Home » Archived » BIRT » Cannot install Birt on Eclipse 4.2.1 Juno(Unable to install Birt on Eclipse 4.3.1 Juno - Win7)
Cannot install Birt on Eclipse 4.2.1 Juno [message #986115] Sun, 18 November 2012 18:47 Go to next message
I downloaded the zip.
I followed the directions by creating a link file.
Nothing.
I then copied the files directly into the eclipse folder's plugins and features directories.
Nothing.
How exactly do you install Birt on Eclipse Juno 4.2.1?
Thanks.
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #986260 is a reply to message #986115] Mon, 19 November 2012 11:29 Go to previous messageGo to next message
Can use, the install software feature of eclipse by getting the update site link on the birt project page.
best regards, Patrick.
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #986273 is a reply to message #986260] Mon, 19 November 2012 11:52 Go to previous messageGo to next message
I searched for that - hoping it would be easy to find.
If you have it - please send to me.
I was unable to find it.
Thanks.
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #986275 is a reply to message #986273] Mon, 19 November 2012 12:02 Go to previous messageGo to next message
I think I found 3.7 - so I used 4.2 in the link section.
http://download.eclipse.org/birt/update-site/4.2
Seems to be working!
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #986284 is a reply to message #986275] Mon, 19 November 2012 12:45 Go to previous messageGo to next message
normally this way is the best and easy way
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #997265 is a reply to message #986284] Fri, 04 January 2013 15:14 Go to previous messageGo to next message
I am trying to install birt 4 on my eclipse 4 from this url
and it can't find anything. It says "There are no items available". Someone can help?
Or maybe some other way to install it?
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #997283 is a reply to message #997265] Fri, 04 January 2013 16:57 Go to previous messageGo to next message
You could try downloading the designer plugins from the main download page:
Eclipse BIRT - 4.2.1 Download Page
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #997596 is a reply to message #997283] Tue, 08 January 2013 09:12 Go to previous messageGo to next message
Thanks for the repling. I managed to install.
But i've got another problem.
I created a report and it works fine via Preview. I used a code from Voggela's site. Here's my open script:
count = 0;
importPackage(Packages.org.eclipse.core.runtime);
// Create instance of
// the GetStockHistory class
//gsh = new Packages.daomock.StockDaoMock();
importPackage(Packages.daomock);
gsh = new StockDaoMock();
//Load the List
stock = gsh.getStockValues("Java");
and here's my code:
Browser browser = new Browser( parent, SWT.NONE );
HashMap<String,String> myparms = new HashMap<String,String>();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
myparms.put("ALLOW_PAGE", "false");
myparms.put("MAX_ROWS_KEY", "500");
Bundle bundle = org.eclipse.core.runtime.Platform.getBundle("com.investflex.rcp.riskcontrol");
URL url = FileLocator.find(bundle, new Path("birt.rptdesign"), null);
String rpt = "";
try
rpt = FileLocator.toFileURL(url).getPath();
} catch (IOException e1) {
e1.printStackTrace();
WebViewer.display(rpt, browser, myparms);
When I start, i got this error:
org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "count = 0;
//Load the List
stock = gsh.getStockValues("Java"); ":
Fail to execute script in function __bm_OPEN(). Source:
" + count = 0;
//Load the List
stock = gsh.getStockValues("Java"); + "
A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: ReferenceError: "StockDaoMock" is not defined. (/report/data-sets/script-data-set[@id="40"]/method[@name="open"]#10)
Script source: /report/data-sets/script-data-set[@id="40"]/method[@name="open"], line: 0, text:
__bm_OPEN(). (Element ID:1)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:99)
at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:256)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:98)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(ScriptDataSetRuntime.java:80)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.java:247)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:223)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1142)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:262)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:119)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:104)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:
" + count = 0;
//Load the List
__bm_OPEN()
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:147)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:90)
... 87 more
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.
__bm_OPEN()
at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:123)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:996)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:138)
... 88 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "StockDaoMock" is not defined. (/report/data-sets/script-data-set[@id="40"]/method[@name="open"]#10)
__bm_OPEN()
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoException(JavascriptEvalUtil.java:303)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:102)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:134)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:992)
... 89 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "StockDaoMock" is not defined. (/report/data-sets/script-data-set[@id="40"]/method[@name="open"]#10)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c5._c1(/report/data-sets/script-data-set[@id="40"]/method[@name="open"]:10)
at org.mozilla.javascript.gen.c5.call(/report/data-sets/script-data-set[@id="40"]/method[@name="open"])
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
at org.mozilla.javascript.gen.c6._c0(/report/data-sets/script-data-set[@id="40"]/method[@name="open"]:0)
at org.mozilla.javascript.gen.c6.call(/report/data-sets/script-data-set[@id="40"]/method[@name="open"])
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.gen.c6.exec(/report/data-sets/script-data-set[@id="40"]/method[@name="open"])
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:95)
... 91 more
org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "if(count < stock.size()){
row["columnDate"] = stock.get(count).getDate();
row["columnOpen"] = stock.get(count).getOpen();
row["columnHigh"] = stock.get(count).getHigh();
row["columnLow"] = stock.get(count).getLow();
row["columnClose"] = stock.get(count).getClose();
row["columnVolume"] = stock.get(count).getVolume();
count++;
return true;
return false; ":
Fail to execute script in function __bm_FETCH(). Source:
" + if(count < stock.size()){
count++;
return true;
return false; + "
Error evaluating Javascript expression. Script engine error: ReferenceError: "stock" is not defined. (/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"]#1)
Script source: /report/data-sets/script-data-set[@id="40"]/method[@name="fetch"], line: 0, text:
__bm_FETCH(). (Element ID:1)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:143)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch(ScriptDataSetRuntime.java:103)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery.java:260)
at org.eclipse.birt.data.engine.executor.dscache.DataSetToCache.fetchFromDataSet(DataSetToCache.java:242)
at org.eclipse.birt.data.engine.executor.dscache.DataSetToCache.fetch(DataSetToCache.java:171)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch(OdiAdapter.java:218)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.doNext(RowResultSet.java:113)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.next(RowResultSet.java:91)
at org.eclipse.birt.data.engine.executor.cache.ExpandableRowResultSet.next(ExpandableRowResultSet.java:63)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.populateData(SmartCacheHelper.java:316)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.initInstance(SmartCacheHelper.java:285)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.getResultSetCache(SmartCacheHelper.java:246)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.(SmartCache.java:73)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.populateOdiResultSet(PassUtil.java:132)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:62)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.doSinglePass(PassManager.java:170)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareDataSetResultSet(PassManager.java:94)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateDataSetResultSet(PassManager.java:80)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.cacheDataSet(ResultSetPopulator.java:203)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.(CachedResultSet.java:142)
at org.eclipse.birt.data.engine.executor.CandidateQuery.execute(CandidateQuery.java:160)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:226)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_FETCH(). Source:
count++;
return true;
return false; + "
__bm_FETCH()
... 105 more
__bm_FETCH()
... 106 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "stock" is not defined. (/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"]#1)
__bm_FETCH()
... 107 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "stock" is not defined. (/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"]#1)
at org.mozilla.javascript.gen.c7._c1(/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"]:1)
at org.mozilla.javascript.gen.c7.call(/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c8._c0(/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"]:0)
at org.mozilla.javascript.gen.c8.call(/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c8.exec(/report/data-sets/script-data-set[@id="40"]/method[@name="fetch"])
... 109 more
org.eclipse.birt.report.engine.api.EngineException: Data Set script method "Fetch" returned null; expected a Boolean value. (Element ID:1)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:244)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:233)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:165)
Caused by: org.eclipse.birt.data.engine.core.DataException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:153)
... 103 more
//Load the List
" + count = 0;
//Load the List
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.executeQueries(ExtendedGenerateExecutor.java:205)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.execute(ExtendedGenerateExecutor.java:65)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:62)
" + count = 0;
//Load the List
__bm_OPEN()
... 87 more
__bm_OPEN()
... 88 more
__bm_OPEN()
... 89 more
... 91 more
count++;
return true;
return false; ":
count++;
return true;
return false; + "
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #997871 is a reply to message #997596] Tue, 08 January 2013 17:58 Go to previous messageGo to next message
This the one you followed? Let me know, I'll take a look, in the morning.
http://www.vogella.com/articles/EclipseBIRT/article.html
Re: Cannot install Birt on Eclipse 4.2.1 Juno [message #998105 is a reply to message #997871] Wed, 09 January 2013 06:34 Go to previous message
Yes, that's it. Thank you.
Previous Topic:BIRT Aggregate Extension Example Error!
Next Topic:How to customize bar chart color
Current Time: Wed Jul 23 12:52:25 EDT 2025
Powered by FUDForum. Page generated in 0.28363 seconds
