| Cancel EVL validation that is in progress [message #987705] |
Tue, 27 November 2012 11:48  |
Hi all,
I have implemented model validation using EVL. This all works great (well have some problems, but will be another story if I feel up for it).
The models that need validation might become large, which in combination of a slow PC might result in several minutes validation time.
So I added a Job (which runs on the background) so the user is still able to work on the model or other things).
Of course, the user might become restless and annoyed and wants to cancel the job using the cancel button on the progress monitor (which popped up due to the Job). My code handles this fine (validation requests are queued), but the status of the monitor is only checked in between validations (that might take this long time)...
The actual question:
I am wondering how to abort a validation that is still in progress when the user clicks the cancel button? It is even possible to cancel/abort an EVL validation or is additional support by Epsilon required? And while we are at it, is it possible to show the validation progress in the monitor?
| Re: Cancel EVL validation that is in progress [message #987746 is a reply to message #987705] |
Tue, 27 November 2012 16:36   |
Hi Maarten,
It depends on how you're launching the EVL script from your job. Since you're running the EVL script from Eclipse, you're probably calling EclipseContextManager#setup to set up Eclipse integration for the context of the EVL module, right?
There's a version of setup that takes both the IEolContext and an IProgressMonitor. If you tie up the return value of the IProgressMonitor#isCanceled() method to the cancel button, the EVL script should be cancelled properly when the user hits the cancel button.
That's pretty much how the cancel button is implemented for all the E*L launch configurations, basically.
As for the progress bar, I don't think we have anything in Epsilon for that. Could you file a feature request for that? How should we measure progress? Should we measure progress by the number of checked constraints, or by the number of checked objects? I think the second option won't scale well to large models, though.
No problem,
Antonio
| Re: Cancel EVL validation that is in progress [message #987808 is a reply to message #987746] |
Wed, 28 November 2012 04:09   |
Antonio Garcia-Dominguez wrote on Tue, 27 November 2012 22:36
Not exactly, the validator is created using
IBatchValidator validator = (IBatchValidator) ModelValidationService.getInstance().newValidator(EvaluationMode.BATCH);
validator.validate(myObject);
During validation my model constraint (provided using the org.eclipse.emf.validation.constraintProviders extension) is found.
In the validate() method I use (a slightly modified version of) the Eclipse diagnostican:
EObject target = ctx.getTarget();
Diagnostician diagnostician = new MyDiagnostician();
Diagnostic diagnostics = diagnostician.validate(target);
The diagnostican class finds the EVL constraint files using the used instances of the extension org.eclipse.epsilon.evl.emf.validation and the actual validation (using the EMF Validation framework) is performed.
Hm... now I wrote this down: this seems a little complicated just to get validation working...
So, I do not have this setup() method I believe..?
I try to keep the EMF validation in the loop, so the validator shows in the Eclipse 'Model Validation' preferences, so the user is able to disable them. And to be able to get regular notifications of the validation result using the IValidationListener interface.
I do need another method to activate the EVL validations? (preferably while keep using the Eclipse/EMF validation framework)
Hm... I did not think of a measure for the amount of work...
Checking by the amount of constraints might be an option, as it is probably easier to get the total amount than the total amount of (nested) objects that needs to be checked? (Especially since the complete resource is currently validated). Also after parsing the EVL files, the number of validation rules is probably known already?
Only thing is, I register a unknown/certain amount of EVL validators. The total progress of one validation cycle, should keep this amount in mind...? Also possible as org.eclipse.epsilon.evl.emf.validation.EValidatorPopulator registers all my validators.
| Re: Cancel EVL validation that is in progress [message #987831 is a reply to message #987808] |
Wed, 28 November 2012 05:31  |
I got curious about EclipseContextManager#setup and saw it was used in the EVLValidator class (which I use somewhere along the line).
I solved my problem and provided a patch: see Bug #395261
Because I execute the validation from a background thread (Job), I get another problem because a MessageDialog is opened on the wrong (non-UI) thread, see Bug #395262.
[Updated on: Wed, 28 November 2012 05:32] by Moderator
FUDForum. Page generated in 0.05947 seconds
