Home » Eclipse Projects » EclipseLink » Postgres inet type
Postgres inet type [message #980721] Sun, 11 November 2012 18:05 Go to next message
So, using eclipselink and inet type is nicely cast to string when reading.
But on insert something is wrong:
Caused by: org.postgresql.util.PSQLException: ERROR: column "..." is of type inet but expression is of type character varying
  Hint: You will need to rewrite or cast the expression.
So I must override using descriptor customizer? Is kinda strange since I can insert into that column the IP as normal string.
This gets generated, nothing special (And it dies):
Call: INSERT INTO "table" (columns ...) VALUES (?, ?, ?, ?, ?, ?, ?)
	bind => [7 parameters bound]
And this WORKS:
VALUES (... '127.0.0.1' ...);
So when I call an ordinary query I can pass inet field as standard string and it all works. When a prepared statement it called via eclipselink and inet is bound as a string everything dies. A bug certiainly, but is there any workaround or a trick to make it work? Converter doesn't seem to work.
Re: Postgres inet type [message #981629 is a reply to message #980721] Mon, 12 November 2012 10:18 Go to previous messageGo to next message
If it accepts your string inline with the statement, you might try turning parameter binding off.
See
http://eclipse.org/eclipselink/documentation/2.4/jpa/extensions/q_bindparameters.htm
for info on the property
[Updated on: Mon, 12 November 2012 11:11] by Moderator
Re: Postgres inet type [message #982992 is a reply to message #981629] Tue, 13 November 2012 10:37 Go to previous messageGo to next message
What database type is inet? If you JDBC driver does not allow binding a String, then you can use a Converter to convert to the required database type.
Re: Postgres inet type [message #984694 is a reply to message #980721] Wed, 14 November 2012 17:37 Go to previous messageGo to next message
Well I can always use a native query and I will for now.
@Chris: Yes it accepts param inet as inline string in a native query. The link you posted doesn't make it exactly clear (I am using java EE!) if I can just use @QueryHint annotation on a @Entity class to override the behaviour just for it? That would be perfect I guess. Does it do escaping if you do it like that automatically?
@James: The problem is I don't know. Manual doesn't say: http://www.postgresql.org/docs/9.2/static/datatype-net-types.html And yea, I am quite sure that is the problem. Strangely though it accepts string inline no problems. I guess I need to take this to postgre people.
[Updated on: Wed, 14 November 2012 17:44] by Moderator
Re: Postgres inet type [message #985579 is a reply to message #984694] Thu, 15 November 2012 09:04 Go to previous messageGo to next message
You might find this link helpful:
https: github.com/ancoron/pg-inet-maven/wiki/Support-custom-data-types-in-EclipseLink
Re: Postgres inet type [message #985698 is a reply to message #980721] Thu, 15 November 2012 12:40 Go to previous messageGo to next message
You need to add parameter ?stringtype=unspecified to your JDBC connection string. This is due to reason that inets in your query are explicitly casted to Strings by PostgreSQL JDBC driver.
Re: Postgres inet type [message #985744 is a reply to message #985698] Thu, 15 November 2012 17:14 Go to previous message
Query hints apply only to the query they are added to, while if the propertiy is set in the persistence.xml it will apply to every query. So the @QueryHint neededs to be added within a named query annotation, not an entity. Example 4-27 needs improvement but I don't have an example handy at the moment, I'll try fixing the example tomorrow.
Previous Topic:Pagination - FIRST_ROWS_N
Next Topic:PostGIS + Eclipselink
Current Time: Fri Jul 25 22:51:37 EDT 2025
Powered by FUDForum. Page generated in 0.05304 seconds
