Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo EMF @OneToOne and @ManyToOne
Teneo EMF @OneToOne and @ManyToOne [message #987233] Sat, 24 November 2012 14:59 Go to next message
Hello.
I am using Teneo 2.0.1 and Hibernate 4.1.8. Here are my DataStore init options:
props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "true");
props.setProperty(PersistenceOptions.ID_COLUMN_NAME, "id");
props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY, "true");
props.setProperty(PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, "false");
props.setProperty(PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY, "true");
I'd like to use fetch=EAGER for some references in my objects. I use these annotations in ecore model: @OneToOne(fetch=EAGER) ; @ManyToOne(fetch=EAGER) ;
<eAnnotations source="teneo.jpa">
<details key="value" value="@OneToOne(fetch=EAGER)"/>
</eAnnotations>
<details key="value" value="@ManyToOne(fetch=EAGER)"/>
</eAnnotations>
I get the following exception:
org.eclipse.emf.teneo.annotations.parser.AnnotationParserException: The eclass: HbAnnotatedEAttribute does not have an efeature for OneToOne
How can I achieve loading of the needed object references?
Svetoslav
Re: Teneo EMF @OneToOne and @ManyToOne [message #987259 is a reply to message #987233] Sun, 25 November 2012 04:47 Go to previous messageGo to next message
Hi Svetoslav,
It seems that you set the OneToOne/ManyToOne annotations are set on an EAttribute and not on an EReference.
If that's not the case can you post/send the ecore?
gr. Martin
On 11/24/2012 08:59 PM, Svetoslav Mising name wrote:
> Hello.
> props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "true"); props.setProperty(PersistenceOptions.ID_COLUMN_NAME,
> "id");
> </eAnnotations>
> </eAnnotations>
> Cheers,
> Svetoslav
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Teneo EMF @OneToOne and @ManyToOne [message #987504 is a reply to message #987259] Mon, 26 November 2012 17:10 Go to previous messageGo to next message
Yes, you are right. I was using the greatest design pattern - copy/paste and accidentally copied @OneToOne under an attribute Smile . Thank you.
I'd like to ask one more question though (not sure if I have to open a new topic). After I switched to FETCH_ASSOCIATION_EXTRA_LAZY = "true" and FORCE_LAZY = "true" hibernate generates very wrong queries - on selects it joins completely irrelevant tables: for example I try to get Student with id = 1 but it joins University table as well (University has many Students but it is irrelevant to this query - the HQL looks like: select s from Student s where s.id=1).
Svetoslav
Re: Teneo EMF @OneToOne and @ManyToOne [message #987523 is a reply to message #987504] Mon, 26 November 2012 18:25 Go to previous messageGo to next message
Hi Svetoslav,
I guess student references university, not sure why the extra joins happen, it all depends on the select behavior of
hibernate which can be influenced:
http://docs.jboss.org/hibernate/orm/4.1/manual/en-US/html_single/#performance-fetching
I would need to see the complete model or better the generated hbm to comment on this in more detail.
gr. Martin
> attribute :) . Thank you.
> s.id=1).
> Cheers,
> Svetoslav
The Netherlands
Re: Teneo EMF @OneToOne and @ManyToOne [message #987757 is a reply to message #987523] Tue, 27 November 2012 17:22 Go to previous message
Hi Martin,
I've just sent you the model, hbm and the generated sql by mail.
Svetoslav
Previous Topic:Hook to modify how xsd:double is serialized by XMLResource
Next Topic:customization templates: EPackageModelGenAnnotation not found
Current Time: Wed Jul 23 05:46:23 EDT 2025
Powered by FUDForum. Page generated in 0.08266 seconds
