Home » Modeling » Papyrus » Inconsistencies between ".di"file and ".uml"file
Inconsistencies between ".di"file and ".uml"file [message #987025] Thu, 22 November 2012 21:58 Go to next message
My papyrus is 0.9.1,when I delete something,like one class,in the class diagram and save the ".di" file,but the ".uml" file remain the deleted element.I reopen the ".uml" file,it remain the deleted element as before.What's wrong?Is it a bug?By the way, how can I generate the ".di" file from ".uml" file?
Re: Inconsistencies between ".di"file and ".uml"file [message #987031 is a reply to message #987025] Thu, 22 November 2012 22:48 Go to previous messageGo to next message
You are probably deleting only the *view* of the element from the
diagram. To delete the element from the model also is a different
operation. By default, the Delete key deletes only the view.
Right-click on the element in the diagram to find an action to delete
the element from the model.
What do you mean by generating the *.di file from the *.uml file? It
isn't a generated file. It has entirely its own data, with only
references to the diagrams in the *.notation file. This latter is what
references the elements in the *.uml file.
HTH,
Christian
Re: Inconsistencies between ".di"file and ".uml"file [message #987039 is a reply to message #987031] Fri, 23 November 2012 00:53 Go to previous messageGo to next message
Hello Christian
why di and notation file created when we create new papyrus model?
Re: Inconsistencies between ".di"file and ".uml"file [message #987064 is a reply to message #987031] Fri, 23 November 2012 04:21 Go to previous messageGo to next message
I copy the content of the ".uml" file to a text file,and I delete the ".di" file carelessly.So I wonder if I can recover the graphical model from the content of the ".uml" file.
Re: Inconsistencies between ".di"file and ".uml" [message #987100 is a reply to message #987064] Fri, 23 November 2012 08:21 Go to previous messageGo to next message
The diagrams are all in the *.notation file, not the *.di file.
You can recover the *.di file from the workspace's local history.
Right-click on the folder that contained the *.di file and select the
"Restore from Local History..." action.
HTH,
Christian
Re: Inconsistencies between ".di"file and ".uml" [message #987101 is a reply to message #987039] Fri, 23 November 2012 08:23 Go to previous messageGo to next message
Hi, Ann,
Do you mean Why are they separate files and not just combined in one?
Separation of concerns, I suppose, but hopefully a Papyrus committer
who knows the history of the design can answer that.
cW
On 2012-11-23 05:53:17 +0000, Ann barry said:
> Hello Christian why di and notation file created when we create new
> papyrus model?
> Regards
Re: Inconsistencies between ".di"file and ".uml" [message #987141 is a reply to message #987101] Fri, 23 November 2012 13:07 Go to previous message
Hello Christian
i also don't know the exact reason
may be related to design concept:separation of concern
however, thank you for your analysis
Ann
Previous Topic: MARTE palette usage
Next Topic:Failed to load Papyrus model with MARTE Stereotypes in standalone application
Current Time: Sat Jul 26 11:50:13 EDT 2025
Powered by FUDForum. Page generated in 0.07875 seconds
