Home » Modeling » TMF (Xtext) » Resolving Crossreferences in Eclipse context
Resolving Crossreferences in Eclipse context [message #985460] Thu, 15 November 2012 07:12 Go to next message
I'd like to resolve crossreferences across multiple files in my DSL to display some actual values in Tooltips.
Multiple files are included with explicit include statements like in C. I have a class, that processes reads these include statements, put the referenced files in a ResourceSet and calls EcoreUtil.resolveAll() on the ResourceSet to resolve crossreferences across multiple files.
This works fine when running it Standalone after calling StandaloneSetup. When called in EObjectDocumentationProvider or anywhere else in the editor context crossreferences don't get resolved and remain as "Link<someNumbers>" in the Model.
Why does EcoreUtil.resolveAll() not work in the eclipse context and how can I resolve these crossreferences?
I'm sure, I'm doing something horribly wrong, but I haven't found the right way yet. Wink
Re: Resolving Crossreferences in Eclipse context [message #985513 is a reply to message #985460] Thu, 15 November 2012 08:03 Go to previous messageGo to next message
Hi how do you get the resource set. ?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Resolving Crossreferences in Eclipse context [message #985545 is a reply to message #985513] Thu, 15 November 2012 08:35 Go to previous messageGo to next message
It's a bit messy. Maybe I need to clean that up...
List<Resource> result = new ArrayList<Resource>();
URI rootFile = URI.createFileURI(filename);
Resource rootResource = null;
ResourceSet rs = new ResourceSetImpl();
rootResource = rs.getResource(rootFile, true);
<recursion that adds imported files to result>
result.add(0, rootResource);
ResourceSet resourceSet = new ResourceSetImpl();
for(Resource resource : result) {
	resourceSet.getResource(resource.getURI(), true);
EcoreUtil.resolveAll(resourceSet);
I hope that's all of the relevant lines.
Re: Resolving Crossreferences in Eclipse context [message #985547 is a reply to message #985545] Thu, 15 November 2012 08:38 Go to previous messageGo to next message
I forgot... the List<Resource> is returned in a Variable resources and then this happens:
		List<Resource> resources = createResources(filename);
		if (resources != null) {
			for(Resource resource : resources) {
I really need to clean up this mess...
Re: Resolving Crossreferences in Eclipse context [message #985567 is a reply to message #985545] Thu, 15 November 2012 08:53 Go to previous messageGo to next message
Use Iresourcesetprovider to get the resourceset
Re: Resolving Crossreferences in Eclipse context [message #985641 is a reply to message #985567] Thu, 15 November 2012 10:15 Go to previous messageGo to next message
ok, I used
IResourceSetProvider resourceSetProvider;
ResourceSet resourceSet = resourceSetProvider.get(ResourcesPlugin.getWorkspace().getRoot().getProject());
to initialize the ResourceSet but the references still don't get resolved. Have I used IResourceSetProvider correctly?
Re: Resolving Crossreferences in Eclipse context [message #985648 is a reply to message #985641] Thu, 15 November 2012 10:30 Go to previous messageGo to next message
Can you give more Context? How where do you call the stuff. Are you
sure you use the right project?
Re: Resolving Crossreferences in Eclipse context [message #986271 is a reply to message #985460] Mon, 19 November 2012 11:48 Go to previous message
I got it...
Here's something for others that have this problem:
To get the resourceSet from a URI:
IResourceSet resourceSet = null;
if (resourceSetProvider != null) {
	IWorkspace workspace = ResourcesPlugin.getWorkspace();
	String s = uri.isPlatformResource() ? uri.toPlatformString(true) : uri.toString();
	IPath path = new Path(s);
	IResource resource = workspace.getRoot().getFile(path);
	IProject project = null == resource ? null : resource.getProject();
	resourceSet = resourceSetProvider.get(project==null?);
}else{
The ResourceSetProvider can be initialized by Guice. By supplying (optional = true) it will be null when running standalone, thus explaining the if-clause above.
(optional = true)
If this solution is stupid, please tell me...
Previous Topic:Functions with parameter types
Next Topic:Scoping and cross-references
Current Time: Sun Jul 27 11:42:43 EDT 2025
Powered by FUDForum. Page generated in 0.53935 seconds
