Home » Modeling » Papyrus » types of interface
types of interface [message #987201] Sat, 24 November 2012 07:42 Go to next message
hello everyone
i want to build provided interface and required interface
i select interface from Palette but how to make this interface provided or required?
Best Regards
Laya
Re: types of interface [message #987227 is a reply to message #987201] Sat, 24 November 2012 14:13 Go to previous messageGo to next message
Hi, Laya,
The distinction between "provided" and "required" Interfaces is not
intrinsic to the interfaces, themselves. Rather, it is in how a
Component depends on them.
A "provided" interface is nothing more than an interface that a
Component makes available to other Components by providing some
implementation of that interfaces.
A "required" interface is nothing more than an interface that a
Component needs to implement its function, which it expects to be
provided by some other component in the assembly.
Required interfaces are typically determined by the dependencies of a
Component and/or the types of its parts and its ports. Provided
interfaces are typically determined by the InterfaceRealizations of a
HTH,
Christian
On 2012-11-24 12:42:30 +0000, Laya eng said:
> hello everyone
> or required?
> Best Regards
> Laya
Re: types of interface [message #987371 is a reply to message #987227] Mon, 26 November 2012 05:36 Go to previous messageGo to next message
Hello Laya,
From the tool point of view, you can edit the port's interfaces from the "Manage Interfaces" menu.
Simply right-click on the port, and select "Manage Interfaces".
Camille
Re: types of interface [message #987428 is a reply to message #987371] Mon, 26 November 2012 10:08 Go to previous messageGo to next message
Hello Christian ,Hello Camille
thank you for helping me
1*only use required and provided interface with component diagram?if yes
so in what case we use the interface element in Palette?
2*i try what you mentioned above
please check them to specify the correctness of them because when i right click on port i don't find "Manage Interfaces" option
Best Regards
Laya
  • Attachment: step1.PNG
    (Size: 6.61KB, Downloaded 331 times)
  • Attachment: step2.PNG
    (Size: 26.84KB, Downloaded 410 times)
Re: types of interface [message #987430 is a reply to message #987428] Mon, 26 November 2012 10:10 Go to previous messageGo to next message
The menu doesn't appear on the port's label (This is a usability issue).
You have to right click on the port element.
Camille
Re: types of interface [message #987433 is a reply to message #987430] Mon, 26 November 2012 10:24 Go to previous messageGo to next message
Hello Camille
Please check it
i didn't find this option
Laya
  • Attachment: try.png
    (Size: 101.70KB, Downloaded 351 times)
Re: types of interface [message #987699 is a reply to message #987430] Tue, 27 November 2012 11:26 Go to previous messageGo to next message
Hello Camille
i use the last version of Papyrus juno
i don't find this option?
Laya
Re: types of interface [message #987702 is a reply to message #987699] Tue, 27 November 2012 11:31 Go to previous messageGo to next message
Hello Laya,
I've checked the handler test, and it's a little bit restrictive. The menu only appears when you right-click on a Graphical port (From the diagram). It won't be available in the ModelExplorer, nor on the port's label from the diagram.
Camille
[Updated on: Tue, 27 November 2012 11:31] by Moderator
Re: types of interface [message #987706 is a reply to message #987702] Tue, 27 November 2012 11:51 Go to previous messageGo to next message
Hello Camille
thank you so much for your efforts
yes i find it but a message occur told me to define port before manage it as illustrated in attachment
how can i define it?
Laya
  • Attachment: define.PNG
    (Size: 29.97KB, Downloaded 351 times)
Re: types of interface [message #988422 is a reply to message #987702] Thu, 29 November 2012 15:46 Go to previous messageGo to next message
Hello Camille,
i try to perform two cases
the first one is to specify that a component require number of operations and the second case that a component provide number of opertions required by other component
so where can i define these operation?
Laya
Re: types of interface [message #988616 is a reply to message #987702] Fri, 30 November 2012 12:25 Go to previous messageGo to next message
Hello Camille
i am really miss you
you are smart and active member in this sub-forum and i hope i can do the same for other members
i hope you guide me in finding the way to perform two cases mentioned above
Kind Regards
Laya
Re: types of interface [message #988805 is a reply to message #988616] Mon, 03 December 2012 04:58 Go to previous message
Hello Laya,
To manage ports required/provided interfaces, here are the steps to follow:
- Create a Port on either a Component (Component diagram) or a Class (Composite structure diagram)
- Set this Port's type to either a Class or an Interface
- Right click on the graphical representation of the Port, and select "Manage interfaces"
- Select the interfaces this Port provides (i.e. implements) and requires (i.e. depends on). Note that when the Port is typed with an Interface, this interface is automatically "Provided", and you cannot add new Provided interfaces.
So, two things to remember:
- Provided/Required are derived properties. They are derived from the type of the Port. So the Port needs a type before you can use "Manage interfaces"
- The "Manage interfaces" menu is only available on diagrams, for Composite Structure and Component diagrams. You have to right click on the graphical representation of the Port. This is a tool limitation which will need to be fixed.
Camille
Previous Topic:Use Case Specification
Next Topic:MARTE profile in uml format
Current Time: Sun Jul 27 16:27:16 EDT 2025
Powered by FUDForum. Page generated in 0.34073 seconds
