Home » Eclipse Projects » EGit / JGit » Build cloned files ? Build button grayed out...
Build cloned files ? Build button grayed out... [message #986288] Mon, 19 November 2012 13:20 Go to next message
Hi everyone.
Just a small problem I have after finaly achieving to clone a project from gitorious.
Now that the project is showing up on eclipse and i can navigate to its source files, I can't build it. The build button on the taskbar is grayed out.
Is there something I am missing here ?
Thanks in advance
Re: Build cloned files ? Build button grayed out... [message #986343 is a reply to message #986288] Tue, 20 November 2012 02:31 Go to previous messageGo to next message
How is this question related to EGit ? Also we don't know which project you are talking about.
Re: Build cloned files ? Build button grayed out... [message #986366 is a reply to message #986288] Tue, 20 November 2012 04:12 Go to previous messageGo to next message
On 19.11.2012 19:20, george bakir wrote:
> Hi everyone.
> from gitorious.
> grayed out. Is there something I am missing here ?
Most likely you have 'Build Automatically' enabled and everything is
already built.
Dani
> Thanks in advance
Re: Build cloned files ? Build button grayed out... [message #986714 is a reply to message #986288] Wed, 21 November 2012 07:30 Go to previous messageGo to next message
It's just a basic openGL project for my uni, but I don't think that matters.
Could you please give me a basic guide on how to clone a project using eclipse ?
Alos I don't think it's already built as when I got to run, it says that the have not been any previous launcehs.
Not even sure if I coned it properly.
Thanks!
Re: Build cloned files ? Build button grayed out... [message #987052 is a reply to message #986714] Fri, 23 November 2012 03:16 Go to previous messageGo to next message
Did you have a look at this: http://wiki.eclipse.org/EGit/User_Guide#Starting_the_import_wizard ?
Re: Build cloned files ? Build button grayed out... [message #987215 is a reply to message #986288] Sat, 24 November 2012 09:49 Go to previous messageGo to next message
Hi again!
I must be using a newer version than the one on the tutorial.
There is no add / clone button on mine as apparently this proccess is beeing done automatically on my version.
Re: Build cloned files ? Build button grayed out... [message #987350 is a reply to message #987215] Mon, 26 November 2012 04:18 Go to previous messageGo to next message
Ok, you're right, the documentation is outdated here. But the steps afterwards haven't changed. So you can clone the repository and import the projects with the Wizard. Do you see afterwards
- the repository in the Git Repositories View
- the project in eclipse with the git decorations?
- The history of the project in the History View (Team > Show in History)
Re: Build cloned files ? Build button grayed out... [message #987948 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
here's a picture of what i see: index.php/fa/12534/0/
still can't build...
  • Attachment: Git clone.png
    (Size: 100.27KB, Downloaded 855 times)
Re: Build cloned files ? Build button grayed out... [message #987966 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 30 November 2012 12:10] by Moderator
Re: Build cloned files ? Build button grayed out... [message #987978 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 30 November 2012 12:15] by Moderator
Re: Build cloned files ? Build button grayed out... [message #987992 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988007 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988024 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988041 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 30 November 2012 12:14] by Moderator
Re: Build cloned files ? Build button grayed out... [message #988058 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 30 November 2012 12:13] by Moderator
Re: Build cloned files ? Build button grayed out... [message #988076 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988097 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988115 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988139 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988161 is a reply to message #987350] Wed, 28 November 2012 12:21 Go to previous messageGo to next message
No Message Body
Re: Build cloned files ? Build button grayed out... [message #988364 is a reply to message #987948] Thu, 29 November 2012 10:32 Go to previous message
It looks like egit has correctly cloned the repo and imported the project. You should ask the question on the forum which covers the type of your projects.
Previous Topic:Eclipse editor features stop working
Next Topic:Unable to use key file SSH
Current Time: Wed Jul 23 12:24:01 EDT 2025
Powered by FUDForum. Page generated in 0.11244 seconds
