Home » Modeling » TMF (Xtext) » Reusing validation in GMF editor
Reusing validation in GMF editor [message #985996] Sat, 17 November 2012 02:26 Go to next message
Hi all,
I implemented validation constraints for a certain Xtext grammar. Earlier I
had implemented the constraints in Checks and injected them into a GMF
editor using the GMF Check adapter. Now I am trying to reuse the new
validation rules (in the Xtext grammar bundle) within the GMF editor(s). The
problem is that only the default EMF rules are used.
I found some threads and information about how to remove or override the EMF
default rules, for example
http://stackoverflow.com/questions/5861948/changing-default-validation-
messages recommends to add a fragment. My question relates to the other side
of the problem though: Why isn't validation from the Xtext DSL bundle
evaluated, too? I saw that the Xtext-based bundles are loaded in the product
(seen in the "Installed Software" dialog).
Could this behaviour be related to that the GMF editor is not using the
XtextResource yet, but still utilises the GMF Resource Factory? To put it
another way: Is it required to use the XtextResource in order to let
validation become work?
Or is it even required to apply the Xtext-GMF-Glue-Code? I didn't yet
because at the moment I am only using the GMF editor. Textual editor
integration is actually planned for another release.
Thanks for your help,
Axel
Re: Reusing validation in GMF editor [message #985999 is a reply to message #985996] Sat, 17 November 2012 05:32 Go to previous messageGo to next message
The reason is that EMF, even though it offers an extension point to feed
all other registries, does not provide one to feed the EValidator.Registry.
In oAW, where the check adapter comes from, we've built our own EP,
initialized it with an IStartup and wrote the contributed validators
into EMF's registry.
In Xtext we no longer do that, as that is quite an invasive strategy
that could break other EMF clients.
So what you basically have to do is manually adding the validator to the
registry, e.g. when your editor starts.
Am 17.11.12 08:26, schrieb Axel Guckelsberger:
> Hi all,
> Axel
Re: Reusing validation in GMF editor [message #986012 is a reply to message #985999] Sat, 17 November 2012 08:34 Go to previous messageGo to next message
Hey Jan,
thank you for your quick reply which is very helpful.
My misunderstanding was indeed that I assumed Xtext doing the registration
itself (I think I had read this in an earlier post).
Working on it now.
Axel
>> Hi all,
>> I had implemented the constraints in Checks and injected them into a GMF
>> The problem is that only the default EMF rules are used.
>> EMF default rules, for example
>> side of the problem though: Why isn't validation from the Xtext DSL
>> bundle evaluated, too? I saw that the Xtext-based bundles are loaded in
>> the product (seen in the "Installed Software" dialog).
>> Axel
Re: Reusing validation in GMF editor [message #986017 is a reply to message #985999] Sat, 17 November 2012 09:02 Go to previous messageGo to next message
Hi Jan
OCL has the same problem, requiring user installation and hoping that
layering a CompositeEValidator on top of whatever is already installed
won't do too much harm. This is partly to add validation and partly to
add an extended API that supports customizable diagnostics.
Do you think it's time for an EMF EValidator.Registry extension point
that addresses more recent requirements?
Ed Willink
> feed all other registries, does not provide one to feed the
> the registry, e.g. when your editor starts.
>> Hi all,
>> Earlier I
>> editor(s). The
>> the EMF
>> other side
>> product
>> put it
>> Axel
Re: Reusing validation in GMF editor [message #986023 is a reply to message #985999] Sat, 17 November 2012 10:58 Go to previous messageGo to next message
Hi again,
in the meanwhile I wrote the following method:
    private void initValidationRegistry() {
        // unregister default validation rules from EMF
        final EValidator.Registry registry = EValidator.Registry.INSTANCE;
        final EcorePackage ecorePackage = EcorePackage.eINSTANCE;
        if (registry.containsKey(ecorePackage)) {
            registry.remove(ecorePackage);
        // register validator from Xtext bundle
        final MyPackage myPackage = MyPackage.eINSTANCE;
        if (!registry.containsKey(myPackage)) {
            final Injector injector = new MyDslStandaloneSetup()
                    .createInjectorAndDoEMFRegistration();
            final MyDslJavaValidator validator = injector
                    .getInstance(MyDslJavaValidator.class);
            registry.put(myPackage, validator);
        // testing output
        for (final Object v : registry.values()) {
            System.out.println(v.getClass());
It is called at the end of the preWindowOpen() method in the
DiagramEditorWorkbenchWindowAdvisor class.
Without applying this method the test output prints:
- class org.eclipse.emf.ecore.xml.type.impl.XMLTypePackageImpl$1
- class org.eclipse.emf.ecore.impl.EcorePackageImpl$1
- class org.eclipse.xtext.validation.CompositeEValidator
This works fine, the default constraints from Ecore are validated.
After activating the method above I get:
- class org.example.xtext.validation.MyDslJavaValidator
But then all diagram elements are broken. This happens always, even before starting any validation run at all. Also it happens independently of the Ecore package removal.
Is there anything obviously wrong in the initValidationRegistry() method?
I noticed that the CompositeEValidator is gone in the second test output.
Should I add my validator class to it instead of the registry?
Greetings,
Axel
[Updated on: Sat, 08 December 2012 14:26] by Moderator
Re: Reusing validation in GMF editor [message #986053 is a reply to message #986023] Sat, 17 November 2012 16:31 Go to previous messageGo to next message
You have broken the holy rule of *never* using standalone setup in
Eclipse. It's meant for runtime only and will mess up all EMF registries.
This newsgroup is full of solutions to this problems.
Am 17.11.12 16:58, schrieb Axel Guckelsberger:
> Hi again,
> // testing output
> The attached file screen1.jpg shows how it looks like in the editor.
> - all diagram elements are broken
> - happens always, even before starting any validation run at all
> - happens independently of the Ecore package removal.
> Greetings,
> Axel
Re: Reusing validation in GMF editor [message #986054 is a reply to message #986017] Sat, 17 November 2012 16:34 Go to previous messageGo to next message
Hi Ed,
my impression is that the EValidator API is not the best part of EMF,
maybe was even planned to be changed, and that this is why there hasn't
been a registry which would freeze an unfortunate solution.
Jan
Am 17.11.12 15:02, schrieb Ed Willink:
> Hi Jan
> Regards
> Ed Willink
>>> Hi all,
>>> Earlier I
>>> editor(s). The
>>> the EMF
>>> other side
>>> product
>>> put it
>>> Axel
Re: Reusing validation in GMF editor [message #986073 is a reply to message #986053] Sun, 18 November 2012 05:00 Go to previous messageGo to next message
Hi Jan,
thanks for the pointer. Originally I used the activator but had the same
results which is why I tried out the standalone setup afterwards.
Now I replaced
MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
by
final Injector injector = MyDslActivator.getInstance()
..getInjector(MyDslActivator.ORG_EXAMPLE_MYDSL);
The test output prints the following values in the EValidator registry now:
So the CompositeEValidator is not dropped anymore now. But beside this the
change does not change anything with regards to the behaviour in the editor
unfortunately.
I did also look at the MyDslExecutableExtensionFactory class, but first this
is not visible for being called by other bundles and second it delegates to
the activator again.
Axel
[Updated on: Sun, 18 November 2012 05:50] by Moderator
Re: Reusing validation in GMF editor [message #986081 is a reply to message #986073] Sun, 18 November 2012 10:10 Go to previous messageGo to next message
Just getting the EValidator from the Injector should do the job, as all
the rest is performed by the method
AbstractInjectableValidator.register(EValidatorRegistrar)
which is automatically executed by the Injector.
Make sure your MyDslJavaValidator overrides getEPackages() to set the
EPackages for which it is evaluated.
If that still doesn't work, you have to debug the Diagnostician.
Am 18.11.12 11:00, schrieb Axel Guckelsberger:
> Hi Jan,
> Now I replaced
> by
> unfortunately.
> Axel
>>> Hi again,
>>> EValidator.Registry.INSTANCE; final EcorePackage ecorePackage =
>>> EcorePackage.eINSTANCE; if (registry.containsKey(ecorePackage))
>>> // testing output
>>> Greetings,
>>> Axel
Re: Reusing validation in GMF editor [message #989368 is a reply to message #985999] Wed, 05 December 2012 15:51 Go to previous messageGo to next message
Hi Jan,
I debugged into the Diagnostician class and found out the reason for why
validation is not working.
In org.eclipse.xtext.validation.AbstractInjectableValidator the
isResponsible() returns false causing the validator to be skipped.
The logic in isResponsible() is as follows:
return !isLanguageSpecific() || Strings.equal(languageName,
getCurrentLanguage(context, eObject));
isLanguageSpecific() just checks whether the languageName member var is not
null, which returns true in my tests as languageName contains the name of my
xtext language.
The other option in the OR clause, that is the Strings.equal() call, returns
false because getCurrentLanguage() relies on either the context or a
XtextResource for determining the current language.
But the context is just created by Diagnostician#createDefaultContext() and
does therefore not contain CURRENT_LANGUAGE_NAME.
What can I do to resolve this?
I want to start using XtextResource anyway, so that might be the most
obvious possibility. But maybe there is also some way to define (read:
inject) the required information?
Axel
>> Hi all,
>> Axel
Re: Reusing validation in GMF editor [message #989370 is a reply to message #989368] Wed, 05 December 2012 15:57 Go to previous messageGo to next message
To make this clear: I imagine something like injecting the
CURRENT_LANGUAGE_NAME into the context, so that validation would work also
with older model files which are still based on XML/XMI.
Re: Reusing validation in GMF editor [message #989543 is a reply to message #989368] Thu, 06 December 2012 11:44 Go to previous messageGo to next message
I don't get it. Why don't you just override isLanguageSpecific() or
isResposible() in your validator to fit your needs?
Am 05.12.12 21:51, schrieb Axel Guckelsberger:
> Hi Jan,
> xtext language.
> Axel
>>> Hi all,
>>> Axel
Re: Reusing validation in GMF editor [message #989584 is a reply to message #989543] Thu, 06 December 2012 15:49 Go to previous message
Thanks Jan,
I was just so happy that I found the problem cause that I oversaw that my validator is an inheriting class. Too easy to see Smile
Thanks again,
Axel
Previous Topic:xtext - creating a new EObject
Next Topic:Bug parsing Xtext file
Current Time: Tue Jul 22 09:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.07764 seconds
