Getting Started [message #987543] |
Tue, 27 November 2012 00:28  |
I am a beginner and getting started to use eclipse RAP.
I installed eclipse RAP and I tried executing the first sample hello RAP template.
I get this error message,
HTTP ERROR: 404
Problem accessing /rap. Reason:
ProxyServlet: /rap
Powered by Jetty://
Can any one please help me get started?
Re: Getting Started [message #987645 is a reply to message #987640] |
Tue, 27 November 2012 07:21  |
probably you are using RAP 2.0M3 with Juno "Eclipse for RCP and RAP
developers" which includes RAP Tools 1.5.x. The application generated
with templates by RAP Tools 1.5.x is not compatible with RAP 2.0. If you
are using RAP Tools 1.5 I will suggest to stay with RAP Runtime 1.5. If
you want to go with RAP 2.0 please get Eclipse Juno Classic package and
install RAP Tools 2.0 from [1].
[1] http://www.eclipse.org/rap/downloads/
HTH,
Ivan
On 11/27/2012 2:06 PM, Bindhu Niranjan wrote:
> Hi Ivan,
> Thank you for your response.
> I still keep getting the same message in the browser.
> I also see the below listed error message in the console.
> 2012-11-27 15:58:24.636:INFO:oejs.Server:jetty-8.1.3.v20120522
> 2012-11-27 15:58:24.759:INFO:oejs.AbstractConnector:Started
> mailto:SelectChannelConnector@0.0.0.0:4153
> !SESSION 2012-11-27 15:58:23.980
> eclipse.buildId=unknown
> java.version=1.7.0
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
> Command-line arguments: -dev
> file:C:/Users/Fusionss-1/workspace_juno/.metadata/.plugins/org.eclipse.pde.core/test/dev.properties
> -os win32 -ws win32 -arch x86_64 -console -consolelog -data
> C:\Users\Fusionss-1\workspace_juno/.metadata/.plugins/org.eclipse.rap.ui.launch/test
> !ENTRY org.eclipse.osgi 4 0 2012-11-27 15:58:25.144
> !MESSAGE An unexpected runtime error has occurred.
> !STACK 0
> java.lang.NullPointerException: The parameter 'path' must not be null.
> at
> org.eclipse.rap.rwt.internal.util.ParamCheck.notNull(ParamCheck.java:40)
> at
> org.eclipse.rap.rwt.internal.application.ApplicationImpl.addEntryPoint(ApplicationImpl.java:93)
> at
> org.eclipse.rap.ui.internal.servlet.WorkbenchApplicationConfigurator.registerApplicationEntryPoints(WorkbenchApplicationConfigurator.java:205)
> at
> org.eclipse.rap.ui.internal.servlet.WorkbenchApplicationConfigurator.configure(WorkbenchApplicationConfigurator.java:101)
> at
> org.eclipse.rap.rwt.internal.application.ApplicationContextConfigurator.configureCustomSettings(ApplicationContextConfigurator.java:51)
> at
> org.eclipse.rap.rwt.internal.application.ApplicationContextConfigurator.configure(ApplicationContextConfigurator.java:40)
> at
> org.eclipse.rap.rwt.internal.application.ApplicationContext.doActivate(ApplicationContext.java:249)
> at
> org.eclipse.rap.rwt.internal.application.ApplicationContext.activate(ApplicationContext.java:120)
> at
> org.eclipse.rap.rwt.application.ApplicationRunner.activateApplicationContext(ApplicationRunner.java:114)
> at
> org.eclipse.rap.rwt.application.ApplicationRunner.start(ApplicationRunner.java:82)
> at
> org.eclipse.rap.rwt.osgi.internal.ApplicationReferenceImpl.startRWTApplication(ApplicationReferenceImpl.java:77)
> at
> org.eclipse.rap.rwt.osgi.internal.ApplicationReferenceImpl.start(ApplicationReferenceImpl.java:63)
> at
> org.eclipse.rap.rwt.osgi.internal.ApplicationLauncherImpl.doLaunch(ApplicationLauncherImpl.java:103)
> at
> org.eclipse.rap.rwt.osgi.internal.ApplicationLauncherImpl.launch(ApplicationLauncherImpl.java:85)
> at
> org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.startApplication(HttpServiceTracker.java:75)
> at
> org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.addingService(HttpServiceTracker.java:46)
> at
> org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.addingService(HttpServiceTracker.java:1)
> at
> org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932)
> at
> org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
> at
> org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
> at
> org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
> at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:317)
> at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
> at
> org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.access$6(HttpServiceTracker.java:1)
> at
> org.eclipse.rap.ui.internal.servlet.HttpServiceTracker$ApplicationLauncherTracker.addingService(HttpServiceTracker.java:125)
> at
> org.eclipse.rap.ui.internal.servlet.HttpServiceTracker$ApplicationLauncherTracker.addingService(HttpServiceTracker.java:1)
> at
> at
> at
> at
> org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
> at
> org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:894)
> at
> org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
> at
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
> at
> org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
> at
> org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
> at
> org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
> at
> org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451)
> at
> org.eclipse.rap.rwt.osgi.internal.Activator.registerService(Activator.java:50)
> at
> org.eclipse.rap.rwt.osgi.internal.Activator.registerApplicationLauncher(Activator.java:45)
> at
> org.eclipse.rap.rwt.osgi.internal.Activator.start(Activator.java:26)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
> at
> org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
> at
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
> !ENTRY org.eclipse.rap.ui.workbench 4 0 2012-11-27 15:58:25.146
> !MESSAGE FrameworkEvent ERROR
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi>
> Please advice.
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03350 seconds
