Home » Eclipse Projects » Virgo » Write log message in a single file - virgo - common - logging
Write log message in a single file - virgo - common - logging [message #986141] Mon, 19 November 2012 03:14 Go to next message
Dear Experts,
I am logging by importing the package "org.apache.commons.logging" of Virgo.
Log logger = LogFactory.getLog(Activator.class);
logger.info("start Bundle");
It's OK
But my log will be generated in the same file with the Virgo server (\serviceability\logs\log.log).
I do not want to use the same file with Virgo server, It's hard to find my messages.
How can I configure this logger to use another file? It's possible ?
Thanks so much!
Re: Write log message in a single file - virgo - common - logging [message #986437 is a reply to message #986141] Tue, 20 November 2012 07:19 Go to previous messageGo to next message
The logs should be generated in serviceability/logs/<application name>/log.log, so it shouldn't be too hard to find just your own logs.
You can check the User Guide - 13.3 Configuring Serviceability and Diagnostics for more information on how and where to add your custom configuration if this is not what you want.
Hristo Iliev
Re: Write log message in a single file - virgo - common - logging [message #986592 is a reply to message #986437] Wed, 21 November 2012 01:30 Go to previous message
Hi Hristo,
Thanks for your instruction.
I can resolve my problem now.
It just only adds a new appender and logger in serviceability.xml file
Previous Topic:Exception when trying to use spring namespace handler in virgo
Next Topic:Spring framework 3.2.0.RC1 available for testing with Virgo
Current Time: Fri Jul 25 11:40:32 EDT 2025
Powered by FUDForum. Page generated in 0.37030 seconds
