Home » Newcomers » Newcomers » Changed to C99 mode and now I have " 'asm' undeclared" errors(Error with 'asm' using C99 mode. )
Changed to C99 mode and now I have " 'asm' undeclared" errors [message #986117] Sun, 18 November 2012 20:58 Go to next message
I'm currently changing some C++ code over to C syntax, I ran into for loops not be able to run unless it was C99 mode so I changed that. All the for loop errors went away but now I have 'asm' undeclared errors. Any suggestions?
Thanks.
Re: Changed to C99 mode and now I have " 'asm' undeclared" errors [message #986123 is a reply to message #986117] Mon, 19 November 2012 00:04 Go to previous messageGo to next message
I got this working correctly now. I found the "asm" that was giving me trouble and tried it with "__asm" and it worked. I don't understand why but hopefully that helps others.
Re: Changed to C99 mode and now I have " 'asm' undeclared" errors [message #986280 is a reply to message #986117] Mon, 19 November 2012 12:20 Go to previous message
> Any suggestions?
> Thanks.
http://www.eclipse.org/forums/index.php/t/161206/
Previous Topic:PyDev Djando debug configuration fails to import settings
Next Topic:Eclipse not starting on Mac OS X Lion
Current Time: Sun Aug 31 08:24:15 EDT 2025
Powered by FUDForum. Page generated in 0.18348 seconds
