Home » Modeling » EMF » [CDO] CDOTransaction lifecycle, attempt to modify historical revision
[CDO] CDOTransaction lifecycle, attempt to modify historical revision [message #985862] Fri, 16 November 2012 08:17 Go to next message
I am currently working on porting an existing EMF application to CDO, specifically, we are using CDOWorkspace for clients. Our current implementation uses a single CDOTransaction to support all of the editors and views in our application. For persistence, we've added a TransactionalEditingDomainListener to our TransactionalEditingDomain's Lifecycle. This listener is responsible for incrementally calling CDOTransaction.commit() upon close of every EMF Transaction. CDOWorkspace.checkin() is initiated by the user via a button push.
As such, it is possible to call CDOTransaction.commit() multiple times between requests for CDOWorkspace.checkin(). If the same object is modified multiple times between CDOWorkspace.checkin(), the revision number is incremented each time as expected.
The problem I am seeing is a ConcurrentModificationException upon the first CDOTransaction.commit() after a CDOWorkspace.checkin() of an object that previously had more than one revision committed. I've attached a unit test that illustrates the problem.
My question is whether our expectation to use a single CDOTransaction in this style is legitimate, and this is a valid bug; or are we violating some assumptions and should look in a different direction?
Side note: I have temporarily worked around this problem by deferring CDOTransaction.commit() until immediately prior to CDOWorkspace.checkin(). This ensures the multiple revisions of an object are not included in a CDOWorkspace.checkin().
Thanks in advance,
Matt
WorkspaceTest to illustrate possible bug:
  @Requires(IRepositoryConfig.CAPABILITY_UUIDS)
  public void testMultipleAddsReusingTransaction() throws Exception
    InternalCDOWorkspace workspace = checkout("MAIN", CDOBranchPoint.UNSPECIFIED_DATE);
    CDOTransaction transaction = workspace.openTransaction();
    CDOResource resource = transaction.getResource(getResourcePath(RESOURCE));
    Product1 product = null;
    for (int i = 0; i < PRODUCTS; i++)
      product = createProduct(i);
      resource.getContents().add(product);
      transaction.commit();
    CDOCommitInfo info = workspace.checkin();
    resource.getContents().add(createProduct(PRODUCTS));
     * The following line generates the ConcurrentModificationException:
Exception stacktrace:
[ERROR] Rollback in MEMStore: java.util.ConcurrentModificationException: Attempt by Transaction[1:1] to modify historical revision: _HOYrkS_sEeKIAtS-2U2oCA:0v6
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.isContainerLocked(TransactionCommitContext.java:915)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.lockObjects(TransactionCommitContext.java:832)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:511)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:46)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
	at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:911)
	at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:904)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:295)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:97)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Re: [CDO] CDOTransaction lifecycle, attempt to modify historical revision [message #985920 is a reply to message #985862] Fri, 16 November 2012 11:49 Go to previous messageGo to next message
Am 16.11.2012 14:17, schrieb Matt Mursko:
> time as expected.
This sounds like a bug in CDOWorkspaceImpl. Can you please submit a bugzilla and attach the test case there?
Cheers
/Eike
http://www.esc-net.de
> Thanks in advance,
> Matt
> at
> at
> at
Re: [CDO] CDOTransaction lifecycle, attempt to modify historical revision [message #985937 is a reply to message #985920] Fri, 16 November 2012 13:09 Go to previous message
Thank you for the prompt reply Eike. Here is the bug:
Bug 394491 - CDOWorkspace: "Attempt by Transaction to modify historical revision" for object with multiple modifications between checkin()
Previous Topic:[CDO] 4.2-M2 target platform / tycho error
Next Topic:[CDO] Rollback problem
Current Time: Fri Jul 25 20:40:05 EDT 2025
Powered by FUDForum. Page generated in 0.05861 seconds
