Home » Eclipse Projects » Plugin Development Environment (PDE) » Error Exporting Plugin : Home/Classes does not exist
Error Exporting Plugin : Home/Classes does not exist [message #900920] Thu, 09 August 2012 00:17 Go to next message
I'm stuck on this error. I'm in OS X and trying to run my Eclipse on the 1.7 JDK from Oracle. I also picked 1.7 as the execution environment for my plugin. When I try the "Export Wizard", then under "Destination" choose "Directory", I get this error ...
/Users/rob/Workspace/.metadata/.plugins/org.eclipse.pde.core/temp/org.eclipse.pde.container.feature/compile.org.eclipse.pde.container.feature.xml:4: The following error occurred while executing this line:
/Users/rob/Workspace/BambooEclipse/build.xml:31: /Library/Java/JavaVirtualMachines/1.7.0.jdk/Contents/Home/Classes does not exist.
Any ideas?
thanks,
Rob
Re: Error Exporting Plugin : Home/Classes does not exist [message #984789 is a reply to message #900920] Wed, 14 November 2012 19:25 Go to previous messageGo to next message
If you are still having this problem. Go to '/Library/Java/JavaVirtualMachines/1.7.0.jdk/Contents/Home' and create an empty folder called 'Classes' in it (you will need administrative privileges for this).
For some reason empty folder works.
Re: Error Exporting Plugin : Home/Classes does not exist [message #985649 is a reply to message #900920] Thu, 15 November 2012 10:31 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=392434
The errors should be fixed in 3.8.2 and 4.3.
Previous Topic:how to clone cdt.managedbuild.tool.gnu.c.linker
Next Topic:Simplify PDE Builds for similar projects
Current Time: Fri Jul 25 20:42:53 EDT 2025
Powered by FUDForum. Page generated in 0.05094 seconds
