Home » Modeling » Graphiti » Getting exceptions on upgrading Graphiti from 0.8.2 version to Graphiti 0.9.1
Getting exceptions on upgrading Graphiti from 0.8.2 version to Graphiti 0.9.1 [message #974629] Wed, 07 November 2012 02:50 Go to next message
I was using Graphiti version 0.8.2 previously with which my code was working perfectly fine.
I have now upgraded to Graphiti 0.9.1.I was getting some compilation errors on upgradation, due to API changes in 0.9.1.
I have replaced the corresponding code to use the changed APIs.Now I get the following error while trying to run the code.
at org.eclipse.graphiti.ui.editor.DefaultPersistencyBehavior.isDirty(DefaultPersistencyBehavior.java:192)
at org.eclipse.graphiti.ui.editor.DiagramEditor.isDirty(DiagramEditor.java:899)
at org.eclipse.ui.internal.PartTester.testEditor(PartTester.java:45)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:687)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1459)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:972)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.iter.codac.sdd.product.intro.Application.chooseWorkspaceWithEclipse(Application.java:190)
at org.iter.codac.sdd.product.intro.Application.start(Application.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Any guess as what this error is about?
Re: Getting exceptions on upgrading Graphiti from 0.8.2 version to Graphiti 0.9.1 [message #981581 is a reply to message #974629] Mon, 12 November 2012 09:28 Go to previous message
Hemlata,
I guess the editor is not initialized correctly, the editing domain (EMF)
seems to be null.
Michael
Previous Topic:ReconnectionContext
Next Topic:Dragging between two diagrams
Current Time: Fri Jul 25 20:04:33 EDT 2025
Powered by FUDForum. Page generated in 0.04619 seconds
