Home » Modeling » TMF (Xtext) » resolving cross-references
resolving cross-references [message #984278] Wed, 14 November 2012 10:04 Go to next message
Hi all,
When resolving a cross-reference in LinkingService.getLinkedObjects, I was returning an object retrieved with something like
resourceSet.getEObject(uri, true)
which caused the respective file to be opened and reparsed. I changed the second argument to "false" and so far it seems that it's still working (but there's a lot to test still).
Is the first way the right one, or it doesn't matter? Maybe I'm just not doing anything yet with the returned value?
best regards,
Vlad
Re: resolving cross-references [message #985741 is a reply to message #984278] Thu, 15 November 2012 16:51 Go to previous messageGo to next message
resourceSet.getEObject(uri, false) will yield return null if the
resource is not yet loaded. In the default linking service, we use the
index and return a proxy rather than a resolved object. This will not
cause any files to be parsed. Have you tried that?
Am 14.11.12 16:04, schrieb Vlad Dumitrescu:
> Hi all,
> resourceSet.getEObject(uri, true) which caused the respective file to be
> best regards,
> Vlad
Re: resolving cross-references [message #985746 is a reply to message #985741] Thu, 15 November 2012 17:42 Go to previous messageGo to next message
Thanks Jan,
I another thread, I described that if I put all referenceable objects in the index this blows up the JVM's memory. There could be 3000 largish files in a project. So I got the suggestion to just keep the top-level constructs in the index, and then navigate the model. This obviously requires the objects to be resolved, but I thought they would be retrieved from a serialized form instead of from parsing the file again. This is how I did in my pre-Xtext implementation and took it for granted.
I understand your explanation that I got it working with a 'false' argument just by accident. Thanks!
regards,
Vlad
Re: resolving cross-references [message #985938 is a reply to message #985746] Fri, 16 November 2012 13:05 Go to previous messageGo to next message
A customer of ours used EMF proxies with some essential values set.
These can be populated e.g. from the userData in the
IEObjectDescriptions. After all proxies are EObjects and behave to a
certain extend like those. Even though I would not recommend this as
long as you are 100% sure what you're doing, this might be something to
look at.
Am 15.11.12 23:42, schrieb Vlad Dumitrescu:
> Thanks Jan,
> regards,
> Vlad
Re: resolving cross-references [message #985953 is a reply to message #985938] Fri, 16 November 2012 15:54 Go to previous message
I'm not sure I understand what you mean -- the language model classes use proxies instead of normal references?
That might be interesting to explore, but there's one more thing that I'm unsure about and that is whether I know what I'm doing Smile
best regards,
Vlad
Previous Topic:importing native java source code
Next Topic:Selection for a type system
Current Time: Sun Jul 27 08:07:36 EDT 2025
Powered by FUDForum. Page generated in 0.04059 seconds
