Home » Modeling » EMF » [CDO] Problem with concurrent read and write threads
[CDO] Problem with concurrent read and write threads [message #987715] |
Tue, 27 November 2012 12:27  |
I'm noticing a very strange behavior in the following test I made using concurrent access.
Scenario: I have 2 threads, 1 reader and 1 writer, executing concurrently. We never have write conflicts, because we have only 1 writer.
The threads are executing without any delay, because I want to see how CDO handles many requests. For each iteration, a new session is created.
During the test I get some exceptions (NPE). If I don't make the commit then there isn't any exception.
!ENTRY org.eclipse.net4j 4 0 2012-11-27 16:31:14.217
!MESSAGE NullPointerException
!STACK 0
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOBranch(CDODataInputImpl.java:188)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOCommitInfo(CDODataInputImpl.java:276)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitNotificationIndication.indicating(CommitNotificationIndication.java:36)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientIndication.indicating(CDOClientIndication.java:56)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
I checked and the writes didn't failed, everything was persisted.
Is this an "expected" behavior (let's say, a known limitation) when opening and closing so many CDOSession in a very short time? Or can we say it is a bug?
I attached the test java file.
Re: [CDO] Problem with concurrent read and write threads [message #987767 is a reply to message #987715] |
Tue, 27 November 2012 22:48   |
Am 27.11.2012 18:27, schrieb Silvestre Martins:
> !STACK 0
CommitNotificationIndication.indicating() is executed asynchronously on a client side after successful commits on the
server side. If the client has closed or is closing the session (with all the contained infrastructure such as the
branch manager) any kind of exception can possibly occur from the notification signal thread. They can all be ignored.
You may call it a known limitation, although the problem is really just the logging of the exception.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Problem with concurrent read and write threads when creating too many sessions [message #988420 is a reply to message #987767] |
Thu, 29 November 2012 15:41   |
Eike Stepper wrote on Tue, 27 November 2012 22:48Am 27.11.2012 18:27, schrieb Silvestre Martins:
> !STACK 0
Cheers
/Eike
So you don't recommend to create a bugzilla for this. This is ok for me, because I don't expect to have this exception very often when running in a normal usage.
BTW, do you know about any example of a typical implementation of CDO in a web application (the CDO client would be in the server side)? I mean, how would, in these case, the CDO Session be used? Mapping the CDO session to the user session seems to be what makes more sense to me, but it may cause the session to stay opened for a long time. Is the CDO session ready for this kind of usage?
In the other hand, creating a CDO Session for each request, may end with too many CDO sessions being created.
Another usage could be to create a CDO session for each "conversation", like when starting a wizard workflow or editing the details of an entity.
Re: [CDO] Problem with concurrent read and write threads when creating too many sessions [message #988475 is a reply to message #988420] |
Fri, 30 November 2012 01:43   |
Am 29.11.2012 21:41, schrieb Silvestre Martins:
> the server side)?
Yes ;-)
> this kind of usage?
CDOSession is kind of an expensive facility because it does authentication/negotiation and it maintains a
CDORevisionCache (plus other caches). If you don't care about session.getUserID() being used for the commits of all
users I'd recommend to use one CDOSession for all users and open CDOViews or CDOTransactions per HttpSession (or per
HttpRequest).
Cheers
/Eike
Re: [CDO] Problem with concurrent read and write threads when creating too many sessions [message #988601 is a reply to message #988475] |
Fri, 30 November 2012 11:26   |
Eike Stepper wrote on Fri, 30 November 2012 01:43Am 29.11.2012 21:41, schrieb Silvestre Martins:
> the server side)?
Yes
> this kind of usage?
HttpRequest).
What about concurrency? I want the users to be able to perform concurrent modifications. Can we have concurrent transactions within same session? I assumed we can't.
More, I want the users to be able to make several changes (like the wizard example) and then perform a save (commit) on the DB. I don't want other users to see the changes before user presses "save".
Re: [CDO] Problem with concurrent read and write threads when creating too many sessions [message #988610 is a reply to message #988601] |
Fri, 30 November 2012 12:07   |
Am 30.11.2012 17:26, schrieb Silvestre Martins:
>> in > the server side)? Yes ;)
>> for > this kind of usage?
>> > Another usage could be to create a CDO session for each "conversation", like when starting a wizard workflow or >
>> HttpRequest).
Sure, you can. As many views and/or transactions as you want.
No problem, CDOTransactions (and the model instance they provide) are fully separated from each other.
Cheers
/Eike
Re: [CDO] Problem with concurrent read and write threads when creating too many sessions [message #988618 is a reply to message #988610] |
Fri, 30 November 2012 12:32   |
Eike Stepper wrote on Fri, 30 November 2012 12:07Am 30.11.2012 17:26, schrieb Silvestre Martins:
>> HttpRequest).
I thought that CDOTransactions shared the same objects from CDOSession cache. In this case it could implement is as you suggested.
Thanks.
Current Time: Sun Jul 27 09:15:57 EDT 2025
Powered by FUDForum. Page generated in 0.34072 seconds
