Home » Eclipse Projects » Remote Application Platform (RAP) » RWT meets Grails
RWT meets Grails [message #986221] Mon, 19 November 2012 08:57 Go to next message
I'd like to introduce a small plugin that I've been working on recently.
When I have to develop desktop-like interfaces with Grails, I was always missing the nice API and widgets that RAP provides with RWT. After playing around with RWT standalone, I tried to get RWT running in a Grails application. Thanks to the nice and decoupled design of RWT, it was actually pretty easy to get things going. To simplify things even more, I created a Grails plugin that seamlessly integrates RWT to be used as the UI layer.
I think this makes a very powerful combination that enables you to:
  • use the Groovy language to build your RWT applications.
  • use the powerful features that the full-stack Grails web-framework offers, like the very nice Domain/Hibernate layer (GORM), dependency injection, testing facilities, convention over configuration, deployment, and so on...
  • use the RWT API and the server-side centric UI architecture (no pain with DTOs/marshalling, cross-compiling code, etc.).
  • simplify the RWT setup and configuration.
The RAP developers really did a great job with RWT and for several reasons I think it has significant advantages over other web UI libraries in certain use-cases. I'd would really love to see RWT gaining some more traction in the Grails community.
So if you can't use the full RAP stack for some reason and want to try RWT standalone you might want to give the Grails-RWT combination a try!
The plugin and documentation is available here: http://grails.org/plugin/rwt
Get acquainted with Grails: http://grails.org/
Being a first release, there are some things I'm planning to improve in the future for the plugin. I'm also always interested to here your feedback and ideas!
Have fun experimenting! Smile
Ben
P.S: There is a depdencency resolution issue where I could use some help from the RAP community. Usually, dependency jars are defined in a maven-like manner in Grails applications. The jars are then resolved and downloaded from a pre-configured public maven repo. Since I'm using some features provided in the RWT 2.x branch, I'm using the latest RWT 2.0 milestone. Unfortunately, I didn't find any public maven repo that provides the RAP 2.0 milestone bundles. Therefore, I have to package the RWT dependencies within the Grails plugin, which is not a nice solution. It is not possible to configure the RWT version to be used and when a new RWT version is released I have to release a new plugin version. If there are plans to provide the RWT bundles (at least everything that's required for RWT standalone) in a public maven repo, it could really improve this situation Smile.
Re: RWT meets Grails [message #986531 is a reply to message #986221] Tue, 20 November 2012 13:37 Go to previous messageGo to next message
Ben
I am happy to see RWT running on/with yet another technology. Thanks so
much for your effort and making the result available.
Regarding your dependency issue: there are release builds available from
Maven Central [1], you'll find RWT 1.5 there. I know that there were
plans to also publish milestone builds on a maven repository but I don't
know the current state of this effort.
As I couldn't find an enhancement request, I'd suggest to open one.
Best,
Rüdiger
[1] http://search.maven.org/#search%7Cga%7C1%7Crwt
On 19.11.2012 14:57, Benjamin Wolff wrote:> I'd like to introduce a
> feedback and ideas!
> Have fun experimenting! :)
> Cheers,
> Ben
> improve this situation :).
Rüdiger Herrmann
http://codeaffine.com
Re: RWT meets Grails [message #986669 is a reply to message #986531] Wed, 21 November 2012 05:36 Go to previous messageGo to next message
Hi Ben,
these are great news, thank you for sharing your work! Do you plan to
publish a little tutorial or blog post somewhere? If so, let us know so
that we can link to it from our website.
Regarding Maven: our build infrastructure creates only p2 repositories
and publishing our artifacts to a public Maven repository involves some
manual steps. That's why we currently only go through this process for
release versions. RAP 2.0 will be released and also published to Maven
Central in February.
I hope we can streamline the process and if it helps, we'll consider
publishing also milestone builds. As Rüdiger said, a bug would be
helpful to discuss this.
Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: RWT meets Grails [message #986687 is a reply to message #986669] Wed, 21 November 2012 06:16 Go to previous messageGo to next message
Hi Rüdiger, Hi Ralf,
thanks for your appreciations! Wink
I would really like to post a small tutorial that includes all necessary steps, including setting up Grails for those who are not yet familiar with it, or at least link to a good setup tutorial, as there are already plenty good ones. Unfortunately, I don't have a blog or something. I could create one that you could put in your blog, if you tell me which blog software and markup you use? Alternatively I could extend the project documentation on GitHub with a full tutorial instead of just a "Getting Started". It might also be nice to mention/link this in the RWT standalone FAQ.
Regarding the maven availability, I will file a bug (against RAP?) to track the issue. If only the major releases will be available via maven than that would also be ok. I could release a new version on February that would change from packaged jars to a maven dependency configuration. But having the possibility to use the bleeding edge milestones by simply change the configuration would be nice, as I often use the milestones in production if they turn out to be stable enough. However, another problem is the availability of the eclipse.core and eclipse.equinox jars required for RWT standalone. There are only hopelessly outdated versions available in the public maven repos, if any at all...
Ben
Re: RWT meets Grails [message #986779 is a reply to message #986687] Wed, 21 November 2012 10:35 Go to previous messageGo to next message
Hi Ben,
I've missed your documentation on Github [1] which seems pretty
sufficient to get started. I'm not sure if our blog supports guest
authors, but If you don't mind, I'll simply introduce your plug-in in a
short blog post, based on the information in this thread, and point to
your site. Of course, if you have any additional information that you'd
like to be mentioned, let me know.
yes, against RAP.
There is component in the RAP incubator that might be useful to you.
It's called osgi-packaging [2] and it creates a RAP feature for Apache
Karaf in a nightly build [3]. If you download the .kar file and extract
it (it's a zip file), it contains a complete Maven repository with rwt,
jface, and the necessary dependencies.
Cheers, Ralf
[1] http://bwolff.github.com/grails-rwt/
[2]
http://git.eclipse.org/c/rap/incubator/org.eclipse.rap.incubator.osgi-packaging.git/
[3] https://hudson.eclipse.org/hudson/job/rap-2.0-incubator-osgi-packaging/
Ralf Sternberg
Re: RWT meets Grails [message #989037 is a reply to message #986779] Tue, 04 December 2012 06:29 Go to previous messageGo to next message
Hi Ralf,
thank you very much for your announcement in your blog! Also, the logo is really cool! Wink
I just wanted to point to your blog post here: http://eclipsesource.com/blogs/2012/11/28/rap-on-grails
Ben
Re: RWT meets Grails [message #1065627 is a reply to message #986221] Wed, 26 June 2013 14:36 Go to previous message
Dear Community,
I'd like to announce the release of the Grails RWT plugin version 1.0.
The release is based on the freshly released RAP/RWT version 2.1 and I also invested quite some time to polish the documentation, which is available here: http://bwolff.github.io/grails-rwt/
The plugin now supports easy configuration of most of the RWT standalone application aspects. Please have a look at the documentation for all features and how to use it.
Feel free to check it out on the Grails plugin central: http://grails.org/plugin/rwt
Big thanks again to the RAP team for a great product and also for their support!
Ben
Previous Topic:RAP Browser-Widget Cross-Domain
Next Topic:HelloWord: The parameter 'path' must not be null
Current Time: Wed Jul 23 06:51:47 EDT 2025
Powered by FUDForum. Page generated in 0.07779 seconds
