Home » Newcomers » Newcomers » Eclipse suddenly refuses to open
Eclipse suddenly refuses to open [message #986575] Tue, 20 November 2012 21:32 Go to next message
I get the following error:
Error below. Does anyone know why this is happening?
An error has occurred. See the log file /Users/Christian/Dropbox/Projects/Java Projects/.metadata/.log.
And here's the log file's contents:
!SESSION 2012-10-07 11:31:23.698 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.6.0_35
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/Christian/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -keyring /Users/Christian/.eclipse_keyring -showlocation
This is a continuation of log file /Users/Christian/Dropbox/Projects/Java Projects/.metadata/.bak_0.log
Created Time: 2012-10-07 17:11:53.710
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 17:11:53.710
!MESSAGE
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:276)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:494)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:545)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:366)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:313)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1072)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4133)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1495)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1491)
at org.eclipse.swt.widgets.Canvas.sendKeyEvent(Canvas.java:493)
at org.eclipse.swt.widgets.Control.doCommandBySelector(Control.java:1060)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5585)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSResponder.interpretKeyEvents(NSResponder.java:68)
at org.eclipse.swt.widgets.Composite.keyDown(Composite.java:587)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5495)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:221)
at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2102)
at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2284)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5557)
at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:5002)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5151)
at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3616)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:775)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:569)
at org.eclipse.swt.widgets.Text.paste(Text.java:1409)
at org.eclipse.ui.internal.quickaccess.SearchField$12.execute(SearchField.java:286)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.GeneratedMethodAccessor25.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 17:18:12.047
!MESSAGE
!STACK 0
at org.eclipse.swt.widgets.Text.selectAll(Text.java:1586)
at org.eclipse.ui.internal.quickaccess.SearchField$9.execute(SearchField.java:268)
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 17:18:12.679
!MESSAGE
!STACK 0
... 57 more
!SESSION 2012-10-07 17:22:17.518 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-07 17:22:24.387
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-07 17:22:24.843
!MESSAGE CSS property 'selected-tab-fill' has been deprecated: renamed as selected-tab-fill
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 20:01:20.356
!MESSAGE
!STACK 0
at org.eclipse.swt.widgets.Text.copy(Text.java:486)
at org.eclipse.ui.internal.quickaccess.SearchField$11.execute(SearchField.java:280)
at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 20:52:43.681
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 20:52:48.712
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 21:26:32.916
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 23:13:01.791
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 23:13:02.775
!MESSAGE
!STACK 0
... 57 more
!SESSION 2012-10-07 23:31:59.670 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-07 23:32:05.810
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-07 23:32:06.273
!SESSION 2012-10-08 15:48:18.356 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-08 15:48:24.125
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-08 15:48:24.617
!SESSION 2012-10-14 19:06:52.136 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-14 19:06:58.422
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-14 19:06:58.866
!SESSION 2012-10-14 22:16:26.934 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-14 22:16:33.042
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-14 22:16:33.512
!ENTRY org.eclipse.jface.text 4 0 2012-10-14 22:21:39.287
!MESSAGE Unexpected runtime error while computing a text hover
!STACK 0
at org.eclipse.jdt.internal.corext.codemanipulation.StubUtility.getLineDelimiterUsed(StubUtility.java:823)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaSourceHover.getBracketHoverInfo(JavaSourceHover.java:141)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaSourceHover.getHoverInfo(JavaSourceHover.java:96)
at org.eclipse.jdt.internal.ui.text.java.hover.AbstractJavaEditorTextHover.getHoverInfo2(AbstractJavaEditorTextHover.java:84)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:163)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:129)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaEditorTextHoverProxy.getHoverInfo2(JavaEditorTextHoverProxy.java:85)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextViewerHoverManager.java:166)
!SESSION 2012-10-15 21:28:56.629 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-15 21:29:06.863
!SESSION 2012-10-17 22:05:30.332 -----------------------------------
Re: Eclipse suddenly refuses to open [message #986767 is a reply to message #986575] Wed, 21 November 2012 10:10 Go to previous messageGo to next message
Are you trying to share your workspace using Dropbox? This is not
supported and is the possible cause of your problem. Workspaces aren't
meant to be shared. You should only share projects. Try starting with
a clean workspace and import the projects from their current location.
Re: Eclipse suddenly refuses to open [message #986802 is a reply to message #986767] Wed, 21 November 2012 11:59 Go to previous messageGo to next message
No, I'm not. But how do I create a new workplace if Eclipse won't even open?
Re: Eclipse suddenly refuses to open [message #986805 is a reply to message #986802] Wed, 21 November 2012 12:11 Go to previous message
Fixed it, removed the preferences folder in Configuration folder.
Previous Topic:How to setup stepping(?) so I can see what code is executing when.
Next Topic:style-id for list a content on the welcome page
Current Time: Mon Jul 21 11:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.07797 seconds
