Home » Newcomers » Newcomers » Reloading CTabItems in a CTabFolder
Reloading CTabItems in a CTabFolder [message #981648] Mon, 12 November 2012 10:27 Go to next message
I have a multipage editor. In one of the pages I display one or more
views of some data. The Views are drawn on one or more CTabItems that
are in a CTabFolder. This all works fine. However, during runtime,
the user can change the parameters of the views (and even add or remove
views). So I need to be able to wipe out the current CTabFolder
(and/or its CTabItems) and re-create it.
My question is what is the best approach for this? It's not obvious
how exactly to remove the CTabFolder from the ScrolledForm. I'd prefer
to just remove each of the CTabItems from the folder but it isn't
obvious to me how to do that either. If someone can suggest the right
way or point me to some example code, I would be appreciative.
TIA, Ric
Re: Reloading CTabItems in a CTabFolder [message #981752 is a reply to message #981648] Mon, 12 November 2012 12:09 Go to previous messageGo to next message
Well, I experimented with simply calling dispose() on each of the
CTabItems in the CTabFolder, then recreating the CTabItems. This seems
to work fine, but am still not sure this is kosher behaviour.
> TIA, Ric
Re: Reloading CTabItems in a CTabFolder [message #981883 is a reply to message #981752] Mon, 12 November 2012 14:29 Go to previous messageGo to next message
That's the only possibility. Note that the children composites are not
disposed when you dispose the CTabItem!
Tom
Am 12.11.12 18:09, schrieb Ric Wright:
>> remove views). So I need to be able to wipe out the current
>> CTabFolder (and/or its CTabItems) and re-create it.
>> prefer to just remove each of the CTabItems from the folder but it
>> isn't obvious to me how to do that either. If someone can suggest the
>> right way or point me to some example code, I would be appreciative.
>> TIA, Ric
Re: Reloading CTabItems in a CTabFolder [message #982902 is a reply to message #981883] Tue, 13 November 2012 09:11 Go to previous message
Thanks Tom. And thanks for pointing out the additional cleanup
required, I'll make sure to take care of those as well.
Ric
> Tom
>>> TIA, Ric
Previous Topic:trouble again
Next Topic:Exception in thread "main" java.lang.Error: Unresolved compilation problem
Current Time: Sat Jul 26 11:07:53 EDT 2025
Powered by FUDForum. Page generated in 0.32617 seconds
