Home » Modeling » EMF » [EMF] Notification.REMOVE_MANY not used.
[EMF] Notification.REMOVE_MANY not used. [message #987437] Mon, 26 November 2012 10:48 Go to next message
I noticed the RemoveCommand, when notifying is removing items one by one from a collection. The notification is a Notification.REMOVE for each of the items in the collection of the Remove Command, and this n times matching the size of the collection. I expected a REMOVE_MANY. I also noticed REMOVE_MANY is actually not used the whole EMF framework, besides the validation framework.
Is it wrong to expect a REMOVE_MANY? Why is there, if not used?
thanks Christophe
Re: [EMF] Notification.REMOVE_MANY not used. [message #987558 is a reply to message #987437] Tue, 27 November 2012 02:25 Go to previous messageGo to next message
Christophe,
If you do a removeAll (see
org.eclipse.emf.common.notify.impl.NotifyingListImpl.removeAll(Collection<?>))
or a clear you'll see a REMOVE_MANY. If you look closely at what
org.eclipse.emf.edit.command.RemoveCommand.doExecute() does, you'll see
it's not so easy to call removeAll in the general case because we need
to be very sure to record the index of each object and delete exactly
the object at that index so we can put it back at that index for an undo.
On 26/11/2012 4:48 PM, Christophe Bouhier wrote:
> Hello,
> besides the validation framework. Is it wrong to expect a REMOVE_MANY?
> thanks Christophe
Re: [EMF] Notification.REMOVE_MANY not used. [message #987592 is a reply to message #987558] Tue, 27 November 2012 04:48 Go to previous messageGo to next message
Thanks Ed, I think my IDE setup is broken. Ctrl-Shift-G on REMOVE_MANY, didn't return that reference. Anyway, so looking at the code, "Not easy" seems to be "Not at all"?
 // Remove objects from the owner list by index, starting from the end.
    for (i = indices.length - 1; i >= 0; i--)
      ownerList.remove(indices[i]);
BTW For my usecase, I found a workaround for the "bombardment" of notifications when removing many entries at once, by simply scheduling the following action in a Job with a delay, and re-scheduling when a new notification arrives, but it's not very pretty Confused
I just wonder if it's even possible to get one single notification, and conditions would need to be met. Oh this list is an eContents() list from a CDOResource, not sure that makes any difference.
rgds Christophe
Re: [EMF] Notification.REMOVE_MANY not used. [message #987611 is a reply to message #987592] Tue, 27 November 2012 05:30 Go to previous messageGo to next message
Christophe,
Comments below.
Constants are generally in-lined and you'll only find uses if you have
the source in your workspace.
I already pointed you to exactly the method where it's used.
Yes, I pointed this out because the logic for determining exactly which
things to remove is rather complex and involves using == and .equals to
find the indices first (to deal with removing things from a list that
allows duplicates and that uses .equals to compare elements).
> new notification arrives, but it's not very pretty :?
The notifications are generally batched already by
org.eclipse.emf.edit.ui.provider.NotifyChangedToViewerRefresh
You shouldn't rely on there being just one notification. After all,
many command are composites that do multiple things, e.g., Delete.
> rgds Christophe
Re: [EMF] Notification.REMOVE_MANY not used. [message #987720 is a reply to message #987611] Tue, 27 November 2012 13:01 Go to previous messageGo to next message
On 27.11.12 02.30, Ed Merks wrote:
> Christophe,
Finding at what point to update a view (dependent objects, not
necessarily a user interface) based on a sequence of notifications is
something a lot of applications may find problematic. I've several times
wanted to have a flag to set in a Notification to indicate it's the last
one. Another approach is to generate a synthetic notification that does
no harm, but can be identified as the final in a logical sequence. Is
there a practical way of doing something like this?
Hallvard
Re: [EMF] Notification.REMOVE_MANY not used. [message #987734 is a reply to message #987720] Tue, 27 November 2012 14:41 Go to previous messageGo to next message
Hallvard,
A command stack listener knows when a sequence of related changes are
done. Nothing else knows about "logical sequences".
>> Christophe,
> times wanted to have a flag to set in a Notification to indicate it's
> the last one. Another approach is to generate a synthetic notification
> that does no harm, but can be identified as the final in a logical
> sequence. Is there a practical way of doing something like this?
> Hallvard
Re: [EMF] Notification.REMOVE_MANY not used. [message #987809 is a reply to message #987611] Wed, 28 November 2012 04:09 Go to previous messageGo to next message
Thanks for pointing out the NotifyChangedToViewerRefresh class.
Just looking at the code, I am not sure this is really treating the notifications as a batch?
There is a viewer.refresh for every eventType Notification.REMOVE...
As I said, I found a solution for my case. BTW, I think it could be of value to others, so I blogged about it:
http://modelmoo.blogspot.nl/2012/11/lazy-loading-cdo-backed-jface-viewer.html
Re: [EMF] Notification.REMOVE_MANY not used. [message #987813 is a reply to message #987809] Wed, 28 November 2012 04:17 Go to previous messageGo to next message
Christophe,
In this logic
public void notifyChanged(Notification notification)
if (viewer != null && viewer.getControl() != null &&
!viewer.getControl().isDisposed())
// If the notification is an IViewerNotification, it specifies
how ViewerRefresh should behave. Otherwise fall
// back to NotifyChangedToViewerRefresh, which determines how to
refresh the viewer directly from the model
// notification.
if (notification instanceof IViewerNotification)
if (viewerRefresh == null)
viewerRefresh = new ViewerRefresh(viewer);
if
(viewerRefresh.addNotification((IViewerNotification)notification))
viewer.getControl().getDisplay().asyncExec(viewerRefresh);
it's creating a ViewerRefresh that's asynExeced later so any
notifications that come in after that's scheduled and before it's
executed will be merged in the viewerRefresh...
> notifications as a batch? There is a viewer.refresh for every
> eventType Notification.REMOVE... As I said, I found a solution for my
Re: [EMF] Notification.REMOVE_MANY not used. [message #987826 is a reply to message #987813] Wed, 28 November 2012 05:14 Go to previous messageGo to next message
ah, that's in the AdapterFactoryContentProvider.
I never looked into this before, but what I realize now is, that if an ItemProvider generates the notification, it will be an IViewerNotification which is decorated with additional info, like label update etc.. So my content provider, would need to adapt an object, to get similar behavior as the AdapterFactoryContentProvider... and also handle the caching. sweet.... EMF is a pattern heaven Smile
Re: [EMF] Notification.REMOVE_MANY not used. [message #988412 is a reply to message #987734] Thu, 29 November 2012 14:46 Go to previous messageGo to next message
On 27.11.12 11.41, Ed Merks wrote:
> Hallvard,
Yes, a solution with commands executed by the command stack of an
editing domain can be used, since the commands encapsulate the "logical
sequences" aka transactions and the command stack event will indicate
the boundary.
I've always used this technique with UIs, since it provides undo/redo
etc. However, I haven't considered it appropriate for transactions in
general, like when updating a model based on data from sensors, where a
set of updates are considered one sample. In such a case you don't need
support for undo/redo, and creating and storing the command objects with
all the undo-data may be resource consuming. But you still need
something similar... Hm, perhaps custom commands (that can be reused)
and some flushing of the stack is all that is needed.
Hallvard
Re: [EMF] Notification.REMOVE_MANY not used. [message #988471 is a reply to message #988412] Fri, 30 November 2012 00:51 Go to previous message
Hallvard,
Comments below.
>> Hallvard,
> "logical sequences" aka transactions and the command stack event will
> indicate the boundary.
> a set of updates are considered one sample.
Yes, there's no concept of transactions in the EMF core runtime.
> In such a case you don't need support for undo/redo, and creating and
> storing the command objects with all the undo-data may be resource
> consuming.
Yes, it seems pointless to use full blown command when undo isn't needed.
> But you still need something similar... Hm, perhaps custom commands
> (that can be reused) and some flushing of the stack is all that is
> needed.
Commands have useful information, like the affected objects and the
result that might be useful even in this context.
But if there is no UI, I wonder who is using the information and more
importantly what information exactly they need. After all, many objects
can be affected by changes so does each object want/need to get its own
notification indicating "all done for now"?
One might use a change recorder for this type of application and either
process the information in the ChangeRecorder or process the
ChangeDescription it can produce...
> Hallvard
Previous Topic:[CDO] Problem with concurrent read and write threads
Next Topic:[CDO] Install CDO Server in linux
Current Time: Wed Jul 23 02:01:02 EDT 2025
Powered by FUDForum. Page generated in 0.08716 seconds
