Home » Modeling » TMF (Xtext) » Model serialization is very slow(When trying to serialize a EMF model using XtextResource, It takes a huge amount of time)
Model serialization is very slow [message #986393] Tue, 20 November 2012 05:22 Go to next message
I have a problem with the serialization of a EMF model using a XtextResource.
I have generated a Xtext project from an Ecore file.
I have an instance model of 233 objects, which is not that big (imho).
But when I try to serialize it using the XtextResource, I have the impression that the process is stuck in an infinite loop, or at least it is very slow: ~15 minutes
I've paused the process and it seems to be looping in the method
public abstract class AbstractParseTreeConstructor implements IParseTreeConstructor {
   protected AbstractToken serialize(EObject object, AbstractToken currentToken, TreeConstructionReportImpl rep){
I have no idea on how to debug it and improve the serialization process.
I could use a little help here.
In advance, thank you for your comments/remarks.
Charles
[Updated on: Tue, 20 November 2012 05:59] by Moderator
Re: Model serialization is very slow [message #986414 is a reply to message #986393] Tue, 20 November 2012 06:02 Go to previous messageGo to next message
Charles, what version of Xtext are you using? Are you aware that there are two Serializer implementations in Xtext, an old/slower and newer/faster one? Browse some older Forum posts for more about this.. If you created your project with an older version and then later switched to a newer one, you're probably still using the older implementation? To switch, create a new sample test project with the Xtext (latest 2.3.1), and note how in the new *.mwe2 there is a // Serializer 2.0 fragment = serializer.SerializerFragment ... add that to your existing *.mwe2, regenerate - perf any better? Now retest everything... Wink
Re: Model serialization is very slow [message #986431 is a reply to message #986414] Tue, 20 November 2012 07:15 Go to previous messageGo to next message
I'm using Xtext 2.3.0. I'll try with the latest version. I'll let you know. Thank you very much.
Re: Model serialization is very slow [message #1007092 is a reply to message #986431] Mon, 04 February 2013 07:14 Go to previous message
Huge improvement ! thanks a lot !!!!
Br,
Charles
Previous Topic:[Xbase] LValue-like expressions in DSL
Next Topic:Infinite loop when refreshing the outline
Current Time: Fri Jul 25 08:45:58 EDT 2025
Powered by FUDForum. Page generated in 0.07327 seconds
