Home » Eclipse Projects » Remote Application Platform (RAP) » Problems with theming in the WAR-File
Problems with theming in the WAR-File [message #985343] Thu, 15 November 2012 05:20 Go to next message
I've problems theming the version exported as war-File to use it in an external application server (tjws in my case). The program is running fine, as well in the rap's internal appserver (jetty) during running it in eclipse itself.
But it seems that the exported war file ignores my theming settings.
As a sidenote, i need to access it via http:// localhost:8182/stationaer/rap?startup=stationaer, while using eclipse I can use http:// 127.0.0.1:10080/stationaer ...
I tried following:
In the plugin.xml:
<extension
      point="org.eclipse.rap.ui.entrypoint">
   <entrypoint
         class="de.mifritscher.stationaer.rap.EntryPoint"
         id="stationaer.entrypoint1"
         path="/stationaer"
         parameter="stationaer">
   </entrypoint>
</extension>
<extension
      point="org.eclipse.rap.ui.branding">
   <branding
         defaultEntrypointId="stationaer.entrypoint1"
         id="stationaer.branding1"
         servletName="stationaer"
         themeId="stationaer.defaulttheme" <-- (1) changing to the business theme does only work in eclipse+jetty...
         title="Stationaer">
   </branding>
</extension>
<extension
      point="org.eclipse.rap.ui.themes">
   <theme
         file="css/defaulttheme.css"
         id="stationaer.defaulttheme"
         name="Standard">
   </theme>
   <themeContribution
         themeId="org.eclipse.rap.design.example.business.theme">
   </themeContribution>
   <themeContribution
         themeId="org.eclipse.rap.rwt.theme"> <-- (2) the tooltip says that I can use this id to change the default theme, but I get a warning in the eclipse's editor saying that this id doesn't exist
</extension>
build.properties:
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
               META-INF/,\
               libs/,\
               pictures/,\
               html/,\
               css/,\
               ormliteLocalLog.properties,\
               js/
But nor my defaulttheme.css nor trying to use the business theme (1) works. See also (2) - The tooltip says that I can use this id to change the default theme, but I get a warning in the eclipse's editor saying that this id doesn't exist.
What can I do? I'm using RAP 1.5.1 btw.
Re: Problems with theming in the WAR-File [message #985838 is a reply to message #985343] Fri, 16 November 2012 05:29 Go to previous messageGo to next message
Hi Michael,
Here are a few hints, hope they are helpful:
Brandings don't work for entrypoints by path in RAP 1.5 [1]. This
problem has been resolved in RAP 2.0 M3 [2]. If it works for you in
Eclipse, maybe you're using different RAP versions in the IDE and in the
WAR deployment?
BTW, you can add the context path ("/stationaer/") also to your launch
configuration in the IDE to have the same paths as in deployment.
> theme ...
This attibute is used to specify an existing theme to contribute to. At
least in master, the documentation states "the id of the theme this
extension contributes to"
[1] 377424: Hooking an Entrypoint to a branding does not work
https://bugs.eclipse.org/bugs/show_bug.cgi?id=377424
[2] http://eclipse.org/rap/noteworthy/2.0/?build=M3
HTH, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Problems with theming in the WAR-File [message #986199 is a reply to message #985838] Mon, 19 November 2012 07:32 Go to previous messageGo to next message
Hi Ralf,
thanks for the hints - Yes, I had tried 2.0 M2 or 3 some time ago, but removed it. But I'll try 2.0 anyway Wink
>> theme ...
Yes, so the tooltip in eclipse, but it also says that I can use the id "org.eclipse.rap.rwt.theme" as a sort of special ID if I want to change the default theme.
Michael
Re: Problems with theming in the WAR-File [message #986263 is a reply to message #986199] Mon, 19 November 2012 11:39 Go to previous message
Ok, I got it running in 2.0 M3 - I think I missed the extension / application thing a bit. Thanks for the hints!
Previous Topic:require document for deploy rwt standalone to jee container like tomcat or jboss?
Next Topic:CTabFolder strange border
Current Time: Wed Jul 23 06:07:07 EDT 2025
Powered by FUDForum. Page generated in 0.05476 seconds
