Home » Modeling » OCL » def initialized with alternatives (or)
def initialized with alternatives (or) [message #987183] Sat, 24 November 2012 03:43 Go to next message
I need to define a def: which depends on two different alternatives in or.
Precisely I am validating a DSL and I need to retrieve the type of a variable. This depends on the where the variable was defined. It may be for instance a parameter of a method, a property of a class, a local variable. Then I thought to create a def, typed as ocl::OclElement, in the context of the Variable meta-class initialized by these three different possibilities in or. Am I doing the right thing?
Re: def initialized with alternatives (or) [message #987190 is a reply to message #987183] Sat, 24 November 2012 05:28 Go to previous messageGo to next message
A better solution may be defining a set but It seems I am making some syntactical error.
I am doing something like
def: type: Set = {variable.<the first possible element>, variable.<the second possible element>}
or
def: type: Set{} = {variable.<the first possible element>, variable.<the second possible element>}
but in both the cases I get an error.
Also as the two elements of the set are mutually exclusive would this solution be feasible?
Re: def initialized with alternatives (or) [message #987193 is a reply to message #987190] Sat, 24 November 2012 05:57 Go to previous messageGo to next message
You don't explain your problem clearly enough for me to understand "in
or" is not English.
You don't identify what errors you give or provide sufficient context to
reproduce the error.
A zipped project demonstrating your best attempt is nearly always a good
way to avoid wasting my time (and yours).
Ed Willink
> syntactical error.
> or
Re: def initialized with alternatives (or) [message #987207 is a reply to message #987183] Sat, 24 November 2012 08:30 Go to previous message
the right form is
def: type: Set = Set{<first element>, <second element>}
Previous Topic:Custom OCL error messages
Next Topic:Using OCL MDT sources from git
Current Time: Sun Jul 20 20:12:59 EDT 2025
Powered by FUDForum. Page generated in 0.03470 seconds
