service lookup fails with plan based deployment [message #985657] |
Thu, 15 November 2012 10:54  |
In my application I've got a mysql datasource that's deployed in a separate 'infrastructure bundle', and published as a javax.sql.DataSource service. Then a second 'database bundle' uses the service from the other bundle to do some db related stuff. When I deploy both bundles from eclipse everything goes fine (to be on the safe side I wait a bit before deploying the second bundle, so I'm sure the first one is active by then). Now, in deployment mode, I've put both bundles in separate plans, to be able to wait a bit in between activating both plans. The problem is that, no matter how long I wait, the second plan/bundle doesn't find the DataSource service:
[2012-11-15 16:22:35.643] service-monitor-thread-1 <KE0100W> Reference '&dat
aSource' in bundle 'gwf_plan_1b_db-2-com.fugro.gwf.dbmanager' version '1.0.0' is
waiting for service with filter '(objectClass=javax.sql.DataSource)'.
[2012-11-15 16:23:35.648] service-monitor-thread-1 <KE0100W> Reference '&dat
[2012-11-15 16:24:35.653] service-monitor-thread-1 <KE0100W> Reference '&dat
[2012-11-15 16:25:35.658] service-monitor-thread-1 <KE0100W> Reference '&dat
[2012-11-15 16:26:30.449] http-bio-8080-exec-5 <DE0502E> Start of plan '
gwf_plan_1b_db' version '2.0.0' has taken longer than the configured timeout of
'300' seconds.
[2012-11-15 16:26:30.650] ng DM Context Creation Timer <AG0000E> Application con
text creation failure for bundle 'gwf_plan_1b_db-2-com.fugro.gwf.dbmanager' vers
ion '1.0.0'. org.springframework.context.ApplicationContextException: Applicatio
n context initialization for 'gwf_plan_1b_db-2-com.fugro.gwf.dbmanager' has time
d out waiting for (objectClass=javax.sql.DataSource)
Still I can see in the console that the other bundle is ready to offer this service:
osgi> bundle 151
gwf_plan_1_init-2-com.fugro.gwf.infrastructure.mysql_1.0.0 [151]
Id=151, Status=ACTIVE Data Root=C:\programs\virgo-tomcat-server-3.5.0.for_gwf_deployed\work\org.eclipse.osgi\bundles\151\data
"Registered Services"
{javax.sql.DataSource}={org.eclipse.gemini.blueprint.bean.name=dataSource, org.springframework.osgi.bean.name=dataSource, osgi.service.blueprint.compname=dataSource, Bundle-SymbolicName=gwf_plan_1_init-2-com.fugro.gwf.infrastructure.mysql, Bundle-Version=1.0.0, service.id=267}
THE QUESTION: why doesn't plan/bundle 2 just use the available service ?
Re: service lookup fails with plan based deployment [message #986222 is a reply to message #986214] |
Mon, 19 November 2012 08:58  |
Thanks for your feedback, but I was already using that option. My impression is that the plugin tries to make an hybrid between what you feed it with the manifestFile tag, and what it normally would produce without that tag being present. And I suspect there is a bug in the code producing the hybrid (some random sections being dropped, there might be a logic behind what is dropped exactly, but i don't see that logic yet). The workaround with the unzipping-fixing-zipping of the jar seems to work ...
FUDForum. Page generated in 0.12016 seconds
