Home » Eclipse Projects » Virgo » Enhancement propal for Integration tests
Enhancement propal for Integration tests [message #971207] Sun, 04 November 2012 12:49 Go to next message
I know about
the @RunWith(DmKernelTestRunner.class) annotation but I think it's over-complicated: it forces us to duplicate a Virgo conf (with not the exact virgo server format).
As an addition, this solution is not as easy for adding third party libraries and synchronizes it with the enterprise dependencies.
What do you think about a Maven plugin able to run an home made Virgo server zip (or rpm) to run integration tests?
I've not any knowledge on these domains (maven plugins, zip packaging...), it's just one thing I would like to have to make some Itests on my project.
For the background, I'm not able to use pax-exam because of my intense use of virgo ltw, nor virgo test runner due to all my custom server libs, I haven't tried Tycho yet, but I think the pax-exam issue will block me the same way.
Best regards to this wonderful Virgo community,
Charlie
Re: Enhancement propal for Integration tests [message #971693 is a reply to message #971207] Sun, 04 November 2012 22:38 Go to previous messageGo to next message
We're aware it is a bit cumbersome to customize an integration test. We especially felt it when making large infrastructure changes and all the tests had to receive additional bundles, configurations etc. where it would have been easier to have a Virgo zip and run on top.
We were looking into Cargo and PAX-Exam integration. For your particular case I think Cargo might do better. It has Maven and Ant integration and basically works by taking a zipped container and deploys stuff in it and then gives you connection to this server to make checks. We haven't yet focused on getting this support but if the community demand increases it might pop higher on the list Smile
Check it out and let us know if it will help you.
Best Regards
Bobby
Re: Enhancement propal for Integration tests [message #974914 is a reply to message #971693] Wed, 07 November 2012 07:44 Go to previous messageGo to next message
I already know about Cargo (I used it with an home made jsf/spring/tomcat framework) and I think it would be a nice container to fulfill the need.
For sure it will help me!
I'll listen with strong interest for this integration/connector (and may be if I have time I'll work on it (don't count too much on my participation, I'm far underwater for the moment)).
Re: Enhancement propal for Integration tests [message #977453 is a reply to message #974914] Fri, 09 November 2012 04:45 Go to previous messageGo to next message
Is there an enhancement bugzilla to capture this?
Re: Enhancement propal for Integration tests [message #985863 is a reply to message #971207] Fri, 16 November 2012 08:20 Go to previous messageGo to next message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=394465
Re: Enhancement propal for Integration tests [message #985870 is a reply to message #985863] Fri, 16 November 2012 09:02 Go to previous message
Thanks Charlie.
Previous Topic:Virgo + Hibernate problems
Next Topic:Listener for bundle consuming services
Current Time: Wed Jul 23 20:30:00 EDT 2025
Powered by FUDForum. Page generated in 0.26148 seconds
