Home » Modeling » ATL » transformation involving UML profiles
transformation involving UML profiles [message #986551] Tue, 20 November 2012 17:03 Go to next message
Hi to everyone,
I'm trying to make an ATL transformation from a model M1 obtained in Papyrus by applying a profile P1. My objective is to obtain another model M2 with another profile P2 applyed on.
My question is:
How can I specify in the "create" clause the metamodels (UML I suppose) and the profiles involved in the transformation?
I look at the Rational2UML example, and I don't understand how the output profiles is supplyed to ATL.
Thanks in advance for the help.
Re: transformation involving UML profiles [message #986610 is a reply to message #986551] Wed, 21 November 2012 03:03 Go to previous messageGo to next message
I have made an example of trasformation from a simple Network model based on a profile called "lanprofile" to a simple graph model based on "graphprofile".
I coded only two rules and when I test the module I get an error.
The code is the following:
-- @nsURI UML=http://www.eclipse.org/uml2/3.0.0/UML
module lan2graph;
create OUT : UML from IN : UML, GRAPHPROF : UML;
helper def : getStereotype(name : String) : UML!Stereotype =
	UML!Stereotype.allInstances()->select(p | p.name = name)->first();
helper context UML!Model def: hasStereotype(name : String) : Boolean =
	not self.getAppliedStereotype(name).oclIsUndefined();
helper context UML!Class def: hasStereotype(name : String) : Boolean =
rule init {
	from
		s: UML!Model
	to
		t: UML!Model (name <- 'graphModel')
do {
 		t.applyProfile(UML!Profile.allInstances()->select(p | p.name = 'graphprofile')->first());
rule class {
 from
  source: UML!Class(  source.hasStereotype('lanprofile::Host') )
 to
  target: UML!Class(  name<-'NodeIstance' )
  do
  	target.applyStereotype(thisModule.getStereotypeGraph('node'));
  	target.setValue(thisModule.getStereotypeGraph('node'), 'name', source.getTagValue(thisModule.getStereotypeGraph('node'),'Name') );
The last lines of infromation execution and error ATL returns are:
getStereotypeGraph:17	enditerate
	stack: Sequence {GRAPHPROF!node}
	locals: self=lan2graph : ASMModule, name='node'
getStereotypeGraph:18	call J.first():J
	locals: self=lan2graph : ASMModule, name='node'	Calling Sequence {GRAPHPROF!node}.first()
	stack: GRAPHPROF!node
	locals:
	stack: OUT!Nodo, GRAPHPROF!node
	locals: self=lan2graph : ASMModule, link=TransientLink {rule = class, sourceElements = {source = org.eclipse.uml2.uml.internal.impl.ClassImpl@5eefda (name: Host, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, targetElements = {target = org.eclipse.uml2.uml.internal.impl.ClassImpl@1bc1cae (name: Nodo, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, variables = {}}, source=IN!Host, target=OUT!Nodo
__applyclass:19	pcall J.applyStereotype(J):J
	locals: self=lan2graph : ASMModule, link=TransientLink {rule = class, sourceElements = {source = org.eclipse.uml2.uml.internal.impl.ClassImpl@5eefda (name: Host, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, targetElements = {target = org.eclipse.uml2.uml.internal.impl.ClassImpl@1bc1cae (name: Nodo, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, variables = {}}, source=IN!Host, target=OUT!Nodo	Calling OUT!Nodo.applyStereotype(GRAPHPROF!node)
org.eclipse.m2m.atl.engine.emfvm.VMException: Exception during invocation of operation applyStereotype on org.eclipse.uml2.uml.internal.impl.ClassImpl@1bc1cae (name: Nodo, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
Java Stack:
	at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.invoke(EMFModelAdapter.java:767)
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:425)
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
	at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
	at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
	at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:937)
	at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1141)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@1f0779c (name: node, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
	at org.eclipse.uml2.uml.internal.operations.ElementOperations.applyStereotype(ElementOperations.java:1413)
	at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereotype(ElementImpl.java:510)
	at sun.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
	at org.eclipse.m2m.atl.engine.emfvm.adapter.EMFModelAdapter.invoke(EMFModelAdapter.java:760)
	... 14 more
Re: transformation involving UML profiles [message #986645 is a reply to message #986610] Wed, 21 November 2012 04:48 Go to previous messageGo to next message
To answer to your first post: M1, P1 & P2 will be the input models of your transformation whereas M2 will be the only output model (all of them conform to the UML metamodel of course).
Concerning your second post, have you set the "Support UML2 stereotypes application" and "Allow inter-model dependencies" options in your ATL launch configuration (cf. the "Advanced" tab of the ATL Launch Configuration UI)?
Hugo
Re: transformation involving UML profiles [message #986708 is a reply to message #986645] Wed, 21 November 2012 06:54 Go to previous messageGo to next message
Thanks Hugo, I think your suggests are useful but now I have another strange error.
The code that get the error is:
module lan2graph;
create OUT : UML from IN : UML, GRAPHPROF : UML, LANPROF : UML;
helper def : getStereotypeGraph(name : String) : UML!Stereotype =
	UML!Stereotype.allInstancesFrom('GRAPHPROF')->select(p | p.name = name)->first();
helper def : getStereotypeLan(name : String) : UML!Stereotype =
	UML!Stereotype.allInstancesFrom('LANPROF')->select(p | p.name = name)->first();
rule init {
	from
		s: UML!Model
	to
do {
rule class {
 	from
 	to
  		target: UML!Class(  name<-'Nodo' )
	do
and the error is:
getStereotypeGraph:19	call J.first():J
	locals:
	locals: self=lan2graph : ASMModule, link=TransientLink {rule = class, sourceElements = {source = org.eclipse.uml2.uml.internal.impl.ClassImpl@1194d7d (name: Host, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, targetElements = {target = org.eclipse.uml2.uml.internal.impl.ClassImpl@c833aa (name: Nodo, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, variables = {}}, source=IN!Host, target=OUT!Nodo
	locals: self=lan2graph : ASMModule, link=TransientLink {rule = class, sourceElements = {source = org.eclipse.uml2.uml.internal.impl.ClassImpl@1194d7d (name: Host, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, targetElements = {target = org.eclipse.uml2.uml.internal.impl.ClassImpl@c833aa (name: Nodo, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)}, variables = {}}, source=IN!Host, target=OUT!Nodo	Calling OUT!Nodo.applyStereotype(GRAPHPROF!node)
	stack:
	locals:
	stack:
__exec__:19	enditerate
	stack:
	locals:
	stack:
	locals:
Java Stack:
	at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:51)
	at org.eclipse.m2m.atl.engine.emfvm.lib.ExecEnv.terminated(ExecEnv.java:2557)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:210)
Caused by: java.lang.reflect.InvocationTargetException
	at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.applyDelayedInvocations(UML2ModelAdapter.java:136)
	at org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:49)
	... 12 more
Caused by: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@3b7999 (name: node, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
	... 17 more
I hope you can still help me.
[Updated on: Wed, 21 November 2012 07:08] by Moderator
Re: transformation involving UML profiles [message #986711 is a reply to message #986708] Wed, 21 November 2012 07:17 Go to previous messageGo to next message
Maybe the name of the stereotype is not correctly set when calling to getStereotypeGraph: does something like getStereotypeGraph('GRAPHPROF::Node') work better (with GRAPHPROF as actual profile name in your profile file and Node as stereotype name)?
Hugo
Re: transformation involving UML profiles [message #986728 is a reply to message #986711] Wed, 21 November 2012 08:23 Go to previous messageGo to next message
Hugo Bruneliere wrote on Wed, 21 November 2012 07:17
I redefined the helper function getSteretypeGraph as you said:
helper def : getStereotypeGraph(qname : String) : UML!Stereotype =
	UML!Stereotype.allInstances()->select(p | p.qualifiedName = qname)->first();
So the call becomes:
target.applyStereotype(thisModule.getStereotypeGraph('graphprofile::node'));
but it returns the same error above.
Re: transformation involving UML profiles [message #986812 is a reply to message #986728] Wed, 21 November 2012 13:01 Go to previous messageGo to next message
I've just found a bug report here that seems to describe the same error occured to me.
The reporter wrote:
If an ATL transformation is run against a UML model which has a profile attached that is, a) not exported using a EMF URL PATHMAP or b) not located on the file system locally, then ATL will crash with the following exception:
We can avoid the exception normally by exposing profiles we use as both GMF and EMF pathmaps. However, if a modeller add a previously unknown profile without assigning a EMF pathmap then ATL will fail with the above exception.
I don't understand the workaround.
I created my profiles and my input model in Papyrus and then I used those as they are. Have I to modify the model or the profiles in any way before to execute the trasformation?
Thanks again for the help.
Re: transformation involving UML profiles [message #986836 is a reply to message #986812] Wed, 21 November 2012 16:31 Go to previous messageGo to next message
The error you see does not sound like it related to that issue in Bugzilla. The issue in Bugzilla, reported by me, occurs when ATL encounters a profiled UML model, whose profile has not been exposed in a way ATL can process it i.e. EMF Pathmap
The issue you see "org.eclipse.m2m.atl.engine.emfvm.adapter.UML2ModelAdapter.finalizeModel(UML2ModelAdapter.java:51)" is nearly always because you are generating an invalid/malformed output UML model. The error is a little cryptic but it stems from the fact the model is not serializable and so the profile cannot be applied correctly.
Try running the transform without applying the profile on the output model. I would bet your model isn't valid. Try running a validate on it. You will probably see an element sitting outside the model, when it really should be nested somewhere else. Assuming that is the problem, fix the offending rule, then put back in the profile application code.
Ronan
Re: transformation involving UML profiles [message #987578 is a reply to message #986836] Tue, 27 November 2012 03:50 Go to previous messageGo to next message
Thank you, very much! You guessed the cause of the error. But now i have another question.
To solve the problem, that is creating alle the elements inside the Model, I wrote a general rule and some lazy rules:
rule main {
 from
    s: UML!Model ( s.name = 'model')
 to
    container1 : UML!Model (
	name<- 'graphModel',
        packagedElement <- UML!Class.allInstancesFrom('IN')->select( c |
                                  c.hasStereotype('lanprofile::Host'))->collect( t |
                                  thisModule.host2node(t) ),
	packagedElment <-  [...]
   do {
 	container1.applyProfile(UML!Profile.allInstances()->select(p |
lazy rule host2node {
 	from
  		source: UML!Class
 	to
  		target: UML!Class ( name <- 'Node')
	do
        target.setValue(thisModule.getStereotypeGraph('graphprofile::node'), 'name',
                                     source.getTagValue('lanprofile::Host','Name') );
The problem now is that I can't use the simple approach of Matched Rules, and so I can't look for patterns in my input model.
So my question is: there's a way to move the target pattern elements inside the Model, for example in the "do" section of a matched rule?
More clearly, I would like to write rules like this:
rule host_router {
    from
	host1 : UML!Class,
	host2 : UML!Class,
	host1_host2 : UML!Association (
                           host1.hasStereotype('lanprofile::Router') and
                           host2.hasStereotype('lanprofile::Host') and
			   (host1_host2.endType.first() = host1 and
                            host1_host2.endType.last() = host2
	to
		node_host1 : UML!Class ( name <- host1.getTagValue('lanprofile::Router','Name')  ),
		node_host2 : UML!Class (  name <- host2.getTagValue('lanprofile::Host','Name') ),
		node1_node2 : UML!Association
	do
		moveToModel(node_host1);
		moveToModel(node_host2);
		moveToModel(node1_node2);
[Updated on: Tue, 27 November 2012 04:06] by Moderator
Re: transformation involving UML profiles [message #1200626 is a reply to message #987578] Thu, 21 November 2013 05:26 Go to previous messageGo to next message
I've a new strange Problem. Now with applying UML Stereotypes. Hope that anyone can help me to find a solution.
I like transform in input Model= UML model+profil1+profile2 in to output Model=UML model+profil1+profile3
profile1=SysML
profile2=MuseML
profile3=Sym
-- @nsURI MModelicaMLProfile=http://www.eclipse.org/papyrus/0.10.0/SysML4Modelica
-- @nsURI MMsysml=http://www.eclipse.org/papyrus/0.7.0/SysML
-- @nsURI MMuml=http://www.eclipse.org/uml2/4.0.0/UML
-- @nsURI MMmuseMLProfile=http://www.eclipse.org/papyrus/MuseML/1
create OUT : MMuml from INuml : MMuml, INsysml : MMsysml, INmuseMLProfile: MMmuseMLProfile, ImodelicaMLProfile: MModelicaMLProfile ;
rule applyprofil{
from museml: MMuml!Model
to
sym: MMuml!Model(
name<- museml.name
do{
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='SysML').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Blocks').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='ModelElements').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='PortAndFlows').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Constraints').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Activities').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Allocations').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Requirements').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Interactions').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='StateMachines').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='UseCases').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='SysML4Modelica').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Classes').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Components').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='EquationsAndAlgorithms').first());
sym.applyProfile(MMuml!Profile.allInstances()->select(p | p.name ='Other').first());
rule Muse2ModelicaModel{
from museml: MMuml!Class(
thisModule.isBlockStereotyped(museml) and
museml.isMuseMLClassDefinitionStereotyped()
to
sym: MMuml!Class(
name<- museml.name
-- name <- sym.namee
do{
sym.applyStereotype(museml.getApplicableStereotype('SysML::Blocks::Block'));
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:43)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate$1.run(AtlLaunchConfigurationDelegate.java:274)
... 6 more
Caused by: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@1791d92 (name: Block, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false) (isActive: false)
... 12 more
Re: transformation involving UML profiles [message #1200977 is a reply to message #1200626] Thu, 21 November 2013 09:07 Go to previous messageGo to next message
Your model is not serializable to UML. Thus the error. Where have you assigned the classes you generate to the model? The model must be serializable to correct UML before you start applying stereotypes.
Ronan
Re: transformation involving UML profiles [message #1698716 is a reply to message #1200977] Wed, 17 June 2015 08:13 Go to previous message
I had a similar problem. Maybe my solution will be helpful for someone... I'm using QVTo instead of ATL, but I guess that the idea is the same.
The following code:
modeltype ISO20022 uses 'urn:iso:std:iso:20022:2013:ecore';
modeltype UML uses 'http://www.eclipse.org/uml2/3.0.0/UML';
transformation ModelToDatabase(in m : ISO20022, in p : UML, out uml : UML);
property profile : Profile = p.rootObjects()![Profile];
main()
    m.objectsOfType(Repository)->toModel();
mapping Repository::toModel() : UML::Model
	result.applyProfile(profile);
	name := 'Repository';
	packagedElement += self.dataDictionary->toPackage(); // 2 add nested package to the model
mapping DataDictionary::toPackage() : UML::Package
	name := 'DataDictionary';
	result.applyStereotype(profile.getStereotype(name)); // 1 apply stereotype
query Profile::getStereotype(name : String) : Stereotype =
	profile.ownedStereotype->any(st|st.name = name);
causes the exception:
Caused by: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@d36f83e7 (name: DataDictionary, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
	at org.eclipse.uml2.uml.internal.operations.ElementOperations.applyStereotype(ElementOperations.java:1411)
I think that the exception is raised because I tried to apply the stereotype to the nested package before the later one is added to the model.
Here is a fix, take a look at comments:
main()
	self.dataDictionary->toPackage(result);
mapping DataDictionary::toPackage(owner : Package) : UML::Package
	nestingPackage := owner; // 1 add nested package to the model
	result.applyStereotype(profile.getStereotype(name)); // 2 apply stereotype
Previous Topic:Drools Meta Model
Next Topic:[ATL] How programmatically know name and referenceModelName in ATL transformations
Current Time: Fri Jul 25 23:44:35 EDT 2025
Powered by FUDForum. Page generated in 0.04851 seconds
