Home » Eclipse Projects » Eclipse 4 » Custom StatusReporter (or how to override WorkbenchStatusReporter)
Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #915747] Mon, 17 September 2012 18:23 Go to next message
I need to change some of the behavior in WorkbenchStatusReporter.
Ideally I would like to extend WorkbenchStatusReporter and override the report method.
In PartRenderingEngine I can see where the status reporter is pulled from the context:
public void eventLoopException(Throwable exception) {
	StatusReporter statusReporter = (StatusReporter) appContext
			.get(StatusReporter.class.getName());
	if (statusReporter != null) {
		statusReporter.show(StatusReporter.ERROR,
				"Internal Error", exception);
	} else {
		if (logger != null) {
			logger.error(exception);
I thought I would be able to add my own with the following:
lContext.set(StatusReporter.class.getName(), new MyCustomStatusReporter());
But my custom one is never used; the code that gets the status reporter in PartRenderingEngine always ends up invoking StatusReporterCreationFunction (which creates an instance of WorkbenchStatusReporter).
How can I specify my own implementation of StatusReporter to replace/extend the WorkbenchStatusReporter?
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #915756 is a reply to message #915747] Mon, 17 September 2012 18:49 Go to previous messageGo to next message
Since StatusReporter is a core service you would need a bit extra work to get it done .
You would need to provide your context function as in http://www.vogella.com/articles/EclipseRCP/article.html#icontextfunction
Part of your component definition (create a {projectRoot}/OSGI-INF/component.xml)would look like this:
<implementation class="org.eclipse.e4.paho.client.OtherCF"/>
 <service>
   <provide interface="org.eclipse.e4.core.contexts.IContextFunction"/>
 </service>
 <property name="service.context.key" type="String"
   value="org.eclipse.e4.core.services.statusreporter.StatusReporter"/>
where *.OtherCF is something like:
public class OtherCF extends ContextFunction {
	public Object compute(IEclipseContext context) {
		return ContextInjectionFactory.make(MyWorkbenchStatusReporter.class,
				context);
where the MyWorkbenchStatusReporter is your StatusReporter extending and implementing anything you like.
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #981758 is a reply to message #915756] Mon, 12 November 2012 12:15 Go to previous messageGo to next message
Sorry to bump this old thread, but I'm noticing something weird here.
Using your example I was able to register my custom status reporter and everything works fine when launching from Eclipse.
However, we've noticed that the component is not registered when running from a standalone build that was built from Eclipse.
My MANIFEST.MF has this line:
Service-Component: OSGI-INF/StatusReporter.xml
StatusReporter.xml looks like this:
<scr:component xmlns:scr="hxxp://www.osgi.org/xmlns/scr/v1.1.0"
  name="com.company.blah.productname.StatusReporter">
<implementation class="com.company.blah.productname.StatusReporterContextFunction"/>
 <service>
 </service>
</scr:component>
StatusReporterContextFunction.java:
package com.company.blah.productname;
import org.eclipse.e4.core.contexts.ContextFunction;
import org.eclipse.e4.core.contexts.ContextInjectionFactory;
import org.eclipse.e4.core.contexts.IEclipseContext;
public class StatusReporterContextFunction extends ContextFunction {
	@Override public Object compute(IEclipseContext pContext) {
		return ContextInjectionFactory.make(StatusReporter.class, pContext);
Is there some additional step I'm missing to get this to work for a build running outside of Eclipse?
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #981882 is a reply to message #981758] Mon, 12 November 2012 14:28 Go to previous messageGo to next message
Did you check that the build.properties is correct? Also make sure the
bundle is activate lazy.
Tom
Am 12.11.12 18:15, schrieb Justin Unterreiner:
> <implementation
> <service>
> </service>
> </scr:component>
> pContext);
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #981916 is a reply to message #981882] Mon, 12 November 2012 15:06 Go to previous messageGo to next message
The build.properties includes the OSGI-INF directory:
output.. = bin/
bin.includes = META-INF/,\
               plugin.xml,\
               css/default.css,\
               Application.e4xmi,\
               conf/,\
               com.company.blah.productname.product,\
               images/,\
               OSGI-INF/
source.. = src/,\
           conf/
src.includes = images/
And the MANIFEST.MF contains the lazy activation policy:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: com.company.blah.productname
Bundle-SymbolicName: com.company.blah.productname; singleton:=true
Bundle-Version: 2.0.4
Bundle-Activator: com.company.blah.productname.Activator
Bundle-Vendor: company
Bundle-ActivationPolicy: lazy
Eclipse-RegisterBuddy: com.company.framework,
 com.company.blah.lib
Require-Bundle: javax.inject;bundle-version="1.0.0",
 org.eclipse.core.runtime;bundle-version="3.8.0",
 org.eclipse.swt;bundle-version="3.100.0",
 org.eclipse.core.databinding;bundle-version="1.4.1",
 org.eclipse.core.databinding.beans;bundle-version="1.2.200",
 org.eclipse.jface;bundle-version="3.8.0",
 org.eclipse.jface.databinding;bundle-version="1.6.0",
 org.eclipse.e4.ui.services;bundle-version="0.10.1",
 org.eclipse.e4.ui.workbench;bundle-version="0.10.2",
 org.eclipse.e4.core.services;bundle-version="1.0.0",
 org.eclipse.e4.core.di;bundle-version="1.1.0",
 org.eclipse.e4.core.contexts;bundle-version="1.1.0",
 org.eclipse.e4.ui.workbench.swt;bundle-version="0.10.1",
 org.eclipse.core.databinding.property;bundle-version="1.4.100",
 org.eclipse.e4.ui.css.core;bundle-version="0.10.1",
 org.w3c.css.sac;bundle-version="1.3.1",
 org.eclipse.e4.core.commands;bundle-version="0.10.1",
 org.eclipse.e4.ui.bindings;bundle-version="0.10.1",
 org.eclipse.ui;bundle-version="3.103.0",
 org.eclipse.ui.forms;bundle-version="3.5.200",
 com.company.blah.lib,
 com.company.productname2.model,
 com.company.productname2.business,
 com.company.productname2.model;bundle-version="1.6.0",
 org.eclipse.osgi.services;bundle-version="3.3.100",
 org.eclipse.nebula.widgets.datechooser;bundle-version="1.0.0",
 javax.annotation;bundle-version="1.0.0"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Import-Package: com.company.common.model.reporting,
 com.company.lassen.reporting,
 com.company.lib,
 com.company.blah.lib.swt,
 org.eclipse.e4.core.di.extensions,
 org.eclipse.e4.ui.di,
 org.osgi.framework;version="1.3.0",
 org.osgi.service.event;version="1.3.0"
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #982046 is a reply to message #981916] Mon, 12 November 2012 17:36 Go to previous messageGo to next message
@Justin: Properly you miss some flags. If you want create a small example (service plus small application) and send it to Lars.Vogel@gmail.com, I have a look.
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #985691 is a reply to message #982046] Thu, 15 November 2012 12:28 Go to previous messageGo to next message
I've created a standalone project and everything works as expected.
What really bugs me is that it works in my regular project when running from Eclipse, but not from the build that Eclipse produces. If it works when running from Eclipse, wouldn't that indicate that the configuration is correct and something is not created right for the build?
Is there a way I can turn on verbose or trace level logging in OSGI so I can see what is going on and/or why it is failing to load my component?
I tried adding the following to my launcher ini, but it didn't seem to make a difference.
-Dosgi.debug.verbose=true
-Dosgi.tracefile=C:/tmp/osgitrace.txt
Re: Custom StatusReporter (or how to override WorkbenchStatusReporter) [message #985707 is a reply to message #915747] Thu, 15 November 2012 13:13 Go to previous message
I ended up removing the XML file and reference in the manifest and did it programmatically via my Activator:
public void start(BundleContext bundleContext) throws Exception {
	Dictionary<String, Object> properties = new Hashtable<String, Object>();
	properties.put("service.context.key", "org.eclipse.e4.core.services.statusreporter.StatusReporter");
	StatusReporterContextFunction implementation = new StatusReporterContextFunction();
	bundleContext.registerService("org.eclipse.e4.core.contexts.IContextFunction", implementation, properties);
	Activator.context = bundleContext;
Previous Topic:Making a fixed perspective in an e4 model?
Next Topic:Injecting doesn't work - eModelService.find works - why?
Current Time: Wed Jul 23 06:12:51 EDT 2025
Powered by FUDForum. Page generated in 0.09474 seconds
