Home » Modeling » M2T (model-to-text transformation) » How to use generic types with for sequence?
How to use generic types with for sequence? [message #986838] Wed, 21 November 2012 16:40 Go to next message
For my studies I develop an HTML code generator with Acceleo v3.3.1.
To do this I have to run through different classes that didn't get the same ancestors (probably a mistake in my ecore model but it is to late to change it), how can I do to loop over all the classes? I tried to cast them with OclAny and T but the twice give me the following error:
Module generateHtml for block for (aContenu.oclAsType(site::Rubrique).eContents()). site.impl.TexteImpl was not an instanceof T.
Here is the code where the error is thrown:
[for (aDiv : T | aContenu.oclAsType(Rubrique).eContents())]
[if aDiv.oclIsTypeOf(Texte) ]
<p class="texte">[aDiv.oclAsType(Texte).texte /]</p>
[/if]
[if aDiv.oclIsTypeOf(Lien) ]
<a href="aDiv.oclAsType(Lien).adresse">[aDiv.oclAsType(Lien).libelle/]</a>
[/if]
[/for]
Thanks for your help, and sorry for my english (I'm french)..
Re: How to use generic types with for sequence? [message #986870 is a reply to message #986838] Thu, 22 November 2012 03:01 Go to previous messageGo to next message
Having a common superclass would be the easiest way, but you can also do through ifs :
[for (aDiv: EObject | aContenu.eContents())]
  [if (aDiv.oclIsKindOf(Rubrique) or aDiv.oclIsKindOf(AnotherType) or ...]
    generate this
  [/if]
[/for]
Laurent Goubet
Obeo
Re: How to use generic types with for sequence? [message #986940 is a reply to message #986870] Thu, 22 November 2012 07:52 Go to previous messageGo to next message
Thanks for your reply.
I tried with EObject as generic type but it says me "Invalid Type: EObject" and it fails at the compilation.
I also tried with T and OclAny which didn't show any advertissement but which also fails at the compilation time with the following message:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Invalid type for iteration at line 24 in Module generateHtml for block for (aContenu.eContents()). site.impl.TexteImpl was not an instanceof T.
Re: How to use generic types with for sequence? [message #986988 is a reply to message #986940] Thu, 22 November 2012 12:24 Go to previous messageGo to next message
OCL has yet to be fully aligned with UML 2.x and so there is no support
for generic types; consequently there is no support for generic types in
Acceleo.
In the Ecore-based version of Eclipse OCL, "T" and "T1" are magic
non-types used for declaration purposes of e.g. Set(T) which looks like
but is not a UML templated type. Their specified semantics is unclear.
Don't expect them to do anything useful for you.
The new Pivot-based version of Eclipse OCL prototypes a variety of UML
alignment resolutions including support for generic types. "T" and "T1"
are no longer magic, they are just the names of declared template
parameters.
Ed Willink
Re: How to use generic types with for sequence? [message #987047 is a reply to message #986988] Fri, 23 November 2012 02:57 Go to previous message
Florian,
T is a non-existing type and should not be used, Ed explained that better than I could.
You have to use an existing type for the loop variable, and the best choice when you have no common-supertypes is EObject. If it is not recognized as-is by OCL, use its qualified name :
[for (aDiv: ecore::EObject | aContenu.eContents())]
    generate this
  [/if]
[/for]
Laurent Goubet
Obeo
Previous Topic:[Acceleo] EMTL files not contained in build
Next Topic:EMFT JET Transformation Project Error: Could not load JET template loader
Current Time: Thu Jul 31 03:54:45 EDT 2025
Powered by FUDForum. Page generated in 0.45622 seconds
