Home » Modeling » ATL » Problem in loading meta Model
Problem in loading meta Model [message #985830] Fri, 16 November 2012 05:05 Go to next message
Normally, the meta model should be loaded at first , for enabling the Sample Ecore Model Editor to provide a tree structure representation of the Ecore model
but when i do a right click to select this option at the Meta Model, it is not visible for me
what is the problem? i have installed other version of Eclipse but i doesn't work
CAN YOU HELP ME PLEAAASE
I haven't enought time
Thank u
Re: Problem in loading meta Model [message #985841 is a reply to message #985830] Fri, 16 November 2012 05:41 Go to previous message
For the "Register Metamodel" action to be available from a right-click on an Ecore file, you need to use the Project Explorer in the ATL perspective.
Hugo
Previous Topic:ATL VM question about exclusive pattern matching execution
Next Topic:ResolveTemp in Lazy Rule relating to another Lazy Rule
Current Time: Thu Jul 24 18:01:48 EDT 2025
Powered by FUDForum. Page generated in 0.24775 seconds
