Home » Modeling » M2T (model-to-text transformation) » [Xpand] model Root
[Xpand] model Root [message #981575] Mon, 12 November 2012 09:25 Go to next message
Hi all ,
I have a question concerning Modeling , Should any Model has a Root ? if Yes how I can access the Root of any model.xmi using xpand after I create dynamic instance of the metamodel ?(I want general template to access root of any Model.xmi)
if not could you please show me an example of a model without Root?
Thank you very much in advance.
Re: [Xpand] model Root [message #981725 is a reply to message #981575] Mon, 12 November 2012 11:47 Go to previous message
There is no need for either way, both is possible. The "root" is or are the elements that are direct content of a Resource. The root of any object can be accessed with eRootContainer. If you have multiple elements as direct content of the resource, you would have different results for that operation, since each of them is a root element.
~Karsten
Previous Topic:XMLBeautifier - Xpand - model to code generation
Next Topic:[Acceleo] generation exception after deploy
Current Time: Wed Jul 23 01:24:16 EDT 2025
Powered by FUDForum. Page generated in 0.04567 seconds
