Home » Modeling » ATL » Convert Float to Double - by refInvokeOperation?
Convert Float to Double - by refInvokeOperation? [message #987622] Tue, 27 November 2012 05:56 Go to next message
Hi members,
I'm trying to assign a Float value from a source model object to a Double attribute of the matching target model object:
rule Real2Term {
    from
    	source: transformate!RealTransformer
    to
    	otxTerm: otx!FloatLiteral (
    		value <- source.value -> refInvokeOperation('doubleValue', Sequence{})
which produces the error
org.eclipse.m2m.atl.engine.emfvm.VMException: Wrong use of refInvokeOperation
otxTerm.value is Double, source.value is Float. There is no doubleValue helper (similar to longValue), so I'm trying to access the Java method, which fails.
Thanks for helping.
Re: Convert Float to Double - by refInvokeOperation? [message #987635 is a reply to message #987622] Tue, 27 November 2012 06:42 Go to previous messageGo to next message
This seems to do the required transformation from Float to Double:
rule Real2Term {
    from
    to
    		value <- 1.0 * source.value
However, I would be glad if you could provide an example on how to use refInvokeOperation. I have tried to do that several times unsuccessfully.
Thank you.
Re: Convert Float to Double - by refInvokeOperation? [message #987655 is a reply to message #987635] Tue, 27 November 2012 08:05 Go to previous messageGo to next message
The refInvokeOperation allows to call an operation of a given element type.
For instance considering an operation SampleOperation defined for the type transformate!RealTransformer in your example, it could be called like this:
source.refInvokeOperation('SampleOperation',Sequence{})
Hugo
Re: Convert Float to Double - by refInvokeOperation? [message #987666 is a reply to message #987622] Tue, 27 November 2012 08:53 Go to previous messageGo to next message
Hugo,
do I understand correctly that refInvokeOperation can only be used for model elements, but not - as I tried to do - for their attributes of 'plain' Java types, like Float in the given example?
Re: Convert Float to Double - by refInvokeOperation? [message #987671 is a reply to message #987666] Tue, 27 November 2012 09:21 Go to previous messageGo to next message
refInvokeOperation has no sense if the method name is a contant.
This method is to be used with a variable method name otherwise you can call the method directly.
Re: Convert Float to Double - by refInvokeOperation? [message #987678 is a reply to message #987622] Tue, 27 November 2012 09:46 Go to previous message
Sylvain, I'm still not getting it - does that mean an ATL method (= a helper), or a Java method?
In other words: How to call a method 'directly'?
Previous Topic:ATL plugin in Eclipse
Next Topic:EDate in the transformations
Current Time: Wed Jul 23 20:33:22 EDT 2025
Powered by FUDForum. Page generated in 0.04884 seconds
