Home » Modeling » Model-to-Model Transformation » Behavioral features ( state machine) support(import and preserve behavioral features of UML models)
Behavioral features ( state machine) support [message #985914] Fri, 16 November 2012 11:44 Go to next message
Hi all,
I have two models A and B, they are based on two meta models PIMmeta and PSMmeta respectively. The models represents both structural (classes) and behavioral ( state machines) features of UML models. All the models are based on UML using MagicDraw.
The goal is to transform the states in model A to the equivalent states in model B.
After creating the project and linking to the models,and in the the resulted ecore files from the models, only the structural parts(classes) were derived. All the state machines and Activity diagrams were ignored.
how to convert my models to .ecore while preserving the behavioral features?
Thanks in advance,
Re: Behavioral features ( state machine) support [message #985928 is a reply to message #985914] Fri, 16 November 2012 12:32 Go to previous messageGo to next message
ECore does not support State Macghines so don't use it.
UML is much richer and what MagicDraw gave you; stick with it if you
want UML facilities.
Transformations can use UML as input and/or output.
Ed Willink
On 16/11/2012 16:46, Rihab Eltayeb wrote:
> Hi all,
> states in model B.
> features?
> Thanks in advance,
Re: Behavioral features ( state machine) support [message #986499 is a reply to message #985928] Tue, 20 November 2012 11:31 Go to previous messageGo to next message
Thank you so much Ed,
Since ECore does not support my transformation then any tool based on ECore will not do it.
so which tool can I use?
Any examples? tutorials?
Re: Behavioral features ( state machine) support [message #986505 is a reply to message #986499] Tue, 20 November 2012 11:45 Go to previous messageGo to next message
You are confusing meta-levels.
Ecore tooling may be used for arbitrary meta-models such as UML that
support StateMachines.
As a user you should not need to care what actually representation is
used by your tools, you just need to use meta-models that have your
concepts.
For instance if you want to model Money, that doesn't mean you cannot
use Ecore or UML. It just means you need to use a meta-model (defined
perhaps in Ecore or UML) that does support Money.
Ed Willink
Re: Behavioral features ( state machine) support [message #986506 is a reply to message #986499] Tue, 20 November 2012 11:51 Go to previous messageGo to next message
I was also trying Medini QVT plugin, it is based on ECore,
The meta models have to be registered in order to use them as model type,
The registeration needs an ecore file ! again the ecore problem sustains.
Re: Behavioral features ( state machine) support [message #986524 is a reply to message #986506] Tue, 20 November 2012 12:51 Go to previous messageGo to next message
No
Again you confuse metamodel levels.
The Eclipse MDT/UML2 implementation of the UML meta-model uses Ecore;
UML.ecore.
UML supports state machines and has an Ecore metanmodel; use UML for
StateMachine support, or write your own, or Google for one of the
available Ecore-based StateMachine models.
Most EMF-based transformation machines can transform UML models; set up
can be a bit tricky. I expect Medini QVT can too.
Ed Willink
Re: Behavioral features ( state machine) support [message #986659 is a reply to message #986524] Wed, 21 November 2012 05:15 Go to previous messageGo to next message
Hi Ed and thank you for the clarifications,
My understanding of ECore is that it provides a way to describe models. It also used for runtime support of models.
The ECore concept is similar to MOF concept in UML ( particularly EMOF).
You suggest to define PIMmeta:uml , PIMmeta is of type uml which is defined by uml.ecore.
This is fine. I tried that in QVT before and it works.
You were absolutely right, setup is needed, the question is how?
Now I want to refer to A:PIMmeta , A is an instance of PIMmeta, I got an error that PIMmeta is unkown model type.
I think the PIMmeta.uml have to be registered too. what do you think?
Re: Behavioral features ( state machine) support [message #986707 is a reply to message #986659] Wed, 21 November 2012 06:52 Go to previous messageGo to next message
If you told me which of many possible tools, approaches and versions you
were using, I might be able to help.
It saves me (and you) a lot of tike if you prepare a small simple zipped
project that demonstrates your best attempt.
Ed Willink
Re: Behavioral features ( state machine) support [message #987143 is a reply to message #986707] Fri, 23 November 2012 14:15 Go to previous messageGo to next message
Hi Ed,
I prepared the ziped file, but it seems that I don't have the right to attach something. No Browse link is available with the reply form.
The models were created using magicDraw 16.5, I tried a modeling project in Eclipse Helios to load my models but failed to represent behavior.
The transformation is tried using Medini QVT 1.7
Re: Behavioral features ( state machine) support [message #987154 is a reply to message #987143] Fri, 23 November 2012 16:26 Go to previous messageGo to next message
HI
Medini QVT is not an Eclipse Foundation project so you should try the
Medini support.
Ed Willink
On 23/11/2012 19:15, Rihab Eltayeb wrote:
> Hi Ed,
> behavior.
Re: Behavioral features ( state machine) support [message #987156 is a reply to message #987154] Fri, 23 November 2012 16:38 Go to previous messageGo to next message
HI,
Using Medini QVT was an alternative way to solve the problem.
What I originally did is to create a new modeling project in Eclipse Helios,and add my models to it.
The loss of states prevents me from doing the transformation in Eclipse.
How to setup EMF to use UML meta models and preserve behaviors
Please help me in regard to Eclipse.
Re: Behavioral features ( state machine) support [message #987161 is a reply to message #987156] Fri, 23 November 2012 17:00 Go to previous message
Try reading the UML tutorials so that you understand the relationship
between UML2 and EMF and stop make confused statements.
Then look for a UML example to copy for your chosen transformation tool.
Ed Willink
On 23/11/2012 21:38, Rihab Eltayeb wrote:
> HI,
Previous Topic:[ATL] XSD to ECORE ATL transformation
Next Topic:[ATL]different transformed results between ATL configuration and Java programming transformation
Current Time: Sat Jul 26 03:26:53 EDT 2025
Powered by FUDForum. Page generated in 0.19442 seconds
