Home » Archived » Jubula » best way to enter data into data sets? (Problems with data sets))
best way to enter data into data sets? (Problems with data sets)) [message #987941] Wed, 28 November 2012 12:18 Go to next message
i'm trying to enter 25 rows into a data set. The testcase is based on a "ub_tre_selectNode_byIndexPath". After each row is entered, i press shift+s to save the changes. Than i hit "add" to add a new row. But most of my changes disappear. Once in while the save seems to work (i'm now stuck with 18 rows). Am i doing something wrong?
Re: best way to enter data into data sets? (Problems with data sets)) [message #988266 is a reply to message #987941] Thu, 29 November 2012 03:28 Go to previous messageGo to next message
Hitting <Return> after entering a new row worked for me:
- Enter new row,
- Hit <Return> first, then save the changes (CTRL-s),
- Hit "Add" to add the next row.
But I also struggled with this...
Re: best way to enter data into data sets? (Problems with data sets)) [message #988286 is a reply to message #988266] Thu, 29 November 2012 04:41 Go to previous message
It sounds like you might be running into this problem. It's fixed for Kepler, so for now you'll have to use the workaround which is to make sure that the focus is set correctly after saving. More details are in the bug report.
HTH,
Alex
Previous Topic:problem with cross-platform
Next Topic:'testexec hang-up, after AUT ends' & 'end autrun correctly'
Current Time: Sun Jul 27 11:21:43 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
