Home » Modeling » ATL » ATL to ATL Refining Mode
ATL to ATL Refining Mode [message #985902] Fri, 16 November 2012 10:54 Go to next message
I'm trying to refine my ATL transformation using ATL. The end goal is to dynamically build my input model list. However, i'm having lots of problems getting up and running.
I am running Eclipse Juno and ATL 3.2.1. The issues are as follows:
1) The ATL Metamodel is registered in the EMF Registry. Why is this? I can see the ecore model in the jar org.eclipse.m2m.atl.dsls_3.3.0.v201205241358
2) I have imported the ATL.ecore into my workspace due to the issue in #1. It does not validate. I see 3 errors.
3) When running a simple ATL refiner I get the following error, i assume it is because of #2, "Error loading platform:/resource/TestRefining/Public2Private.atl: org.xml.sax.SAXParseException: Content is not allowed in prolog."
The refiner is as follows:
-- @atlcompiler atl2010
-- @nsURI ATL=http://www.eclipse.org/gmt/2005/ATL
--http://www.eclipse.org/m2m/atl/2011/EMFTVM
--http://www.eclipse.org/gmt/2005/ATL
module AtlFlattenerRefine;
--create OUT : ATL refining IN : ATL;
create OUT : ATL from IN : ATL;
rule RebuildCreateList{
from s : ATL!Rule
to t : ATL!Rule(
name <-s. name+'ZZZZZZZZZ'.debug('q')
I also did some testing with ATL 3.3.1 but got nowhere there either. That said the ATL.ecore was available via the uri http://www.eclipse.org/m2m/atl/2011/EMFTVM. Any help is appreciated!
Ronan
Re: ATL to ATL Refining Mode [message #985904 is a reply to message #985902] Fri, 16 November 2012 10:57 Go to previous messageGo to next message
You have to inject the transformation in xmi first and you'll have to extract it in text after the transformation also.
Re: ATL to ATL Refining Mode [message #985905 is a reply to message #985904] Fri, 16 November 2012 11:00 Go to previous messageGo to next message
Oh Sad
I think I remember doing something like that with AMW years ago. Have you got an example that works with the latest versions of ATL?
Thanks!
Ronan
Re: ATL to ATL Refining Mode [message #985911 is a reply to message #985905] Fri, 16 November 2012 11:12 Go to previous messageGo to next message
Perhaps this post is similar? http://www.eclipse.org/forums/index.php/t/32412/ Any code examples available?
I also some really useful stuff at http://www.eclipse.org/forums/index.php/t/367267/
I got step one working where I generate the .xmi file using ATLCopy and emftvm compiler.
Step two failed with an error "org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/gmt/2005/ATL' not found. (platform:/resource/TestRefining/Public2Private.xmi, 3, 75)". I am using the ATL MM URI http://www.eclipse.org/gmt/2005/ATL. This is stuck into the XMI by ATLCopy. I assume when it tries to load the model it fails as this URI isn't actually registered by ATL. I see I can register the model manually, why doesn't the ATL plugin do this? Once registered I the Refine step works.
Now how do I get the ATL text back from the XMI?
Ronan
[Updated on: Fri, 16 November 2012 12:13] by Moderator
Re: ATL to ATL Refining Mode [message #985921 is a reply to message #985911] Fri, 16 November 2012 11:52 Go to previous messageGo to next message
You can use a small ANT script with calls to ATL ANT Tasks to inject your ATL file (.atl) as an ATL model (.xmi), and after transformation to extract your ATL model as an ATL file.
You have to use the atl.loadModel and atl.saveModel tasks with the right injection/extraction parameter as explained in the documentation.
I hope this helps.
Hugo
Re: ATL to ATL Refining Mode [message #985925 is a reply to message #985921] Fri, 16 November 2012 12:15 Go to previous messageGo to next message
Ok great! I will try.
Thanks Hugo!
Re: ATL to ATL Refining Mode [message #986013 is a reply to message #985902] Sat, 17 November 2012 08:42 Go to previous messageGo to next message
EMFTVM can load .atl files as models directly, but does not yet support
refining mode. You may use ATLCopy.atl and module superimposition:
http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/plugins/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLCopy.atl
Your code should look something like this:
-- @atlcompiler emftvm
uses ATLCopy;
-- Redefine "MatchedRule" rule from ATLCopy
rule MatchedRule {
from s : ATL!MatchedRule
to t : ATL!MatchedRule(
Dennis
Op 16/11/12 16:54, Ronan B schreef:
> from s : ATL!Rule
> to t : ATL!Rule(
> Ronan
Re: ATL to ATL Refining Mode [message #986210 is a reply to message #986013] Mon, 19 November 2012 08:29 Go to previous messageGo to next message
Hi Dennis,
Okay I have tried to create this in an ANT script but I just get the following out:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"/>
My ANT file looks like this:
<project name="MyProject" default="x" basedir=".">
<description>
x
</description>
<target name="x" description="x" >
<emftvm.loadMetamodel name="ATL" uri="http://www.eclipse.org/gmt/2005/ATL"/>
<emftvm.loadModel name="Public2Private" wspath="TestRefining/Public2Private.atl"/>
<emftvm.run modulepath="platform:/resource/TestRefining/" module="ATLFlattenerRefine">
<metamodel name="ATL"/>
<inputmodel name="Public2Private" as="IN"/>
<outputmodel name="ATLCopy-OUT" as="OUT" wspath="TestRefining/ZZZZ.xmi"/>
</emftvm.run>
<emftvm.saveModel name="ATLCopy-OUT" derived="true"/>
</target>
</project>
When I run via the regular run configuration I get a full XMI file.
One other thing. It is cool the injection is automatic but how about serialization back to ATL for the output model with ANT.
Thanks!
Ronan
Re: ATL to ATL Refining Mode [message #986432 is a reply to message #986013] Tue, 20 November 2012 07:15 Go to previous messageGo to next message
Hi Dennis,
do you have some documentation about the API of EMFTVM that helps to load an atl file? Is there an ATL unparser as well? (by unparser I mean an implementation of an XMI to ATL code)
Thanks a lot for your help,
Etienne.
Re: ATL to ATL Refining Mode [message #986438 is a reply to message #986210] Tue, 20 November 2012 07:20 Go to previous messageGo to next message
A quick update. I got what I wanted working using the 2006 compiler. I'll update this post later when I figure out the deserialization/extraction using the newest compiler. For anyone who is interested the ANT for the 2006 compiler is as follows:
<project name="MyProject2006" default="x" basedir=".">
<description>
x
</description>
<atl.loadModel name="ATL" metamodel="MOF" uri="http://www.eclipse.org/gmt/2005/ATL"/>
<atl.loadModel name="UML" metamodel="MOF" uri="http://www.eclipse.org/uml2/2.1.0/UML"/>
<atl.loadModel name="myATL" metamodel="ATL" path="Public2Private.atl">
<injector name="ATL" />
</atl.loadModel>
<atl.loadModel name="myUML" metamodel="UML" path="My.uml"/>
<atl.launch path="ATLRefine.asm">
<option name="allowInterModelReferences" value="true"/>
<inmodel name="IN" model="myATL"/>
<inmodel name="IN2" model="myUML"/>
<superimpose path="ATLCopy.atl"/>
<outmodel name="OUT" model="myOut" metamodel="ATL"/>
</atl.launch>
<atl.saveModel model="myOut" path="SavingMySample.atl">
<extractor name="ATL"/>
</atl.saveModel>
</target>
</project>
Now to get this working with just the API and not ANT Smile
Ronan
[Updated on: Tue, 20 November 2012 07:20] by Moderator
Re: ATL to ATL Refining Mode [message #986539 is a reply to message #986210] Tue, 20 November 2012 15:27 Go to previous messageGo to next message
Op 19/11/12 14:29, Ronan B schreef:
> Hi Dennis,
> out:
> <description>
> x
> </description>
> </emftvm.run>
> </target>
> </project>
You should first load the .atl model, and then the ATL metamodel, because the
ATL parser insists on loading its own version of the ATL metamodel. EMFTVM
will reuse the ATL metamodel that was pre-loaded by the ATL parser.
Sounds counter-intuitive, but that's the conceptual mismatch between ATL and
EMF: EMF automatically determines the required metamodel from the model
itself, but ATL needs an explicit reference (to deal with output models,
a.o.). The Eclipse launch dialog takes care of this behind the scenes, but in
Ant, you prescribe the loading order.
> Thanks!
> Ronan
EMF selects the resource implementation (XMI, XML, ATL ,...) based on file
extension. That's why you need to save your UML models using the .uml
extension, or the wrong resource implementation is used.
If you want EMF to select the ATL resource implementation for the output
model, you should use the .atl file extension. Then you will get a textual ATL
file.
Dennis
Re: ATL to ATL Refining Mode [message #986541 is a reply to message #986432] Tue, 20 November 2012 15:40 Go to previous messageGo to next message
Op 20/11/12 13:15, EtienneB Mising name schreef:
> Hi Dennis,
Unfortunately no documentation. There are only examples for now:
Test for EMFTVM ant tasks:
http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/tests/org.eclipse.m2m.atl.emftvm.tests/anttest/build.xml
Compiler-copy script - copies the ATLtoEMFTVM.atl compiler to an XMI version
of itself:
http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/plugins/org.eclipse.m2m.atl.emftvm.compiler/compiler-copy/build.xml
And for the meta-lovers:
Compiler-compiler script - compiles the ATLtoEMFTVM.atl compiler using an
older version of itself:
http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/plugins/org.eclipse.m2m.atl.emftvm.compiler/compiler-compiler/build.xml
Compiled-compiler-compiler script - compiles the ATLtoEMFTVM.atl compiler
using the compiled version of itself:
http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/plugins/org.eclipse.m2m.atl.emftvm.compiler/compiler-compiler/compiled-compiler-compiler/build.xml
> Etienne.
EMFTVM provides a complete EMF resource implementation for ATL, which includes
both injector (parser) and extractor (pretty-printer). As EMF selects the
resource implementation based on file name extension, you should always use
..atl for input as well as output models to trigger the use of the ATL parser
and pretty-printer.
Dennis
Re: ATL to ATL Refining Mode [message #986937 is a reply to message #986539] Thu, 22 November 2012 07:30 Go to previous messageGo to next message
Hi Dennis,
Okay great, I would never of guessed the order made a difference there. Is there anyway of improving the error handling to help future users with this issue?
Now my test injector/extractor/refiner works beautifully Smile ANT code is as follows:
<description>
x
</description>
<emftvm.run modulepath="platform:/resource/TestRefining/" module="ATLCopy">
<outputmodel name="ATLCopy-OUT" as="OUT" wspath="TestRefining/out/Public2Private.atl"/>
</emftvm.run>
</target>
</project>
Now i'm going to try getting this to work via the API. I'm sure i'll have more questions, but hopefully we can get something together here on the Forum as a lot of people seem to be interested in the new VM.
Thanks again!
Ronan
Re: ATL to ATL Refining Mode [message #987303 is a reply to message #986937] Sun, 25 November 2012 16:13 Go to previous messageGo to next message
Op 22-11-12 13:30, Ronan B schreef:
> Hi Dennis,
> issue?
Probably yes. I'll look into it.
Dennis
> Now my test injector/extractor/refiner works beautifully :) ANT code is as
> follows:
> <description>
> x
> </description>
> module="ATLCopy">
> </emftvm.run>
> </target>
> </project>
> Thanks again!
> Ronan
Re: ATL to ATL Refining Mode [message #987405 is a reply to message #986432] Mon, 26 November 2012 08:48 Go to previous messageGo to next message
Hi Etienne,
I finally got the emftvm to run via the API. Unfortuantely the API is not the same as the one provided before in CoreService. Perhaps it can be in the future? I figured this out by debugging a laucnher that works. You will need a copy of many of the methods in org.eclipse.m2m.atl.emftvm.launcher/EMFTVMLaunchConfigurationDelegate to make this work. They are private there. The values are hardcoded below but are easily made generic.
ExecEnv env = EmftvmFactory.eINSTANCE.createExecEnv();
ResourceSet rs = new ResourceSetImpl();
Map<String, String> metamodelLocations = new HashMap<String, String>();
metamodelLocations.put("ATL","http://www.eclipse.org/gmt/2005/ATL");
Map<String, String> metamodelOptions = new HashMap<String, String>();
loadFileMetaModels(rs, metamodelLocations, metamodelOptions, env);
Map<String, String> inputModelLocations = new HashMap<String, String>();
inputModelLocations.put("IN", "platform:/resource/TestRefining/Public2Private.atl");
Map<String, String> inputModelOptions = new HashMap<String, String>();
loadInputModels(rs, inputModelLocations, inputModelOptions, env);
Map<String, String> outputModelLocations = new HashMap<String, String>();
outputModelLocations.put("OUT","platform:/resource/TestRefining/Public2Private_refined.atl");
Map<String, String> outputModelOptions = new HashMap<String, String>();
outputModelOptions.put("OUT","allowIntermodelReferences derivedFile");
createOutputModels(rs, outputModelLocations, outputModelOptions, env);
loadOtherMetaModels(rs, metamodelLocations, metamodelOptions, env);
ModuleResolver resolver = createModuleResolver("/TestRefining/");
env.loadModule(resolver, "ATLCopy");
TimingData timingData = new TimingData();
env.run(timingData);
Map<String, String> emptyMap = Collections.emptyMap();
saveModels(env.getOutputModels(), outputModelOptions, emptyMap);
After getting all this to work in Juno I found out the emftvm compiler does not work in Eclipse Helios Version: 3.6.2.r362_v20101104-9SAxFMKFkSAqi8axkv1ZjegmiBLY
Build id: M20110210-1200. I get the following error:
Errors occurred during the build.
Errors running builder 'ATL builder' on project 'X'.
org.eclipse.emf.ecore.util.Switch
Should I file a bug Dennis?
Ronan
Re: ATL to ATL Refining Mode [message #987500 is a reply to message #987405] Mon, 26 November 2012 16:23 Go to previous messageGo to next message
Hello Ronan, Etienne,
Op 26/11/12 14:48, Ronan B schreef:
> Hi Etienne,
Basically, ExecEnv *is* the API. EMFTVM does not align with ATL's ILauncher
and IModel interfaces due to explicit design choice:
1. ATL/EMFTVM should not provide API for model loading/saving: this is the
domain of EMF. Any questions regarding loading/saving/parsing/pretty-printing
should be forwardable to EMF/EMFText/xText(/TCS?) whenever possible.
ATL/EMFTVM should stick to transformation.
2. ATL/EMFTVM should not record model-metamodel relationships when it cannot
enforce them anyway; EMF has a different, incompatible way of representing
model-metamodel relationships (i.e. on a per-instance basis, using XML
namespaces for example).
The above code translates an Eclipse launch configuration to the EMFTVM
ExecEnv API. Another example of using EMFTVM as part of an Eclipse plug-in can
be found here (see lines 200-225):
http://soft.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-instantmessenger-config-editor/src/be/ac/vub/uml2cs/instantmessenger/popup/actions/GenerateBuildFileAction.java?view=markup
The basic recipe is quite simple:
1. Wrap any loaded EMF models inside EMFTVM Model and Metamodel instances:
Metamodel xml = EmftvmFactory.eINSTANCE.createMetamodel();
xml.setResource(emfResource);
Model in = EmftvmFactory.eINSTANCE.createModel();
in.setResource(anotherEmfResource);
1. Create an ExecEnv instance:
2. Register any input/output/inout/meta-models:
env.registerMetaModel("CFG", cfg);
env.registerMetaModel("XML", xml);
env.registerInputModel("IN", in);
env.registerOutputModel("OUT", pars);
3. Create a module resolver that can load .emftvm modules and their imports
(DefaultModuleResolver expects a trailing '/' in the prefix!):
ModuleResolver resolver = new
DefaultModuleResolver("platform:/resource/.../", resourceSet);
4. Load a named module using the module resolver:
env.loadModule(resolver, "Module");
-- or, for modules that are contained in a package (folder):
env.loadModule(resolver, "Package::Module");
5. Run the transformation:
env.run(null);
You may add a TimingData object to the mix as well, if you're interested in
performance statistics.
Hmm, you may. Try to include a stack trace as well. I suspect that I'm using a
newer version EMF... I've only tried EMFTVM on Eclipse 3.7 and up.
Dennis
> Regards,
> Ronan
Re: ATL to ATL Refining Mode [message #989464 is a reply to message #987500] Thu, 06 December 2012 05:24 Go to previous message
Thanks for the details. I'll work some more with this later. For now I can't as I have a dependency on Eclipse 3.6. I've added a bugzilla item as previously discussed. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=395906
Ronan
Previous Topic:Errors when removing from and adding to the same sequence in refining mode
Next Topic:Stack size limitation in EMF-specific VM
Current Time: Sat Jul 26 21:19:40 EDT 2025
Powered by FUDForum. Page generated in 1.07326 seconds
