Home » Modeling » TMF (Xtext) » Name validation for imported files
Name validation for imported files [message #984611] Wed, 14 November 2012 16:09 Go to next message
I have a language where names imported from another file cannot be overwritten by newly defined variables. So if I have
file1.mydsl
  a : int
  b : int
file2.mydsl
  import "file1.mydsl"
  a : int
  c : int
I want it to flag an error on the 'a' declared in file2.mydsl. I've tried following the solution presented in this post, but it is overinclusive. In particular, if I have an unrelated file3.mydsl which declares 'c' it will still give an error in file1.mydsl, even though file3.mydsl is never imported into that context. I am using the ImportUriGlobalScopeProvider, but IContainer.Manager.getVisibleContainers seems to have a different notion of visibility from the scope provider. Any ideas?
Re: Name validation for imported files [message #984629 is a reply to message #984611] Wed, 14 November 2012 16:28 Go to previous messageGo to next message
you can simply check if the uri of the duplications found somehow match your import scheme. (the IEObjectDescription contains the uri as well)
~Christian
Re: Name validation for imported files [message #985580 is a reply to message #984629] Thu, 15 November 2012 09:07 Go to previous messageGo to next message
Thanks for the response Christian. Are you suggesting that I navigate my model to find the import statements and then compare them against the URI of the "visible" object? This seems like a lot more work than I would expect for such a task, and I don't think it would cover transitive imports (a imports b and b imports c, etc). I was hoping there was a way to just leverage all the work already done in the scopeprovider to simply detect if a name is already present in the scope and flag that as an error.
-Andrew
Re: Name validation for imported files [message #985605 is a reply to message #985580] Thu, 15 November 2012 09:26 Go to previous messageGo to next message
Hi alternatively you could ask your global scope provider for an
scope for a reference of your type and traverse the scopes elements.
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Name validation for imported files [message #985621 is a reply to message #985605] Thu, 15 November 2012 09:45 Go to previous messageGo to next message
Here is the code I am trying now, but it isn't working.
@Check
public void checkNamesUnique(Name name) {
	IScope scope = globalScopeProvider.getScope(name.eResource(), MydslPackage.Literals.NAME__EXPR, null);
	System.out.println(scope.getAllElements());
In this language 'Name' is the element being referenced and it can appear inside an 'Expr'. When the code above is run, the set of all elements is always empty. Am I calling the global scope provider incorrectly?
-Andrew
Re: Name validation for imported files [message #985636 is a reply to message #985621] Thu, 15 November 2012 10:05 Go to previous messageGo to next message
Hi am not sure if null is a valid filter you could try
predicates.always true. And I don't know if there reference is
correct. You could try
Ereference ref = ecorefactory.created reference.
ref.setetype(xxx.ltersls.name)
Re: Name validation for imported files [message #985640 is a reply to message #985621] Thu, 15 November 2012 10:10 Go to previous messageGo to next message
I switched to calling the global scope provider with the following EReference:
MydslPackage.Literals.INTERFACE_DEF__VARDEFS
Where VarDefs is the place where Names are declared. This seems to return the proper scope so I can do the validation easily.
Next I'll look at how to detect duplicate names from two different imports (e.g. both file1.mydsl and file2.mydsl declare 'a' and are both imported into file3.mydsl).
Andrew
Re: Name validation for imported files [message #985650 is a reply to message #985640] Thu, 15 November 2012 10:32 Go to previous messageGo to next message
Hi it is pretty the same. Check the global scope for duplicates
Re: Name validation for imported files [message #985679 is a reply to message #985650] Thu, 15 November 2012 11:44 Go to previous messageGo to next message
My plan was to check the global scope for duplicates, but I don't see how to navigate the global scope. If I call scope.getAllElements() it only returns non-shadowed elements. Thus my plan was to walk up the scope manually and look at each part of the scope by hand, but there doesn't seem to be a way to look at just the local elements of a scope (such methods are protected rather than public). Is there a known way to do this?
-Andrew
Re: Name validation for imported files [message #985690 is a reply to message #985679] Thu, 15 November 2012 12:19 Go to previous messageGo to next message
Hi what so you mean with "only non shadowed"
Re: Name validation for imported files [message #985697 is a reply to message #985690] Thu, 15 November 2012 12:39 Go to previous messageGo to next message
Suppose I have
file1.mydsl
  a : int
  b : int
file2.mydsl
  a : int
  c : int
file3.mydsl
  import "file2.mydsl"
Then if I get the global scope of file3 and ask for all elements, I get back [a, b, c] where the 'a' refers only the 'a' from file1. The the 'a' from file2 is shadowed so I can't detect the name conflict from the scope directly.
Re: Name validation for imported files [message #985705 is a reply to message #985697] Thu, 15 November 2012 13:02 Go to previous messageGo to next message
Hi is the a conflict at all if the default implementation of the
importuriglobalscope provider has this first come first serve rule
built in
Maybe you have to query the index for this use case anyway
Re: Name validation for imported files [message #985706 is a reply to message #985705] Thu, 15 November 2012 13:08 Go to previous message
PS maybe iterating the parents works too
Previous Topic:Creating Proxies from JvmType
Next Topic:Display Exception while generating Model-Output to User
Current Time: Thu Jul 24 22:17:14 EDT 2025
Powered by FUDForum. Page generated in 0.09444 seconds
