Home » Modeling » EMF » How open EMF generated editor when model is not in a file?
How open EMF generated editor when model is not in a file? [message #987844] Wed, 28 November 2012 06:16 Go to next message
We're working with a editor for a configuration of a running system. For this we have an Ecore model and are basing the editor on the generated editor project. The model is populated by reading information from an executing system.
How can we open the editor, since we don't have any file representation of the model?
At least at a first glance, the EMF generated editor seems to require a resource which have a file representation.
Appreciate any pointers on how to replace the file depencency, to be able to work purely in memory.
--Fredrik
Re: How open EMF generated editor when model is not in a file? [message #987847 is a reply to message #987844] Wed, 28 November 2012 06:34 Go to previous messageGo to next message
The generated editor expects an IEditorInput which could be a URIEditorInput.
From this, you can generated your model, if the URI is a file or something else. In your case, the "executing system" should deliver a model which can de-serialize
into a Resource the editor can handle. For remote Systems, there are CDOResource, HibernateResource etc... If your system doesn't use any of these technologies,
you would need a ResourceFactory to produce the resource.
An alternative, is to skip resources and feed your editor with EObjects which could be results of a query of some sort.
The JFace viewers used by the editor, can be fed with an EObject and show the containment. (So not necessarly a Resource).
Hope this helps.
Christophe
Re: How open EMF generated editor when model is not in a file? [message #987858 is a reply to message #987844] Wed, 28 November 2012 07:12 Go to previous messageGo to next message
Fredrik,
Comments below.
On 28/11/2012 12:16 PM, Fredrik Attebrant wrote:
You don't necessarily need one...
It does require a resource in its resource set.
One approach to take is use a specialized URI syntax. For example,
foo:/ and define a specialized URIHandlerImpl that overrides canHandle
to recognize the "foo" scheme as its own. You'd specialize the
generated editor to add that to the
resourceSet.getURIConverter().getURIHandlers().add(0, new
FooURIHandlerImpl()). You'd also specialize the URI handler's
createInputStream to create a derived InputStream that overrides read to
return -1 (the stream is always empty); that derived input stream should
also implement URIConverter.Loadable so you'd specialize its
loadResource method to create the EObjects and place them in the
resource's contents (keeping in mind that they should be a copy because
they will be moved to be contained by that resource). You'll probably
need to fuss with some additional things, like the getAttributes so that
the resource is considered read only.
That should allow you to open your editor and display the objects you
want to view...
> --Fredrik
Re: How open EMF generated editor when model is not in a file? [message #1003743 is a reply to message #987858] Mon, 21 January 2013 18:01 Go to previous messageGo to next message
I am also interested in this question. I found a quick and surely dirty solution, and I would like to know what may be wrong with it (as I do not have much experience with EMF). At least it provides a quick way to see if your in-memory model can be displayed in the editor.
1. Comment out the createModel() call in createPages() in the generated editor:
public void createPages() {
	// Creates the model from the editor input
	// createModel();
2. Add your resourceSet as argument to the AdapterFactoryEditingDomain constructor:
protected void initializeEditingDomain() {
	// Create the editing domain with a special command stack.
        //   editingDomain = new AdapterFactoryEditingDomain(adapterFactory,
        //		commandStack, new HashMap<Resource, Boolean>());
			commandStack, yourResourceSetHere);
I have constructed the ResourceSet from my model by using a ResourceSetImpl, and constructing Resource with resourceSet.createResource("someRandomUri").
I guess you do not need to use a specialised Uri handler in this case because the ResourceSet is already loaded.
What would be the drawbacks of this approach?
Re: How open EMF generated editor when model is not in a file? [message #1004057 is a reply to message #1003743] Tue, 22 January 2013 09:01 Go to previous messageGo to next message
Comments below.
On 22/01/2013 2:35 PM, fre Mising name wrote:
> generated editor:
> // createModel();
Or empty out the createModel method itself...
> constructor:
Why not use the editing domain's resource set? I.e., why do you need to
create a different one? The problem here is that
org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.getEditingDomainFor(EObject),
which is used to determine the editing domain from the resource set,
won't be able to find it unless you add the appropriate adapter to your
resource set...
Why not populate the resource set in the createModel method?
What editor input do you use to open the editor?
Re: How open EMF generated editor when model is not in a file? [message #1004449 is a reply to message #1004057] Wed, 23 January 2013 04:06 Go to previous messageGo to next message
Comments below.
> > Hi,
> > generated editor:
> > // createModel();
> > constructor:
> resource set...
Thanks. I initially provided a ResourceSet because I have two editor working on the same resource (showing different subtree of the selection in the ContentOutline), so it seemed natural to provide a ResourceSet from the outside. I now use the one from the EditingDomain, and check that the resource have not already been created in the second editor.
I haven't work on this yet, for the moment I just use the one in the generated editor (URIEditorInput(uri) in the EditorAdvisor))... I first wanted to know if there was something fundamentally wrong with my approach before going further. I guess I'll have to implement an editor input representing my in-memory object. Do you mean I would be better off using the URIEditorInput with a custom scheme?
Re: How open EMF generated editor when model is not in a file? [message #1004468 is a reply to message #1004449] Wed, 23 January 2013 04:56 Go to previous message
Comments below.
On 23/01/2013 10:06 AM, fre Mising name wrote:
> Comments below.
>> > Hi,
>> > generated editor:
>> > // createModel();
>> > constructor:
>> resource set...
It sounds like they should share the editing domain itself. Otherwise
they're likely to have problems with the two separate command stacks...
It's generally the way to pass in the information you want the editor to
use...
> in-memory object.
Yes, I think it should pass in the shared editing domain and the object
you want it to focus on. One problem I can foresee is how closing and
reopening the workbench will preserve this open editor...
> custom scheme?
Not necessarily no. If the two editor are going to share the same
in-memory objects they really must share the editing domain (along with
its command stack and resource set)...
Previous Topic:[xcore/xbase] Referencing operation parameters from inside lambda expressions
Next Topic:EMF Compare bugzilla change
Current Time: Wed Jul 23 20:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.18506 seconds
