How To add a report item [message #986242] |
Mon, 19 November 2012 10:17  |
Hi all,
i' ve searched on this forum, on how to add a radio button on a report, i' ve followed the suggest to add this item bye using a text field with html content. But when i preview the report, the radio button isn' t rendered, and so i' ve decided to add a new report item, i' ve searched and found some guide but seems to be outdated. Finally i've found the sample chapter of Integrating and extending BIRT, where is explained how to extend it, but with no luck, becuase when i need to declare the exported package of this plugin, the dialog choice from runtime tab of plugin manifest definition is empty.
If someone here, exentend BIRT component palette and can suggest me an update guide point on how to develop the new reportitem, i appreciate the aid.
thanks, Patrick.
[Updated on: Mon, 19 November 2012 13:27] by Moderator
Re: How To add a report item [message #988534 is a reply to message #988456] |
Fri, 30 November 2012 06:43   |
Il 30/11/2012 0.58, Michael Williams ha scritto:
> With the standard XLS emitter, you can't do images, but if you were to
> use a plug-in, like:
> http://www.birt-exchange.com/be/marketplace/app-showcase/?app=102
> You could use the image idea for XLS, too.
Tnx Michael, i've two question for you, sorry. The first, how can i
install the app in the birt marketplace? And the second is possible to
integrate into xls emitter some of swing components, like lists and
radiobutton?
regards,
Patrick
Re: How To add a report item [message #988953 is a reply to message #988534] |
Mon, 03 December 2012 22:48  |
To install the plug-in, in the designer, you'd just need to drop it into your plugins folder. There should be a readme or instructions available, with the download, too, I think. For the second question, I haven't tried it. You'd most likely be looking at writing your own / modifying an existing XLS emitter to get the output as you're wanting.
FUDForum. Page generated in 0.10284 seconds
