Home » Modeling » Papyrus » programmatic generation of diagrams
programmatic generation of diagrams [message #986703] Wed, 21 November 2012 06:45 Go to next message
Is there any way to programmatically use the diagram generator?
Where may I find the diagram generator interfaces?
Re: programmatic generation of diagrams [message #986731 is a reply to message #986703] Wed, 21 November 2012 08:27 Go to previous messageGo to next message
what is your plan? Do you want to create completely new diagrams or do you want to update existing diagrams according to e.g. your programmatically triggered model changes? If the latter is true and you want to update simple layouted diagrams like class diagrams, consider to install a canonial edit policy for the edit parts.
Re: programmatic generation of diagrams [message #986736 is a reply to message #986731] Wed, 21 November 2012 08:47 Go to previous messageGo to next message
The question is quite interesting. I actually have both the needs.
Thus I need to know what API to exploit when I need to create a completely new set of diagrams (i.e. an just generated model from a QVT-O transformation), and, how to install a "canonical edit policy" for the parts to edit in case of diagram update.
Thanks for your kind help
Re: programmatic generation of diagrams [message #986964 is a reply to message #986736] Thu, 22 November 2012 10:15 Go to previous messageGo to next message
Any Idea?
Re: programmatic generation of diagrams [message #987721 is a reply to message #986964] Tue, 27 November 2012 13:03 Go to previous message
I guess the canonial edit policy should works per default because it comes with gmf. this means if you e.g. create a new class programmatically a graphical node should be created accordingly (BTW: are you planning to use a QVTo transformation to update the UML model?)
Since I've never used the diagram generation component, I cannot tell you how to use it programmatically. I think you should take a look into the projects in [branches/0.9.X/]extraplugins/diagramtemplate/* of the papyrus svn. I think these are the projects which are responsible for diagram generation.
Previous Topic:How to create a new Papyrus UML diagram
Next Topic:how to add variables to a transition in StateMachine Diagram?
Current Time: Thu Jul 24 21:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.48556 seconds
