Home » Newcomers » Newcomers » Java was started but returned exit code=15
Java was started but returned exit code=15 [message #985851] Fri, 16 November 2012 07:04 Go to next message
Hello everybody,
my eclipse stop working... please help me.
  • Attachment: bug.png
    (Size: 88.67KB, Downloaded 694 times)
Re: Java was started but returned exit code=15 [message #985881 is a reply to message #985851] Fri, 16 November 2012 09:41 Go to previous messageGo to next message
On 11/16/2012 07:59 AM, Robert Hahn wrote:
> Hello everybody,
Don't run on the VM at C:\Windows\System32\Java.exe. Explicitly specify
the VM on the command line use the -vm argument or in the eclipse.ini file
Re: Java was started but returned exit code=15 [message #985888 is a reply to message #985881] Fri, 16 November 2012 10:03 Go to previous messageGo to next message
hello David,
thx a lot for your reply.
I was wondering why eclipse stop working suddenly...
I tried a lot of editing eclipse.init but it doesnt work.
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512m
--launcher.defaultAction
openFile
-vm
C:\Program Files\Java\jdk1.6.0_29\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
Re: Java was started but returned exit code=15 [message #985889 is a reply to message #985888] Fri, 16 November 2012 10:10 Go to previous messageGo to next message
On 11/16/2012 8:03 AM, Robert Hahn wrote:
> hello David,
> -startup
> --launcher.library
> -showsplash
> 512m
> openFile
> -vm
> -vmargs
> -Xms40m
> -Xmx512m
That's probably a 32-bit JDK there. Are you running a 64-bit Eclipse?
Re: Java was started but returned exit code=15 [message #985890 is a reply to message #985889] Fri, 16 November 2012 10:12 Go to previous messageGo to next message
Oops, my bad. Ignore that post. The path to a 32-bit JDK would have
started with "Program Files (x86)". (Windows is so far away from me now...)
Re: Java was started but returned exit code=15 [message #985892 is a reply to message #985889] Fri, 16 November 2012 10:23 Go to previous messageGo to next message
eclipse-SDK-4.2-win32-x86_64
Re: Java was started but returned exit code=15 [message #986074 is a reply to message #985892] Sun, 18 November 2012 06:08 Go to previous messageGo to next message
does anaybody have an idea ?
Re: Java was started but returned exit code=15 [message #986079 is a reply to message #986074] Sun, 18 November 2012 08:54 Go to previous messageGo to next message
.log
!SESSION 2012-07-16 14:05:48.170 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Command-line arguments:  -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.ui 2 2 2012-07-16 14:06:50.686
!MESSAGE Invalid property category path: ValidationPropertiesPage (bundle: org.eclipse.wst.xml.ui, propertyPage: org.eclipse.wst.xml.ui.propertyPage.project.validation)
!SESSION 2012-08-31 11:17:12.145 -----------------------------------------------
java.version=1.6.0_29
!ENTRY org.eclipse.ui 2 2 2012-08-31 11:17:30.227
Re: Java was started but returned exit code=15 [message #986140 is a reply to message #986079] Mon, 19 November 2012 03:09 Go to previous messageGo to next message
it would be very helpful if anybody supports me. i am writing my bachelor-thesis at the moment ... so i got no time to loose. thx in advance
Re: Java was started but returned exit code=15 [message #986243 is a reply to message #986140] Mon, 19 November 2012 10:19 Go to previous message
First, make sure that you selected the option to maintain the directory
hierarchy when you extracted the zip file.
The only other thing I can think of is to extract Eclipse into a
location higher up in your file system. Windows has a path limit that
you can run into if you extract Eclipse too far down. Try C:\eclipse.
Previous Topic:Subclipse Problem
Next Topic:how to replace +- icons in eclipse tree view
Current Time: Sat Jul 26 12:55:08 EDT 2025
Powered by FUDForum. Page generated in 0.08706 seconds
