Report Designer terribly slow in Linux [message #366614] |
Wed, 14 January 2009 12:56  |
Originally posted by: murilo.vettalabs.com
Hi.
BIRT Report Designer (running inside Eclipse) is extremely slow in Linux
(I've tested in Ubuntu 8.04, 8.10 and 7.04). It's one order of magnitude
slower than in Windows (considering the same machine).
Even trivial tasks such as selecting a report element and modifying a
property (in Property Editor) or scrolling the report takes several
seconds.
Eclipse itself runs fine. I've tried in different machines, with and
without Compiz (hardware-based GUI acceleration), varying CPU (Pentium
HT 4.2 GHz, Core 2 Duo 1.83 GHz, with 1.5 - 2 GB RAM), without any
success. It doesn't matter if I use Eclipse 3.2, 3.3, 3.4.0 or 3.4.1
(with BIRT 2.3.1).
Does anybody have the same problem ? Any tips for solving the issue ?
I'm thinking about using a profiler (Yourkit) in order to identify the
bottlenecks, do anybody have suggestions about where I should look first ?
Thanks a lot in advance!
muriloq
Re: Report Designer terribly slow in Linux [message #366636 is a reply to message #366614] |
Thu, 15 January 2009 15:03   |
Originally posted by: jasonweathersby.alltel.net
Murilo,
I think there is a bug open for this 241742. You may want to add your
comments to that bug. Also have you tried any of the 2.5 builds?
Jason
Murilo S. de Queiroz wrote:
> Hi.
> seconds.
> (with BIRT 2.3.1).
> muriloq
FUDForum. Page generated in 0.27619 seconds
