Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Integrate external application in SWT application(Integrate external application in SWT application)
Integrate external application in SWT application [message #974539] Wed, 07 November 2012 01:09 Go to next message
I understood how to integrate the application as described in the following links
http://www.eclipse.org/articles/article.php?file=Article-ActivexSupportInSwt/index.html
and http://www.ibm.com/developerworks/opensource/library/os-activex/# , but the problem now is that it requires a program ID. i tried to find the program Id of the application from Windows registry but it seems that the application does not have a program ID. IS there any alternate approach by which i can integrate or any way by which i can assign a program ID to the application
Re: Integrate external application in SWT application [message #985983 is a reply to message #974539] Fri, 16 November 2012 17:03 Go to previous messageGo to next message
Is the application that you want to embed written as either an Active X
control or an OLE Document? This is something that an app whose intent
is to be embeddable must do explicitly, and most do not do this. There
is not an alternate way to integrate a native application in SWT. From
SWT you can use the Program class to launch an external application, but
I don't know if this would make sense in your context or not.
Grant
> following links
Re: Integrate external application in SWT application [message #986008 is a reply to message #985983] Sat, 17 November 2012 06:28 Go to previous message
Hm - IIRC on windows we once used the native handle of the composite and
passed that to the native application, but I can't find the code anymore :-(
Tom
Am 16.11.12 23:03, schrieb Grant Gayed:
> Grant
>> following links
Previous Topic:Windows 64 bit XULRunner for 3.6.2?
Next Topic:Simple PDF Viewer using PDFRenderer
Current Time: Sat Jul 26 01:54:38 EDT 2025
Powered by FUDForum. Page generated in 0.03849 seconds
