Home » Modeling » EMF » Customizing saving Model to XMI via XMISaveImpl options
Customizing saving Model to XMI via XMISaveImpl options [message #986938] Thu, 22 November 2012 07:44 Go to next message
Is there any possibility to extract model to XMI file with the following option:
<root>
  <box xmi:type="mymodel:Box" xmi:id="_123wefwefwjefgeg" name="GreatBox">
    <title>_k84xEzSoEeKTvczlP0YbOQ</title>
  </box>
</root>
<title xmi:id="_k84xEzSoEeKTvczlP0YbOQ" name="SomeTitle" elementType="NORMAL"/>
Instead of the following:
<root>
  <box xmi:type="mymodel:Box" xmi:id="_123wefwefwjefgeg" name="GreatBox" title="_k84xEzSoEeKTvczlP0YbOQ"/>
</root>
I tried to play with Containment option of Box.title attr in Ecore model, but it seem's that I need to extends XMISaveImpl and change smth there.
Re: Customizing saving Model to XMI via XMISaveImpl options [message #986973 is a reply to message #986938] Thu, 22 November 2012 10:56 Go to previous messageGo to next message
Add an annotation to your Box::title attribute in the Ecore model as follows:
source: http:///org/eclipse/emf/ecore/util/ExtendedMetaData
detail: kind -> element
Christian
> following option:
> <root>
> </box>
> </root>
> <root>
> </root>
> there.
Re: Customizing saving Model to XMI via XMISaveImpl options [message #986975 is a reply to message #986973] Thu, 22 November 2012 11:22 Go to previous messageGo to next message
Can you be more specific?
Smth like this: http://habrastorage.org/storage2/171/efe/84c/171efe84cee2616ede4ea4c2a0633c72.png
Here, some Base class comprises semanticElement:SemanticElement attribute to which I added annotation.
Re: Customizing saving Model to XMI via XMISaveImpl options [message #986984 is a reply to message #986975] Thu, 22 November 2012 12:13 Go to previous messageGo to next message
Alexander,
Create an EAnnotation on the "title" EReference in your Ecore model as
Christian outlined and use XMLResource.OPTION_EXTENDED_METADATA mapped
to Boolean.TRUE in your save options map (or set save options in your
resource factory where you create your resource).
On 22/11/2012 5:22 PM, Alexander Unsonamed wrote:
> Smth like this: Here, some Base class comprises
Re: Customizing saving Model to XMI via XMISaveImpl options [message #987041 is a reply to message #986984] Fri, 23 November 2012 02:05 Go to previous messageGo to next message
Hi Ed,
> "use XMLResource.OPTION_EXTENDED_METADATA mapped
to Boolean.TRUE in your save options map" - done
> "Create an EAnnotation on the "title" EReference in your Ecore model as
Christian outlined"
I don't understand how to do that:
1. I added new child to "title" -> Eannotation
2. In the "Properties" view of "title" attr, we have only two properties:
- References: I set it's value to "title:Title"
- Source: I set it's value to http:///org/eclipse/emf/ecore/util/ExtendedMetaData
After reloading genmodel and regenerating Model Code nothing changes.
Re: Customizing saving Model to XMI via XMISaveImpl options [message #987042 is a reply to message #987041] Fri, 23 November 2012 02:23 Go to previous messageGo to next message
Alexander,
Comments below.
On 23/11/2012 8:05 AM, Alexander Unsonamed wrote:
> Hi Ed,
> Christian outlined"
Don't do that.
Yes.
And then create a "Details Entry" under the EAnnotation to hold the
key-value pair.
How do you detect changes? I'd expect the generate XyzPackageImpl to
change because of the annotation, but it's easy not to notice that. That
information is used by the serializer when you direct it to look at such
annotations via that save option.
Re: Customizing saving Model to XMI via XMISaveImpl options [message #987088 is a reply to message #987042] Fri, 23 November 2012 06:44 Go to previous message
Ed,
Thank you, again.
That works perfectly.
Previous Topic:[CDO/SWT.Virtual] Virtual tables and CDOPrefetch
Next Topic:getting editing domain from resource set
Current Time: Mon Oct 27 17:41:15 EDT 2025
Powered by FUDForum. Page generated in 0.06920 seconds
