Home » Eclipse Projects » Paho » Paho SSL with pre-shared key
Paho SSL with pre-shared key [message #973935] Tue, 06 November 2012 13:43 Go to next message
Hi, i got paho java client working with a mosquitto broker without ssl.
I am trying to set the psk-identity and psk values in the paho client but i am failing.
Using the mosqquitto_sub with --psk-identity and --psk works very well.
I assume i need to use some sort of sslsocketfactory but i havent found any good example to use (very new to ssl also).
Any help or pointers are greatly appreciated.
Thank you.
Re: Paho SSL with pre-shared key [message #987652 is a reply to message #973935] Tue, 27 November 2012 07:55 Go to previous messageGo to next message
Hi Johan, apologies for taking so long to respond but I don't always keep an eye on the web forums as much as on the mailing list.
Does this help at all?
https://gist.github.com/4104301
Re: Paho SSL with pre-shared key [message #991007 is a reply to message #987652] Sun, 16 December 2012 15:07 Go to previous messageGo to next message
It does, thank you!
Sorry for late reply.
Re: Paho SSL with pre-shared key [message #1006448 is a reply to message #991007] Thu, 31 January 2013 06:28 Go to previous messageGo to next message
Hi Johan ,
i am getting following exception :
exception throwing after line :KeyPair key = (KeyPair)reader.readObject();
org.bouncycastle.openssl.PEMException: problem parsing ENCRYPTED PRIVATE KEY: javax.crypto.BadPaddingException: pad block corrupted
at org.bouncycastle.openssl.PEMReader$EncryptedPrivateKeyParser.parseObject(Unknown Source)
at org.bouncycastle.openssl.PEMReader.readObject(Unknown Source)
at org.eclipse.paho.sample.mqttv3app.SslUtil.getSocketFactory(SslUtil.java:38)
at org.eclipse.paho.sample.mqttv3app.Sample.(Sample.java:194)
at org.eclipse.paho.sample.mqttv3app.Sample.main(Sample.java:137)
Caused by: javax.crypto.BadPaddingException: pad block corrupted
How you have attached password file??
I have attached my java file.
Please help me.
Tushar.
  • Attachment: SslUtil.java
    (Size: 2.13KB, Downloaded 594 times)
Re: Paho SSL with pre-shared key [message #1007321 is a reply to message #1006448] Tue, 05 February 2013 09:14 Go to previous messageGo to next message
Hi Tushar, did you see the reply to the same issue you reported on the Github Gist posted by Sharon?
https://gist.github.com/sharonbn/4104301
It sounds like you could have a corrupt certificate file or an issue with the platform you are on?
Re: Paho SSL with pre-shared key [message #1007340 is a reply to message #1006448] Tue, 05 February 2013 10:12 Go to previous message
Hi Tushar, did you see the response Sharon posted to this same issue you reported against his original Gist?
It looks like you may have a corrupt certificate or an encoding issue?
What platform are you on, and what JVM?
Previous Topic:Paho Java client, turning off automatic ping messages
Next Topic:Segmentation Fault Issue
Current Time: Sun Jul 20 03:37:38 EDT 2025
Powered by FUDForum. Page generated in 0.26600 seconds
