Home » Modeling » EMF » [CDO] Server in non-OSGi environment
[CDO] Server in non-OSGi environment [message #986376] Tue, 20 November 2012 04:38 Go to next message
I am trying to start a CDO 4.1 server in a non-OSGi environment and ran into a couple of issues.
I initialise my server container as follows:
IManagedContainer repositoryContainer = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(repositoryContainer);
TCPUtil.prepareContainer(repositoryContainer);
JVMUtil.prepareContainer(repositoryContainer);
CDONet4jServerUtil.prepareContainer(repositoryContainer);
OCLQueryHandler.prepareContainer(repositoryContainer);
LifecycleUtil.activate(repositoryContainer);
I am using a H2 db store with no audit and no branching enabled.
When starting the server for the first time I get the following exception:
java.lang.UnsupportedOperationException
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave(ResourceImpl.java:1449)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1417)
	at org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EMFUtil.java:276)
	at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getEPackageBytes(MetaDataManager.java:221)
	at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:248)
	at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:291)
	at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.writePackageUnits(MetaDataManager.java:138)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writePackageUnits(DBStoreAccessor.java:822)
	at org.eclipse.emf.cdo.internal.server.Repository.initSystemPackages(Repository.java:1669)
	at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1864)
Do I have to initialise EMF in some way which would normally be done by the Equinox Extenstion Registry?
The second thing I do not understand is, why I need the following two jars if I am in a non-OSGi environment:
org.eclipse.equinox.common
org.eclipse.equinox.registry
Maybe that is related to the fact that the class org.eclipse.emf.cdo.server.internal.db.mapping.TypeMappingRegistry always
returns an instance of IPluginContainer as its container. I thought it should use the managed container that is used to create the repository ("repositoryContainer" in my example above).
  protected IManagedContainer getContainer()
    return IPluginContainer.INSTANCE;
Jan
Re: [CDO] Server in non-OSGi environment [message #986386 is a reply to message #986376] Tue, 20 November 2012 05:03 Go to previous messageGo to next message
Am 20.11.2012 10:38, schrieb Jan Rosczak:
It's usually easier to prepare IPluginContainer.INSTANCE because many components use that by default, e.g., the
TypeMappingRegistry.
Are you sure that you've deployed org.eclipse.emf.ecore.xmi and org.eclipse.emf.ecore.change properly?
That's most likely because we expose some Platform interfaces, e.g., IAdaptable or IProgressMonitor.
> always
See above.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Server in non-OSGi environment [message #986390 is a reply to message #986386] Tue, 20 November 2012 05:13 Go to previous messageGo to next message
I was missing org.eclipse.emf.ecore.xmi. Now it works and I will refactor my code to use IPluginContainer.INSTANCE.
Jan
Re: [CDO] Server in non-OSGi environment [message #986405 is a reply to message #986390] Tue, 20 November 2012 05:39 Go to previous message
Am 20.11.2012 11:13, schrieb Jan Rosczak:
Excellent ;-)
Cheers
/Eike
Previous Topic:[CDO] CDOResource name equal
Next Topic:emf.sdk feature on Kepler milestone ?
Current Time: Thu Jul 24 22:55:03 EDT 2025
Powered by FUDForum. Page generated in 1.09697 seconds
