Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Hook to modify how xsd:double is serialized by XMLResource
Hook to modify how xsd:double is serialized by XMLResource [message #987235] |
Sat, 24 November 2012 15:40  |
Could someone point me to where I can hook into how the XSD types are serialized by XMLResource? I am specifically interested in modifying how xsd:double types are written.
Right now, even if they have no fractional portion it still puts a ".0" at the end. For example:
<MYFLOAT>7.0</MYFLOAT>
<MYFLOAT>0.0</MYFLOAT>
For consistency with external tools we are integrating with I would prefer it to not add the .0 when there is no fractional portion. For example:
<MYFLOAT>7</MYFLOAT>
<MYFLOAT>0</MYFLOAT>
dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987244 is a reply to message #987235] |
Sun, 25 November 2012 01:12   |
Dave,
This is done in, like for any other EDataType, in the generated factory
for that data type. In this case in
org.eclipse.emf.ecore.xml.type.impl.XMLTypeFactoryImpl.convertDoubleToString(EDataType,
Object). You can't specialize that class, but if you create your own
specialized EDataType, i.e., if you define your own derived
xsd:simpleType, you'll have your own factory method you can specialize.
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987245 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987246 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987247 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987248 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987249 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987250 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987251 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987252 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987253 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987254 is a reply to message #987235] |
Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987276 is a reply to message #987244] |
Sun, 25 November 2012 10:26   |
Thanks Ed
I should have mentioned in my original post that I am using dynamic EMF, so I have no generated code to modify. Is there still a hook, perhaps to override the "dynamic object" factory where I can check the type being serialized and catch it there?
dave
Ed Merks wrote on Sun, 25 November 2012 01:12Dave,
> example:
> dave
Re: Hook to modify how xsd:double is serialized by XMLResource [message #987304 is a reply to message #987276] |
Sun, 25 November 2012 16:17  |
David,
No, there's not much you can do in this case, except perhaps
specializing
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.convertToString(EFactory,
EDataType, Object)
On 25/11/2012 4:26 PM, David Rees wrote:
> Thanks Ed
> dave
>> Dave,
>> factory for that data type. In this case in
>> are > serialized by XMLResource? I am specifically interested in
>> modifying > how xsd:double types are written.
>> would > prefer it to not add the .0 when there is no fractional
>> portion. For > example:
>> > Thanks,
>> > dave
Current Time: Wed Jul 23 05:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.13334 seconds
