Home » Language IDEs » C / C++ IDE (CDT) » Cannot add an so file(Cannot add a library to a project)
Cannot add an so file [message #982830] Tue, 13 November 2012 07:59 Go to next message
I want to add an *.so file to my project so that it dont shows all the functions while auto completing and to remove errors.
I followed the below procedure
project properties->C/C++ build->Settings->GCC C++ Linker->Libraries->
but there ins no way to open GCC C++ Linker. I have attached a screenshot of the same. Please check it
index.php/fa/12318/0/
Any help is appreciated Laughing
  • Attachment: eclipse.png
    (Size: 82.98KB, Downloaded 633 times)
Re: Cannot add an so file [message #983891 is a reply to message #982830] Wed, 14 November 2012 03:20 Go to previous messageGo to next message
You are using a so called Makefile project, i.e. you provide a Makefile and Eclipse will then just call make. Eclipse will not change your Makefile or offer you the GUI to modify it. You have to add the linker options in the Makefile manually.
If you want Eclipse to manage the Makefile then you must go to project properties->C/C++ build and check "Generate Makefiles".
Re: Cannot add an so file [message #983948 is a reply to message #983891] Wed, 14 November 2012 04:23 Go to previous messageGo to next message
The next problem is that I can make the same in terminal. But when I try to do it on eclipse make it shows error: unknown type name 'Value'.
Value is defined by a set of ifdef ......
[Updated on: Wed, 14 November 2012 04:26] by Moderator
Re: Cannot add an so file [message #983949 is a reply to message #983948] Wed, 14 November 2012 04:24 Go to previous message
Also for some reason even after including stdio.h it says it cant find FILE
Previous Topic:MISRA C Checker for Codan
Next Topic:Associate source of project while debugging with gdbserver
Current Time: Wed Jul 23 05:32:09 EDT 2025
Powered by FUDForum. Page generated in 0.06616 seconds
