Home » Modeling » TMF (Xtext) » Resolving cross-references in standalone
Resolving cross-references in standalone [message #977547] Fri, 09 November 2012 06:19 Go to next message
Hello!
I'm currently trying to export my model files to XMI in standalone. My language (called FCSS) refers to elements of another language (TVL). In the editor, cross references are right. However, when I try to generate the XMI, I cannot resolve them and get links like #xtextLink_::0.1.1.0::0::/1"/. I have read a lot of threads from this forum but was not able to solve my problem.
Here is my current export method, inspired by a previous thread:
public class Main {
	public static void main(String[] args) throws IOException {
		// register the TVLPackage to ecore
		EPackage.Registry.INSTANCE.put(TVLPackage.eNS_URI, TVLPackage.eINSTANCE);
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("tvl", new XMIResourceFactoryImpl());
		// register the resourceserviceprovider
		new TVLSupport().registerServices(true);
		// register the dsl
		Injector injector = new FCSSStandaloneSetup().createInjectorAndDoEMFRegistration();
		// load all model file to the resourceset
		XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
		resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
		Resource fcssResource = resourceSet.getResource(URI.createURI("/Users/Quentin/runtime-New_configuration/Test/Tune.fcss"), true);
		Resource tvlResource = resourceSet.getResource(URI.createURI("/Users/Quentin/runtime-New_configuration/Test/Tune.tvl"), true);
		// work with the resources (the elements come from Tune.tvl)
		fcssResource.load(null);
		Resource xmiResource = resourceSet.createResource(URI.createURI("/Users/Quentin/runtime-New_configuration/Test/Tune.xmi"));
		xmiResource.getContents().add(fcssResource.getContents().get(0));
		try {
			xmiResource.save(null);
		} catch (IOException e) {
			e.printStackTrace();
But, when I try to launch it, I get a
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseException: Content is not allowed in prolog.
at line
The code of TVLSupport is the following:
import org.eclipse.xtext.resource.generic.AbstractGenericResourceSupport;
import com.google.inject.Module;
public class TVLSupport extends AbstractGenericResourceSupport {
	protected Module createGuiceModule() {
		return new TVLRuntimeModule();
Do you have any idea of the sources of my problems?
Thank you very much for your help!
Re: Resolving cross-references in standalone [message #982702 is a reply to message #977547] Tue, 13 November 2012 05:51 Go to previous messageGo to next message
Does anybody have a clue?
Thanks!
Re: Resolving cross-references in standalone [message #982752 is a reply to message #982702] Tue, 13 November 2012 06:40 Go to previous messageGo to next message
Looks very strange to me:
1 call the stand alone setups
2 load all Xtext resources to the resource set
3 resolve all
4 add to xmi and save
No factory support etc stuff
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Resolving cross-references in standalone [message #985839 is a reply to message #982752] Fri, 16 November 2012 05:32 Go to previous message
Thank you for your answer!
I finally managed to implemented by looking at the main class generated by mwe2 workflow of my language.
Previous Topic:Chain 2 parsers/generators
Next Topic:Change of display string in editor after content assist
Current Time: Mon Jul 21 02:39:42 EDT 2025
Powered by FUDForum. Page generated in 0.34019 seconds
