Home » Eclipse Projects » Gemini » [Solved]Gemini - is there a way to speed the startup?
[Solved]Gemini - is there a way to speed the startup? [message #975274] Wed, 07 November 2012 13:58 Go to next message
Does anyone have any issues starting up their application with gemini and it increasing the startup time from a couple of seconds to over a minute? I have my application handle two EMFs which are instantiated only once each. I have turned off logging to help speed this along, but it does not help very much. Does anyone have any suggestions to speed this along? I would like to get it to the 20 seconds ballpark at the very least for a normal machine.
Thanks!
[Updated on: Tue, 20 November 2012 12:07] by Moderator
Re: Gemini - is there a way to speed the startup? [message #981600 is a reply to message #975274] Mon, 12 November 2012 09:49 Go to previous messageGo to next message
Hi Scott,
I have not seen that issue occur but would be interested in learning more about what could be causing it. How many bundles are installed? Have you uninstalled the bundles that I asked you to not have installed (org.eclipse.persistence.jpa.equinox, org.eclipse.persistence.jpa.equinox.weaving, org.eclipse.persistence.jpa.osgi)? When you turn on debugging and logging where does the time get spent?
BTW, if you could identify the Gemini subproject you are asking a question about (e.g. Gemini JPA in this case) in the post title it would help. Thanks.
-Mike
Re: Gemini - is there a way to speed the startup? [message #985562 is a reply to message #981600] Thu, 15 November 2012 08:50 Go to previous message
Mike,
Looks like this issue was related to our previous post about OSGI refresh bundles error. I believe we have obtained an efficient execution time of our product's startup procedure. Turning off the debug in the persistence.xml files and getting the right bundles configured and ordered (including removing the older, obsolete bundles you mentioned earlier) helped out tremendously. I will mark this solved in the next few days once I have confirmed this to work across multiple machines.
Thanks again!
[Updated on: Thu, 15 November 2012 08:51] by Moderator
Previous Topic:[SOLVED] Gemini JPA bundles refresh even with -DREFRESH_BUNDLES=false
Next Topic:Gemini JPA 1.1.0 released
Current Time: Wed Jul 23 07:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.04984 seconds
