Repeated Errors After Update [message #978087] |
Fri, 09 November 2012 15:52  |
Hello
I am having no luck attempting to clear the following error, even after I hand edit the file and add the end tag.
Unable to read repository at file:/C:/Users/XXXX/Downloads/eclipse-jee-indigo-SR2-win32-x86_64/eclipse/p2/org.eclipse.equinox.p2.repository/cache/compositeContent-87448873.xml
This is the file:
<repository name="Papyrus" type="org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository" version="1.0.0">
<properties size="1">
<property name="p2.timestamp" value="1346835532000">
</properties>
<children size="1">
<child location="SR2_RC4"/>
</children>
</repository>
Here is the error log:
java.io.IOException: The element type "property" must be terminated by the matching end-tag "</property>".
at org.eclipse.equinox.internal.p2.persistence.CompositeParser.parse(CompositeParser.java:191)
at org.eclipse.equinox.internal.p2.persistence.CompositeRepositoryIO.read(CompositeRepositoryIO.java:64)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:118)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:749)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:402)
at org.eclipse.equinox.internal.p2.ui.QueryableMetadataRepositoryManager.doLoadRepository(QueryableMetadataRepositoryManager.java:46)
at org.eclipse.equinox.internal.p2.ui.QueryableMetadataRepositoryManager.doLoadRepository(QueryableMetadataRepositoryManager.java:1)
at org.eclipse.equinox.internal.p2.ui.QueryableRepositoryManager.loadRepository(QueryableRepositoryManager.java:120)
at org.eclipse.equinox.internal.p2.ui.QueryableRepositoryManager.query(QueryableRepositoryManager.java:157)
at org.eclipse.equinox.internal.p2.ui.QueryableRepositoryManager.query(QueryableRepositoryManager.java:72)
at org.eclipse.equinox.internal.p2.ui.ElementQueryDescriptor.performQuery(ElementQueryDescriptor.java:60)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:104)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.getChildren(QueriedElement.java:69)
at org.eclipse.equinox.internal.p2.ui.viewers.DeferredQueryContentProvider.getChildren(DeferredQueryContentProvider.java:113)
at org.eclipse.equinox.internal.p2.ui.viewers.DeferredQueryContentProvider.getElements(DeferredQueryContentProvider.java:86)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:1010)
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:703)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1336)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:391)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:917)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:605)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:805)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:782)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:753)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1533)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:833)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1517)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1443)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:403)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1404)
at org.eclipse.jface.viewers.CheckboxTreeViewer.preservingSelection(CheckboxTreeViewer.java:416)
at org.eclipse.equinox.internal.p2.ui.dialogs.ContainerCheckedTreeViewer.preservingSelection(ContainerCheckedTreeViewer.java:264)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1510)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1690)
at org.eclipse.equinox.internal.p2.ui.dialogs.AvailableIUGroup$9.run(AvailableIUGroup.java:419)
at org.eclipse.equinox.internal.p2.ui.dialogs.AvailableIUGroup.updateAvailableViewState(AvailableIUGroup.java:416)
at org.eclipse.equinox.internal.p2.ui.dialogs.AvailableIUGroup.setRepositoryFilter(AvailableIUGroup.java:480)
at org.eclipse.equinox.internal.p2.ui.dialogs.AvailableIUsPage.repoComboSelectionChanged(AvailableIUsPage.java:338)
at org.eclipse.equinox.internal.p2.ui.dialogs.AvailableIUsPage$11.repositorySelectionChanged(AvailableIUsPage.java:311)
at org.eclipse.equinox.internal.p2.ui.dialogs.RepositorySelectionGroup.repoComboSelectionChanged(RepositorySelectionGroup.java:652)
at org.eclipse.equinox.internal.p2.ui.dialogs.RepositorySelectionGroup$4.modifyText(RepositorySelectionGroup.java:173)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:179)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Combo.wmCommandChild(Combo.java:2457)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:4669)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4531)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2425)
at org.eclipse.swt.widgets.Combo.callWindowProc(Combo.java:300)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:2142)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.equinox.p2.ui.ProvisioningUI.openInstallWizard(ProvisioningUI.java:209)
at org.eclipse.equinox.internal.p2.ui.sdk.InstallNewSoftwareHandler.doExecute(InstallNewSoftwareHandler.java:31)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler.doExecuteAndLoad(PreloadingRepositoryHandler.java:114)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.run(PreloadingRepositoryHandler.java:68)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler.execute(PreloadingRepositoryHandler.java:66)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Thanks in advance for help with this ...
FUDForum. Page generated in 0.04987 seconds
